* automake/compile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* wrapup/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* acinclude.m4: Rework RTEMS_CONFIG_SUBDIR.
* Makefile.am: Reflect changes to RTEMS_CONFIG_SUBDIR.
* start/Makefile.am: Build $(ARCH)/start16$(LIB_VARIANT).bin.
* Makefile.am: Remove RTEMS_BSP-subdir rule.
* configure.ac: Let AC_CONFIG_FILES(Makefile..) append explictit
rules for RTEMS_BSP-subdirs.
* support/Makefile.am: Pass @RTEMS_BSP@ to AM_CPPFLAGS.
* bsp.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* start/Makefile.am: Use project_lib_DATA.
* aclocal/env-rtemsbsp.m4: Add PROJECT_LIB.
* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* src/i386/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* src/m68k/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* src/powerpc/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* bootloader/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* wrapup/Makefile.am: Use mkdir_p. Remove dirs from
* include/rdbg/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* include/rdbg/i386/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* include/rdbg/m68k/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* include/rdbg/powerpc/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* src/i386/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* src/m68k/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* src/powerpc/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* pppd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_telnetd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_webserver/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* shared/cache/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mongoosev/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mongoosev/duart/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* tx39/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* cache/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc505/ictrl/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/clock/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/mmu/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8260/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8260/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8xx/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8xx/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* ppc403/ictrl/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* ppc403/tty_drv/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* shared/include/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* shared/src/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* bsp.am: Replace bsplibdir by project_libdir.
Use mkdir_p instead of mkinstalldirs.
* Makefile.am: Use mkdir_p instead of mkinstalldirs.
* wrapup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* console/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* motorola/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* openpic/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* pci/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* residual/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vectors/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* bootloader/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* vme/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* consolex/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Reworked.
* aclocal/lead-dot.m4: Remove (Provided by automake-1.8).
* automake/compile.am: Use mkdir_p instead of mkinstalldirs.
* automake/lib.am: Use mkdir_p instead of mkdir.
Remove $(PROJECT_RELEASE)/lib/$(dirstamp) handling.
* aclocal/env-rtemsbsp.m4: Remove bsplibdir.
Cleanups.
* Makefile.am: Remove project_libdir.
* configure.ac: Cosmetics.
* Makefile.am: Cosmetics.
* Makefile.am: Use include_ada_HEADERS.
* startup/Makefile.am: Add custom compilation rule for
rtems-ctor$(LIB_VARIANT).$(OBJEXT).
* aclocal/env-rtemsbsp.m4: AC_SUBST(project_libdir).
* automake/lib.am: Remove project_libdir.
* wrapup/Makefile.am: Reworked.
* bsp.am: Remove project_libdir.
* Makefile.am: Add dirstamp support.
* Makefile.am: Misc. fixes.
* bsp.am: Add project_libdir.
