1999-11-04 | The files in libcpu should not be directly dependent on any BSP. In | Joel Sherrill | 60 | -113/+730 | |
particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated. | |||||
1999-11-03 | Renamed POSIX_Thread_cancel_run to _POSIX_Thread_cancel_run since RTEMS | Joel Sherrill | 5 | -8/+9 | |
internal symbols are supposed to have leading underscores. | |||||
1999-11-03 | Added CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM as a configuration | Joel Sherrill | 1 | -4/+3 | |
parameter. | |||||
1999-11-03 | Added prototype of _POSIX_Semaphore_Delete to avoid warnings. | Joel Sherrill | 1 | -0/+12 | |
1999-11-03 | Added prototype of POSIX_Thread_cancel_run to avoid warnings. | Joel Sherrill | 1 | -0/+12 | |
1999-11-03 | Typo fixed by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1 | -1/+1 | |
1999-11-02 | Split core mutex and semaphore handlers into separate files. | Joel Sherrill | 6 | -0/+561 | |
1999-11-02 | Split core message queue and watchdog handler objects into separate files. | Joel Sherrill | 15 | -993/+875 | |
1999-11-02 | Split Heap and Time of Day Handlers. | Joel Sherrill | 13 | -1537/+809 | |
1999-11-02 | Split threadq.c into multiple files. | Joel Sherrill | 17 | -2/+1280 | |
1999-11-02 | The object memfile.o was being included in the miniIMFS even though it | Joel Sherrill | 31 | -385/+682 | |
should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS. | |||||
1999-11-02 | Split object.c into multiple files. | Joel Sherrill | 17 | -983/+1375 | |
1999-11-02 | Split types.s into individual files. | Joel Sherrill | 12 | -172/+306 | |
1999-11-02 | Final tuning required to drop out POSIX timers. | Joel Sherrill | 4 | -47/+59 | |
1999-11-02 | *** empty log message *** | Joel Sherrill | 4 | -923/+985 | |
1999-11-02 | Split cancel.c into multiple files. | Joel Sherrill | 8 | -186/+280 | |
1999-11-02 | Missed these in the initial split up. | Joel Sherrill | 2 | -0/+177 | |
1999-11-02 | Split key.c into multiple files. | Joel Sherrill | 7 | -226/+294 | |
1999-11-02 | Wrong routine was initially cut into this file. | Joel Sherrill | 1 | -14/+6 | |
1999-11-02 | Split time.c into multiple files. | Joel Sherrill | 14 | -366/+578 | |
1999-11-02 | Split condition variables into multiple files. | Joel Sherrill | 15 | -484/+544 | |
1999-11-02 | Split the POSIX semaphore manager into multiple files. | Joel Sherrill | 18 | -588/+838 | |
1999-11-02 | Split some more stuff out of psignal.c. | Joel Sherrill | 7 | -236/+345 | |
1999-11-02 | Split mutex.c into multiple files. | Joel Sherrill | 23 | -703/+1037 | |
1999-11-02 | Split mqueue into multiple files. | Joel Sherrill | 1 | -0/+28 | |
1999-11-02 | Removed warnings. | Joel Sherrill | 1 | -2/+2 | |
1999-11-02 | Split mqueue.c into a variety of files. | Joel Sherrill | 17 | -673/+1127 | |
1999-11-02 | Minor changes to make the screen match a bit better. | Joel Sherrill | 2 | -4/+4 | |
1999-11-02 | Minor fixes to make screen match a bit better. | Joel Sherrill | 2 | -11/+15 | |
1999-11-02 | Added more proper checking of F_GETFL and F_SETFL. | Joel Sherrill | 1 | -5/+17 | |
Disabled test of F_DUPFD since it does not work. Added comment to indicate that seekdir(NULL) was being called. | |||||
1999-11-02 | Fixed F_SETFL to properly convert between internal | Joel Sherrill | 2 | -4/+6 | |
libio flags and external fcntl.h style flags. | |||||
1999-11-02 | Added support for configuring base filesystem. First attempt at | Joel Sherrill | 2 | -34/+82 | |
a full mount table at initialization. This is the wrong place to mount filesystems 2-n since no device drivers are initialized yet. | |||||
1999-11-02 | Install imfs.h so base filesystem can be configured or IMFS mounted | Joel Sherrill | 1 | -1/+1 | |
by an application. | |||||
1999-11-02 | Check for NULL being passed in. | Joel Sherrill | 8 | -4/+34 | |
1999-11-02 | Fixed typo where memfile_handlers set twice and directory_handlers | Joel Sherrill | 3 | -9/+9 | |
was not set. | |||||
1999-11-02 | Properly initialize location variable. | Joel Sherrill | 3 | -0/+24 | |
1999-11-02 | Split console_reserve_resources into its own file to reduce dependencies. | Joel Sherrill | 3 | -10/+30 | |
Still need to move debug io routines out. | |||||
1999-11-02 | Fixed bug which resulted in misaligned object control structures | Joel Sherrill | 1 | -3/+5 | |
being allocated. This bug manifested itself on the SPARC since it uses ldd/std in its context save/restore routines. | |||||
1999-11-02 | Added a comment to indicate that if a task blocked on a priority | Joel Sherrill | 1 | -0/+5 | |
based thread queue were to be reinserted based on its new priority, this is where the logic would go. | |||||
1999-11-02 | Added code to allocate by index. This is the object ID style used | Joel Sherrill | 1 | -27/+134 | |
by ITRON. Corrected spacing. | |||||
1999-11-02 | Added maximum count detection logic. | Joel Sherrill | 2 | -4/+16 | |
1999-11-02 | Added support for message priority as required by POSIX. | Joel Sherrill | 2 | -5/+43 | |
1999-11-02 | Corrected spacing. | Joel Sherrill | 1 | -2/+2 | |
1999-11-02 | Added message queues and semaphores. | Joel Sherrill | 1 | -0/+11 | |
1999-11-02 | Added CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES and | Joel Sherrill | 1 | -0/+24 | |
CONFIGURE_MAXIMUM_POSIX_SEMAPHORES. | |||||
1999-11-02 | Added comment to make sure Classic API priority to Core priority | Joel Sherrill | 1 | -0/+1 | |
is added in the future. | |||||
1999-11-02 | Added comments for _RTEMS_tasks_Create_extension, | Joel Sherrill | 1 | -4/+9 | |
_RTEMS_tasks_Start_extension, _RTEMS_tasks_Delete_extension, and _RTEMS_tasks_Switch_extension. | |||||
1999-11-02 | Added a case to support the core semaphore error returned when the | Joel Sherrill | 1 | -0/+8 | |
maximum semaphore count is exceeded. | |||||
1999-11-02 | Added code to utilize the maximum_count attribute of core semaphores | Joel Sherrill | 1 | -0/+7 | |
and initialize it to a value that would keep it from every being a problem. | |||||
1999-11-02 | Now much closer to working. | Joel Sherrill | 1 | -7/+61 | |
