* | Tools moved to top-level directory per patch from Ralf Corsepius ↵ | Joel Sherrill | 1999-07-23 | 30 | -9146/+0 |
| | | | | <corsepiu@faw.uni-ulm.de>. | ||||
* | Patch to ease building MCP750 BSP. | Joel Sherrill | 1999-07-23 | 1 | -1/+4 |
* | Patch from Rosimildo DaSilva <rdasilva@connecttel.com> to readd calls to | Joel Sherrill | 1999-07-13 | 1 | -0/+10 |
| | | | | init() and fini() routines. | ||||
* | Patch from Eric Norum <eric@cls.usask.ca>: | Joel Sherrill | 1999-07-12 | 3 | -60/+45 |
| | | | | | | | | | | | | | | I get the following warning when compiling the latest snapshot. I had a quick look at the source -- it certainly looks to me like this is a real bug. ../../../../src/rtems-19990709/c/src/lib/libc/mount.c:97: warning: `options' might be used uninitialized in this function Also, I changed the TFTP test program and TFTP driver to reflect the changes in the way paths are passed to the TFTP driver. The TFTP driver now needs a proper `dotted-decimal' hostname as the second component of the path name. | ||||
* | changed version to 19990709 | Joel Sherrill | 1999-07-09 | 1 | -1/+1 |
* | New files from Jiri Gaisler <jgais@ws.estec.esa.nl>. | Joel Sherrill | 1999-07-09 | 3 | -0/+153 |
* | New file from Jake Janovetz <janovetz@tempest.ece.uiuc.edu>. | Joel Sherrill | 1999-07-09 | 2 | -0/+52 |
* | Patch from Eric Valette <valette@crf.canon.fr>: | Joel Sherrill | 1999-07-09 | 30 | -226/+108 |
| | | | | | | | | | | | | | | | - The same bug fix that was done on pc386 to prevent interrupt from occuring (never experienced it but who knows as I have 8259 emulation :() - Removed every compiler warning (except wrong ones and ones I can't do anything). - Removed any libc available code in code linked with mcp750 rtems executbale. Unfortunately using newlib functions for linking the bootloader does not work as the compilation options in bootloader (-mrelocatable -fixed-r13) are not compatible with newlib options. => I have put any libc external reference in one single new file (lib.c) that is linked only with the boot loader. Removing the file from ${OBJ} and using -lc crash the bootloader. Added big warning... | ||||
* | Patch from Jiri Gaisler <jgais@ws.estec.esa.nl>: | Joel Sherrill | 1999-07-09 | 13 | -58/+197 |
| | | | | | | + interrupt masking correction + FPU rev.B workaround + minor erc32 related fixes | ||||
* | Make sure pthread init stack size is always set. | Joel Sherrill | 1999-07-09 | 1 | -0/+5 |
* | Moved definitions to a more logical place. | Joel Sherrill | 1999-07-08 | 1 | -4/+4 |
* | New file. | Joel Sherrill | 1999-07-03 | 1 | -0/+56 |
* | New files missed in previous addition. | Joel Sherrill | 1999-07-03 | 4 | -0/+1896 |
* | Added some C++/GNU sections. | Joel Sherrill | 1999-07-03 | 1 | -1/+8 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> that splits | Joel Sherrill | 1999-07-02 | 36 | -121/+131 |
| | | | | | | boot_card() and main() into separate files to ease configuration of other packages. This was a big step in the way to build TCL, ncurses, and zlib for RTEMS. | ||||
* | Added code to initialize the /etc/group and /etc/passwd files. | Joel Sherrill | 1999-07-02 | 4 | -0/+182 |
* | Fixed format strings and warnings. | Joel Sherrill | 1999-07-02 | 4 | -18/+18 |
* | Reentrant versions added by Joel. Signficant formatting cleanup. | Joel Sherrill | 1999-07-02 | 5 | -231/+353 |
* | Password and group routines added by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1999-07-02 | 5 | -1/+501 |
* | Patch from Eric Valette <valette@crf.canon.fr> to clean up the | Joel Sherrill | 1999-07-01 | 77 | -709/+751 |
| | | | | previous submission. | ||||
* | Honor 0 as PID of caller. | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | Another attempt at getting everything to build with the new powerpc | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
| | | | | libcpu. | ||||
* | Fixed typo. | Joel Sherrill | 1999-07-01 | 1 | -2/+2 |
* | Added signal_2 file to contain signal(2). | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | New file to implement signal(2). | Joel Sherrill | 1999-07-01 | 1 | -0/+50 |
* | Modified to reflect change in calling sequence of mount(). | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | Test modified to reflect change in calling sequence of mount(). | Joel Sherrill | 1999-07-01 | 1 | -10/+10 |
* | Cleaned up to behave properly -- does not make a directory in the | Joel Sherrill | 1999-07-01 | 1 | -2/+1 |
