2003-10-23 | 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+11 | |
* config-ml.in: Don't built multilib variant normal (-mn) for h8300-*-rtems*. | |||||
2003-07-15 | 2003-07-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -15/+6 | |
* config-ml.in: Partial sync with gcc-3.4's config-ml.in. Add "autoconf-2.5x unquoting" hack. | |||||
2003-03-25 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -1/+4 | |
2002-07-06 | 2002-07-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -248/+21 | |
* config-ml.in: Imported from gcc-3.1. Change to match c/src/config-ml.in. | |||||
2002-07-06 | Initial revision | Ralf Corsepius | 1 | -22/+248 | |
2002-05-14 | 2002-05-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -247/+14 | |
* config-ml.in: Take out arm and sh variants RTEMS does not support. | |||||
2001-12-18 | 2001-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+878 | |
* config-ml.in: New file. Imported from gcc and modified for RTEMS. |
