* | bsp/mpc55xx: Add register type definition | Sebastian Huber | 2013-02-25 | 1 | -1/+1 |
* | bsp/gen5200: New ATA driver | Sebastian Huber | 2013-02-20 | 10 | -45/+1566 |
| | | | | This is a replacement for the ATA task. The performance is much better. | ||||
* | bsp/gen5200: Add and use mpc5200_fatal() | Sebastian Huber | 2013-02-20 | 6 | -10/+27 |
* | bsp/mpc55xx: Fix prototype | Sebastian Huber | 2013-02-20 | 2 | -2/+2 |
* | make: Add default flags | Sebastian Huber | 2013-02-13 | 1 | -7/+4 |
* | make: Add CPPFLAGS | Sebastian Huber | 2013-02-13 | 1 | -0/+2 |
* | make: Remove -Wno-unused flag for debug variant | Sebastian Huber | 2013-02-13 | 1 | -1/+1 |
* | make: Remove -g flags | Sebastian Huber | 2013-02-13 | 1 | -3/+3 |
| | | | | The -g flag is set by the BSP. | ||||
* | make: Remove -qrtems_debug flag usage | Sebastian Huber | 2013-02-13 | 1 | -3/+3 |
* | bsps/powerpc: Remove unused files | Sebastian Huber | 2013-02-13 | 2 | -46/+0 |
* | bsp/lpc32xx: Add BSP_USB_OTG_TRANSCEIVER_VBUS | Sebastian Huber | 2013-02-12 | 1 | -0/+3 |
* | sparc64: revert linkcmds to 4 MB ram size | Gedare Bloom | 2013-02-11 | 1 | -2/+2 |
* | bsp/lpc24xx: Move UART probes to separate files | Sebastian Huber | 2013-02-11 | 6 | -53/+130 |
* | libchip/serial: Make NS16550 handler public | Sebastian Huber | 2013-02-11 | 5 | -18/+29 |
| | | | | This allows derived drivers to use these functions. | ||||
* | libchip/serial: Add const qualifier | Sebastian Huber | 2013-02-11 | 38 | -64/+64 |
* | libchip/serial: Fix warnings | Sebastian Huber | 2013-02-11 | 2 | -2/+13 |
* | libchip/serial: Fix warnings | Sebastian Huber | 2013-02-11 | 1 | -2/+1 |
* | libchip/serial: Fix warnings | Sebastian Huber | 2013-02-11 | 2 | -6/+9 |
* | bsp/erc32: Fix warnings | Sebastian Huber | 2013-02-11 | 1 | -2/+2 |
* | bsp/mpc55xx: Add MPC55XX_ENABLE_START_PROLOGUE | Sebastian Huber | 2013-02-06 | 5 | -0/+51 |
* | bsp/mpc55xx: Merge RSM6 variants into one | Sebastian Huber | 2013-02-06 | 16 | -150/+85 |
* | bsp/mpc55xx: Add and use BSP specific fatal codes | Sebastian Huber | 2013-02-06 | 7 | -20/+45 |
* | bsps/powerpc: Add and use ppc_cpu_is_specific_e200 | Sebastian Huber | 2013-02-06 | 2 | -2/+10 |
* | bsps/powerpc: Fix e200 check | Sebastian Huber | 2013-02-06 | 1 | -4/+2 |
* | bsp/mpc55xx: Add mpc55xx_mmu_apply_config() | Sebastian Huber | 2013-02-06 | 1 | -2/+12 |
* | bsp/mpc55xx: Add BSP_DATA_CACHE_USE_WRITE_THROUGH | Sebastian Huber | 2013-01-28 | 3 | -2/+13 |
* | bsps/powerpc: Add option for write-through cache | Sebastian Huber | 2013-01-28 | 1 | -1/+2 |
* | bsp/mpc55xx: Fix MMU configuration for RSM6 | Sebastian Huber | 2013-01-28 | 1 | -4/+4 |
* | Fixed virtex4,5 BSP compile time warnings | Ric Claus | 2013-01-26 | 6 | -7/+11 |
* | bsp/gen83xx: Disable caches in bsp_restart() | Sebastian Huber | 2013-01-18 | 1 | -1/+23 |
* | bsp/virtex5: Fix define location | Sebastian Huber | 2013-01-14 | 1 | -3/+2 |
* | bsp/lpc32xx: Bypass the IrDA modem for UART6 | Sebastian Huber | 2013-01-11 | 1 | -3/+6 |
* | bsps/arm: Fix LPC Ethernet driver initialization | Sebastian Huber | 2013-01-09 | 1 | -0/+3 |
* | bsp/gen83xx: Register I2C SEMTECH SC620 driver | Sebastian Huber | 2013-01-09 | 1 | -0/+12 |
* | libchip: Add I2C SEMTECH SC620 octal LED driver | Sebastian Huber | 2013-01-09 | 4 | -0/+141 |
* | bsps/powerpc: Add probe handler to I2C driver | Sebastian Huber | 2013-01-09 | 3 | -54/+57 |
* | bsps/powerpc: Fix compiler warnings | Sebastian Huber | 2013-01-09 | 1 | -4/+1 |
* | bsp/gen83xx: Invalidate caches only if disabled | Sebastian Huber | 2013-01-09 | 1 | -3/+10 |
* | bsp/gen83xx: System reset after fatal conditions | Sebastian Huber | 2013-01-09 | 1 | -1/+1 |
* | bsp/gen83xx: Add bsp_restart() | Sebastian Huber | 2013-01-09 | 3 | -0/+27 |
* | bsp/gen83xx: Delete obsolete region | Sebastian Huber | 2013-01-09 | 1 | -1/+0 |
* | leon3: disable unused ISR handler | Joel Sherrill | 2013-01-08 | 1 | -0/+2 |
* | leon3/shmsupp: Fix warnings & comment clean up | Joel Sherrill | 2013-01-08 | 3 | -65/+36 |
* | leon3: Open Ethernet Fixed Warning | Joel Sherrill | 2013-01-08 | 1 | -1/+1 |
* | no_bsp: Fix typo and format | Joel Sherrill | 2013-01-08 | 1 | -10/+10 |
* | m68k/mvme167: Compiles again | Joel Sherrill | 2013-01-08 | 3 | -48/+36 |
| | | | | | | Was including non-existent .h file. Fixed some warnings. Reformatted file header comment blocks. | ||||
* | arm/smdk2410: Update to include bspidle.c | Joel Sherrill | 2013-01-08 | 1 | -1/+1 |
| | | | | | This BSP shares code with the gp32 and needed to include the new bspidle.c file. | ||||
* | arm/gp32: Correct compilation error in BSP Idle Thread | Joel Sherrill | 2013-01-08 | 4 | -24/+38 |
| | | | | | | | Split BSP Idle Thread into separate file to follow convention used on other BSPs. Slight reformatting of file header comment block. | ||||
* | bsp/lpc24xx: Declare conditionally | Sebastian Huber | 2013-01-07 | 1 | -0/+4 |
* | bsp/lpc32xx: System reset after fatal conditions | Sebastian Huber | 2013-01-07 | 1 | -1/+1 |
