mp01/Makefile.am: Reflect having moved automake.
mp01/node1/Makefile.am: Reflect having moved automake.
mp01/node2/Makefile.am: Reflect having moved automake.
mp02/Makefile.am: Reflect having moved automake.
mp02/node1/Makefile.am: Reflect having moved automake.
mp02/node2/Makefile.am: Reflect having moved automake.
mp03/Makefile.am: Reflect having moved automake.
mp03/node1/Makefile.am: Reflect having moved automake.
mp03/node2/Makefile.am: Reflect having moved automake.
mp04/Makefile.am: Reflect having moved automake.
mp04/node1/Makefile.am: Reflect having moved automake.
mp04/node2/Makefile.am: Reflect having moved automake.
mp05/Makefile.am: Reflect having moved automake.
mp05/node1/Makefile.am: Reflect having moved automake.
mp05/node2/Makefile.am: Reflect having moved automake.
mp06/Makefile.am: Reflect having moved automake.
mp06/node1/Makefile.am: Reflect having moved automake.
mp06/node2/Makefile.am: Reflect having moved automake.
mp07/Makefile.am: Reflect having moved automake.
mp07/node1/Makefile.am: Reflect having moved automake.
mp07/node2/Makefile.am: Reflect having moved automake.
mp08/Makefile.am: Reflect having moved automake.
mp08/node1/Makefile.am: Reflect having moved automake.
mp08/node2/Makefile.am: Reflect having moved automake.
mp09/Makefile.am: Reflect having moved automake.
mp09/node1/Makefile.am: Reflect having moved automake.
mp09/node2/Makefile.am: Reflect having moved automake.
mp10/Makefile.am: Reflect having moved automake.
mp10/node1/Makefile.am: Reflect having moved automake.
mp10/node2/Makefile.am: Reflect having moved automake.
mp11/Makefile.am: Reflect having moved automake.
mp11/node1/Makefile.am: Reflect having moved automake.
mp11/node2/Makefile.am: Reflect having moved automake.
mp12/Makefile.am: Reflect having moved automake.
mp12/node1/Makefile.am: Reflect having moved automake.
mp12/node2/Makefile.am: Reflect having moved automake.
mp13/Makefile.am: Reflect having moved automake.
mp13/node1/Makefile.am: Reflect having moved automake.
mp13/node2/Makefile.am: Reflect having moved automake.
mp14/Makefile.am: Reflect having moved automake.
mp14/node1/Makefile.am: Reflect having moved automake.
mp14/node2/Makefile.am: Reflect having moved automake.
cpuuse/Makefile.am: Reflect having moved automake.
malloctest/Makefile.am: Reflect having moved automake.
monitor/Makefile.am: Reflect having moved automake.
putenvtest/Makefile.am: Reflect having moved automake.
rtems++/Makefile.am: Reflect having moved automake.
rtmonuse/Makefile.am: Reflect having moved automake.
stackchk/Makefile.am: Reflect having moved automake.
termios/Makefile.am: Reflect having moved automake.
itronhello/Makefile.am: Reflect having moved automake.
itronmbf01/Makefile.am: Reflect having moved automake.
itronmbox01/Makefile.am: Reflect having moved automake.
itronsem01/Makefile.am: Reflect having moved automake.
itrontask01/Makefile.am: Reflect having moved automake.
itrontask02/Makefile.am: Reflect having moved automake.
itrontask03/Makefile.am: Reflect having moved automake.
itrontask04/Makefile.am: Reflect having moved automake.
itrontime01/Makefile.am: Reflect having moved automake.
* automake/compile.am, automake/host.am, automake/leaf.am
automake/local.am, automake/subdirs.am: New (copied from
../../../automake).
tools/Makefile.am: Reflect having moved automake.
lib/Makefile.am: Reflect having moved automake.
support/Makefile.am: Reflect having moved automake.
debug_ada/Makefile.am: Reflect having moved automake.
debug_c/Makefile.am: Reflect having moved automake.
dos_sup/Makefile.am: Reflect having moved automake.
network_ada/Makefile.am: Reflect having moved automake.
network_ada/adasockets/Makefile.am: Reflect having moved automake.
network_ada/listener/Makefile.am: Reflect having moved automake.
network_ada/tcprelay/Makefile.am: Reflect having moved automake.
ts_1325_ada/Makefile.am: Reflect having moved automake.
shmdr/Makefile.am: Reflect having moved automake.
shmsupp/Makefile.am: Reflect having moved automake.
tty/Makefile.am: Reflect having moved automake.
comm/Makefile.am: Reflect having moved automake.
io/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
pci/Makefile.am: Reflect having moved automake.
