stat()'ing a symbolic link. This is needed to support the port
of the BSD commands like ls to RTEMS.
functionality to libc and update TODO.
Hitachi H8 family. This port was done by Philip Quaife
<philip@qs.co.nz> of Q Solutions and sponsored by
Comnet Technologies Ltd. The port was done based on RTEMS 3.5.1
to a Hitach H8300H. The port was updated to RTEMS 4.5 style
Makefiles/configure by Joel Sherrill <joel@OARcorp.com>.
While doing this Joel added support for the h8300-rtems to
binutils, gcc, newlib, and gdb.
NOTE: Philip submitted a BSP for a Hitachi evaluation board
which is being merged as a separate entity.
generated assembly from it.
that breaks when the target has 16 bit address space. One of the H8
multilibs is a 16-bit address space CPU. When a real attempt is
made to support this CPU model, the code that assumes an address
is 32 bits will have to change. This constant is probably not
flagging all impacted code.
ttyHead back link is set.
with the new RPC code.
that does some cleanup:
* remove c/src/make/main.cfg.in (obsolete, unused) and any reference to it.
* remove RTEMS_BSP_SPECS from c/src/make/custom/default.cfg.in (unused)
All files being effected by this patch are only used when building
RTEMS, therefore this patch should not have any side-effects outside
of the source- rsp. build-tree.
Jennifer Averett <jennifer.averett@oarcorp.com> to fix
appends (O_APPEND at open time) on in-memory files.
A call such as:
fd = open (file, O_APPEND | O_WRONLY);
did not append to the end of the file.
Jennifer Averett <jennifer.averett@oarcorp.com> to make sure
"/" is created with S_IFDIR set.
names to be rtems_PACKAGE_method.
<corsepiu@faw.uni-ulm.de> to add -qnolinkcmds to bsp_specs like
other BSPs.
<corsepiu@faw.uni-ulm.de> to use __i386__ instead of __i386 and i386
to be able to compile this file with -ansi.
<corsepiu@faw.uni-ulm.de> to fix the following:
* lib/configure.in actually is libc's configure.in, so let it depend
on libc not on lib [In my Cygnus/GNU configuration scheme, lib/include
and lib/libc are treated as one unit, while libcpu and libbsp are
treated as separate units.]
* Allow empty --enable-bare* flags for the bare bsp. The formerly
used scheme is too strict for our multilib experiments.
<corsepiu@faw.uni-ulm.de> so these BSPs pick up the
components they need from libcpu.
<corsepiu@faw.uni-ulm.de> to fix a bad file reference.
include <sys/ioctl.h>.
non-networking applications could include <sys/ioctl.h>.
configurations could see it while including <sys/ioctl.h> and
<sys/ioccom.h>.
routine naming to follow RTEMS package/object.method rule.
This patch also eliminated calls to the obsolete routine
m68k_enable_caching.
by the network build.
file to Makefile.am.
to:
I have also added the ability to register and unregister commands. This
allows me to create a set of monitor commands for the network stack plus
basic memory dump/patch commands (needs a working probe interface). I
will also look at a basic ls/cd/rm/mv/cp command set at some stage.
I have been thinking about changing the monitor in the future to more
like a light weight RTEMS shell, `eshell' for embedded shell. This is a
story for another day but is a process or getting the commands to map to
the filesystem (eg, major=commands, minor=command) and supporting an
environment. The filesystem provide a structure for the commands.
initialization. This adds an interface which makes it easier to
control the BSD stack from user code. The BSD stack initialise uses
it. It is a sort of `function' interface for an ifconfig
command.
I also added support for attaching and removing interfaces. With hot
swap PCI comming online support for hot swap PCI will be an important
factor in "state of art" RTOS's. This is also part of a general move on
my part to allow RTEMS to be configured at runtime by calls rather than
table driven at initialisation.
are his notes:
installation prefix).
mpc8xx libcpu support for the first time and remove includes
of bsp.h, references to BSP_Configuration, and Cpu_table. All
of these can be obtained directly from RTEMS now.
responsibility to explicitly pick up the components they
require. This makes it easier to override default implmentations.