| | | | | install tree and does not "cd wrapup." | ||||
* | Now preinstalls header files. | Joel Sherrill | 1999-07-01 | 1 | -4/+8 |
* | Removed mkdir of libcpu. This should have been at the top of the tree. | Joel Sherrill | 1999-07-01 | 1 | -1/+0 |
* | Remove mkdir command. It should be at the top level of the tree. | Joel Sherrill | 1999-07-01 | 1 | -1/+0 |
* | Modified to provide symbols with and without leading underscore in order | Joel Sherrill | 1999-07-01 | 1 | -0/+2 |
| | | | | to support a.out and ELF. | ||||
* | Modified to support ELF. Before SYM() macro was not used consistently. | Joel Sherrill | 1999-07-01 | 2 | -10/+10 |
* | Modified to ignore console interrupts. Otherwise console interrupts were | Joel Sherrill | 1999-07-01 | 1 | -2/+3 |
| | | | | Ada exceptions. Fixed by Joel with advice from Jiri. | ||||
* | Removed hack to set __USER_LABEL_PREFIX__ since late model gcc's and | Joel Sherrill | 1999-07-01 | 1 | -1/+0 |
| | | | | | egcs source tree handle this correctly. No one should be using gcc 2.7.2 anymore. | ||||
* | Added include/libcpu to list of directories made. | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | Regenerated. | Joel Sherrill | 1999-07-01 | 1 | -232/+147 |
* | Added dummy gnatinstallhandler code for all BSPs. This lets Ada programs | Joel Sherrill | 1999-06-24 | 34 | -33/+50 |
| | | | | link even if they do not actually support Ada interrupts. | ||||
* | Patch from Eric Valette <valette@crf.canon.fr> based on bug report from | Joel Sherrill | 1999-06-18 | 1 | -1/+0 |
| | | | | | David.Decotigny@irisa.fr and discussion with Joel. Basically interrupts were enabled too early in this BSP. | ||||
* | Removed pc386 specific command. | Joel Sherrill | 1999-06-18 | 1 | -3/+0 |
* | Switched to using right INSTALL command after report from | Joel Sherrill | 1999-06-17 | 3 | -3/+3 |
| | | | | Ian Lance Taylor <ian@airs.com>. | ||||
* | Patch from Ian Lance Taylor <ian@airs.com> to use INSTALL_CHANGE instead | Joel Sherrill | 1999-06-17 | 1 | -1/+1 |
| | | | | of INSTALL_DATA. | ||||
* | Patcg from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-06-16 | 22 | -386/+276 |
| | | | | | | | -- configure now fails to detect the toolchain for linux-posix. As work-around, I have reverted to the old behavior of RTEMS_TARGET_CPU_NAME, thus no_cpu/no_bsp will fail badly in configure again. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-06-15 | 33 | -188/+232 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | > When I run my script that just repeatedly builds different targets, some > of them die with an error like this: > > Making all RTEMS_BSP=gen68360 in cpugmake[5]: Entering directory > `/usr1/rtems/build/build-m68k-rtems/c/src/exec/score/cpu' > Making all RTEMS_BSP=gen68360 in @RTEMS_CPU@ > /bin/sh: @RTEMS_CPU@: No such file or directory > gmake[5]: *** [all] Error 1 > gmake[5]: Leaving directory > `/usr1/rtems/build/build-m68k-rtems/c/src/exec/score/cpu' > > It is not always the same variable substitution that fails. Sometimes it > is @INSTALL@. But reliably, it is a variable substitution that is > failing. > > Do you have any idea why this happens? Yep, I think I know what's going on. AC_SUBST(RTEMS_CPU) is missing in configure.ins, thus @RTEMS_CPU@ in target.cfg.in doesn't get substituted correctly, causing the bug above. Due to the redundancy of RTEMS_CPU, other most BSPs don't seem to be affected. Other similar problems probably exist for the unix/posix bsp and the hppa.1 cpu, because their */tools/*Makefile.ams require RTEMS_CPU, too. | ||||
* | Attempt at getting desired ioctl.h included. :) | Joel Sherrill | 1999-06-15 | 1 | -1/+1 |
* | After comments D. V. Henkel-Wallace <gumby@zembu.com>, the interface to | Joel Sherrill | 1999-06-15 | 10 | -78/+14 |
| | | | | mount() was changed to avoid the use of a string as the options. | ||||
* | Patch from Rosimildo DaSilva <rdasilva@connecttel.com> to make C++ | Joel Sherrill | 1999-06-15 | 4 | -3/+23 |
| | | | | | exceptions work on the pc386 BSP with i386-elf. This patch also included changes to the i386-rtemself egcs configuration. | ||||
* | RTEMS_FILESYSTEM_READ_WRITE_ONLY changed to RTEMS_FILESYSTEM_READ_WRITE | Joel Sherrill | 1999-06-14 | 5 | -5/+5 |
| | | | | for simplicity. | ||||
* | Wrong prototype corrected. | Joel Sherrill | 1999-06-14 | 2 | -2/+2 |
* | Warning removal from D. V. Henkel-Wallace <gumby@zembu.com>. | Joel Sherrill | 1999-06-14 | 5 | -18/+12 |
