* | bsp/t32mppc: Fix Trace32 configuration file | Sebastian Huber | 2012-06-04 | 1 | -3/+1 |
* | bsps/powerpc: Add load section for .nocache | Sebastian Huber | 2012-06-04 | 13 | -21/+48 |
* | bsp/qoriq: New BSP option | Sebastian Huber | 2012-06-04 | 2 | -0/+6 |
| | | | | New BSP option BSP_USE_DATA_CACHE_BLOCK_TOUCH. | ||||
* | powerpc: Simplify context switch | Sebastian Huber | 2012-06-04 | 6 | -368/+151 |
| | | | | | | | | | | | | | | | | | | | PowerPC cores with the SPE (Signal Processing Extension) have 64-bit general-purpose registers. The SPE context switch code has been merged with the standard context switch code. The context switch may use cache operations to increase the performance. It will be ensured that the context is 32-byte aligned (PPC_DEFAULT_CACHE_LINE_SIZE). This increases the overall memory size of the context area in the thread control block slightly. The general-purpose registers GPR2 and GPR13 are no longer part of the context. The BSP must initialize these registers during startup (usually initialized by the __eabi() function). The new BSP option BSP_USE_DATA_CACHE_BLOCK_TOUCH can be used to enable the dcbt instruction in the context switch. The new BSP option BSP_USE_SYNC_IN_CONTEXT_SWITCH can be used to enable sync and isync instructions in the context switch. This should be not necessary in most cases. | ||||
* | Fix C files which had two semi-colons at EOL | Joel Sherrill | 2012-05-31 | 14 | -17/+17 |
* | pc386: Added sections for rtems-libbsd support. | Jennifer Averett | 2012-05-30 | 1 | -0/+11 |
* | Add bspopts.h.in. | Ralf Corsépius | 2012-05-24 | 85 | -1/+3746 |
* | powerpc/t32mppc: Typo | Sebastian Huber | 2012-05-22 | 1 | -1/+1 |
* | powerpc/t32mppc: New BSP | Sebastian Huber | 2012-05-22 | 18 | -1/+841 |
* | powerpc/qoriq: Fix due to console API changes | Sebastian Huber | 2012-05-21 | 1 | -2/+2 |
* | powerpc/mpc55xxevb: Fix cache define usage | Sebastian Huber | 2012-05-21 | 1 | -5/+9 |
* | Remove references to configure.in. | Ralf Corsépius | 2012-05-18 | 3 | -3/+3 |
* | Remove obsolete reference to posix bsp. | Ralf Corsépius | 2012-05-18 | 1 | -2/+1 |
* | pci.h cleanup - Consolidate common defines to cpukit pci.h | Joel Sherrill | 2012-05-16 | 14 | -1191/+33 |
| | | | | | | | | | | | | | + libbsp/sparc/shared/include/pci.h was largely a copy of an older version of the cpukit pci.h. Removed much of the contents and included <rtems/pci.h>. + sparc/*/pci*.c - Move to <rtems/pci.h> required updating to use uint32_t for dword accesses. + Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION + Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove PCI_MULTI_FUNCTION definitions in C files. + Move PCI_INVALID_VENDORDEVICEID definitions from various C files to cpukit pci.h | ||||
* | mvme5500 and cpukit pci.h - Eliminate mvme5500 specific pci.h | Joel Sherrill | 2012-05-16 | 5 | -63/+5 |
| | | | | | | | | All constants that should have been in cpukit pci.h were moved there. One naming style was corrected. This impacted if_wm.c. All other contents were the same as powerpc/shared/pci.h so BSP specific pci.h could be eliminated. | ||||
* | LEON: moved register definitions into grlib header file | Daniel Hellstrom | 2012-05-16 | 21 | -134/+153 |
| | | | | | | | | | | | | Some register layout definitions for LEON3 reside in ambapp.h which does not really has anything to do with device registers. The register structures has been incorrectly named LEON3_*, the cores are not only used on LEON3 but on LEON4 and perhaps on LEON5 when that day comes. Some structures has been renamed according to the GRLIB core name instead, which CPU that actually use it is not relevant. Drivers has been updated with the new names. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> | ||||
* | Filesystem: Move operations to mount table entry | Sebastian Huber | 2012-05-15 | 1 | -1/+1 |