3c509/Makefile.am: Reflect having moved automake.
ide/Makefile.am: Reflect having moved automake.
ne2000/Makefile.am: Reflect having moved automake.
wd8003/Makefile.am: Reflect having moved automake.
fatal/Makefile.am: Reflect having moved automake.
consolex/Makefile.am: Reflect having moved automake.
tod/Makefile.am: Reflect having moved automake.
spurious/Makefile.am: Reflect having moved automake.
i2c/Makefile.am: Reflect having moved automake.
nvram/Makefile.am: Reflect having moved automake.
bootloader/Makefile.am: Reflect having moved automake.
motorola/Makefile.am: Reflect having moved automake.
openpic/Makefile.am: Reflect having moved automake.
residual/Makefile.am: Reflect having moved automake.
vme/Makefile.am: Reflect having moved automake.
PCI_bus/Makefile.am: Reflect having moved automake.
universe/Makefile.am: Reflect having moved automake.
dlentry/Makefile.am: Reflect having moved automake.
flashentry/Makefile.am: Reflect having moved automake.
canbus/Makefile.am: Reflect having moved automake.
scv64/Makefile.am: Reflect having moved automake.
sonic/Makefile.am: Reflect having moved automake.
liblnk/Makefile.am: Reflect having moved automake.
gdbsci/Makefile.am: Reflect having moved automake.
scitab/Makefile.am: Reflect having moved automake.
trap34/Makefile.am: Reflect having moved automake.
hw_init/Makefile.am: Reflect having moved automake.
gnatsupp/Makefile.am: Reflect having moved automake.
erc32sonic/Makefile.am: Reflect having moved automake.
cache/Makefile.am: Reflect having moved automake.
reg_win/Makefile.am: Reflect having moved automake.
syscall/Makefile.am: Reflect having moved automake.
mpc505/Makefile.am: Reflect having moved automake.
mpc505/ictrl/Makefile.am: Reflect having moved automake.
mpc505/timer/Makefile.am: Reflect having moved automake.
mpc505/vectors/Makefile.am: Reflect having moved automake.
mpc6xx/Makefile.am: Reflect having moved automake.
mpc6xx/clock/Makefile.am: Reflect having moved automake.
mpc6xx/exceptions/Makefile.am: Reflect having moved automake.
mpc6xx/mmu/Makefile.am: Reflect having moved automake.
mpc6xx/timer/Makefile.am: Reflect having moved automake.
mpc6xx/wrapup/Makefile.am: Reflect having moved automake.
mpc8260/Makefile.am: Reflect having moved automake.
mpc8260/clock/Makefile.am: Reflect having moved automake.
mpc8260/console-generic/Makefile.am: Reflect having moved automake.
mpc8260/cpm/Makefile.am: Reflect having moved automake.
mpc8260/exceptions/Makefile.am: Reflect having moved automake.
mpc8260/mmu/Makefile.am: Reflect having moved automake.
mpc8260/timer/Makefile.am: Reflect having moved automake.
mpc8xx/Makefile.am: Reflect having moved automake.
mpc8xx/clock/Makefile.am: Reflect having moved automake.
mpc8xx/console-generic/Makefile.am: Reflect having moved automake.
mpc8xx/cpm/Makefile.am: Reflect having moved automake.
mpc8xx/exceptions/Makefile.am: Reflect having moved automake.
mpc8xx/mmu/Makefile.am: Reflect having moved automake.
mpc8xx/timer/Makefile.am: Reflect having moved automake.
ppc403/Makefile.am: Reflect having moved automake.
ppc403/clock/Makefile.am: Reflect having moved automake.
ppc403/console/Makefile.am: Reflect having moved automake.
ppc403/ictrl/Makefile.am: Reflect having moved automake.
ppc403/timer/Makefile.am: Reflect having moved automake.
ppc403/tty_drv/Makefile.am: Reflect having moved automake.
ppc403/vectors/Makefile.am: Reflect having moved automake.
shared/Makefile.am: Reflect having moved automake.
shared/include/Makefile.am: Reflect having moved automake.
shared/src/Makefile.am: Reflect having moved automake.
mongoosev/Makefile.am: Reflect having moved automake.
mongoosev/duart/Makefile.am: Reflect having moved automake.
mongoosev/vectorisrs/Makefile.am: Reflect having moved automake.
r46xx/Makefile.am: Reflect having moved automake.
r46xx/vectorisrs/Makefile.am: Reflect having moved automake.
shared/cache/Makefile.am: Reflect having moved automake.
shared/interrupts/Makefile.am: Reflect having moved automake.
tx39/Makefile.am: Reflect having moved automake.
tx39/include/Makefile.am: Reflect having moved automake.
tx39/vectorisrs/Makefile.am: Reflect having moved automake.
