* | 2004-08-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-08-18 | 1 | -2/+2 |
| | | | | | | PR 673/make_build * config-ml.in: Quote 'cd "${ml_origdir}"'. Quote 'cd "${ML_POPDIR}"'. | ||||
* | 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-23 | 1 | -0/+11 |
| | | | | | * config-ml.in: Don't built multilib variant normal (-mn) for h8300-*-rtems*. | ||||
* | 2003-07-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-07-15 | 1 | -15/+6 |
| | | | | | * config-ml.in: Partial sync with gcc-3.4's config-ml.in. Add "autoconf-2.5x unquoting" hack. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-25 | 1 | -1/+4 |
* | 2002-07-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-06 | 1 | -248/+21 |
| | | | | | * config-ml.in: Imported from gcc-3.1. Change to match c/src/config-ml.in. | ||||
* | Initial revision | Ralf Corsepius | 2002-07-06 | 1 | -0/+871 |