| | | | | | | | | | | | The scope of the file system operations is the file system instance. The scope of the file system node handlers is the file location. The benefit of moving the operations to the mount table entry is a size reduction of the file location (rtems_filesystem_location_info_t). The code size is slightly increased due to additional load instructions. Restructure rtems_filesystem_mount_table_entry_t to improve cache efficiency. | ||||
* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 53 | -161/+16 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 2430 | -5272/+0 |
* | Miscellaneous - Clean up file headers so patterns followed | Joel Sherrill | 2012-05-11 | 4 | -31/+28 |
| | | | | XXX | ||||
* | librtems++ - Remove junk line accidentally committed | Joel Sherrill | 2012-05-11 | 1 | -3/+2 |
* | pc386 - Clock driver compiles again plus clean up | Joel Sherrill | 2012-05-10 | 1 | -18/+26 |
| | | | | | | | The clock drivers were very inconsistent about prototyping the ISR handlers. This broke with the recent clean up. Tested on qemu. | ||||
* | clockdrv_shell.h - Fix commment | Joel Sherrill | 2012-05-10 | 1 | -1/+1 |
* | clockdrv_shell.c - Remove unreferenced and obsolete file | Joel Sherrill | 2012-05-10 | 1 | -16/+0 |
* | Clock Driver Shell - ISR handler prototype should follow port interrupt model | Joel Sherrill | 2012-05-10 | 1 | -1/+2 |
| | | | | | | The prototype for the clock driver tick isr varies based upon the interrupt model used by the port. This driver was checking solely upon a flag set by the BSP. | ||||
* | nds - Clock driver compiles again | Joel Sherrill | 2012-05-10 | 1 | -12/+17 |
* | nds/libnds - Fix missing prototype warning and formatting | Joel Sherrill | 2012-05-10 | 1 | -6/+9 |
* | hurricane - Remove unused file setvec.c | Joel Sherrill | 2012-05-10 | 1 | -44/+0 |
* | score603e - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -46/+0 |
* | virtex4 - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -6/+0 |
* | virtex - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -7/+0 |
* | mbx8xx - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -1/+0 |
* | haleakala - Eliminate commented out code | Joel Sherrill | 2012-05-09 | 1 | -8/+0 |
* | mpc8260ads - Eliminate commented out code | Joel Sherrill | 2012-05-09 | 1 | -6/+0 |
* | mpc8260ads - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -6/+0 |
* | malta - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -3/+0 |
* | jmr3904 - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -5/+0 |
* | hurricane - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -5/+0 |
* | genmongoosev - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -5/+0 |
* | rbtx4925 - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -5/+0 |
* | rbtx4938 - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 1 | -5/+0 |
* | csb350 - Eliminate any set_vector() remnants | Joel Sherrill | 2012-05-09 | 2 | -7/+14 |
* | libchip/serial - Only use set_vector() on Simple Vectored Architectures | Joel Sherrill | 2012-05-09 | 2 | -2/+11 |
* | librtems++ - Disable Interrupt Class When Not Simple Vectored | Joel Sherrill | 2012-05-09 | 1 | -0/+4 |
| | | | | | | This class only works on Simple Vectored Architectures. Even worse, it is not guaranteed to compile on a Programmable Interrupt Vector architecture. | ||||
* | jmr3904 - Correct tm27.h to use PIC Interrupt Model | Joel Sherrill | 2012-05-07 | 1 | -20/+9 |
* | genmongoosev - Correct tm27.h to use PIC Interrupt Model | Joel Sherrill | 2012-05-07 | 1 | -23/+9 |
* | csb350 - Correct tm27.h to use PIC Interrupt Model | Joel Sherrill | 2012-05-07 | 1 | -10/+8 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 300 | -0/+780 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 3 | -9/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 47 | -127/+0 |
