* | POSIX timer support. | Joel Sherrill | 1999-02-10 | 1 | -1/+1 |
* | Added this file. | Joel Sherrill | 1999-02-10 | 1 | -0/+8 |
* | Don't build spfatal since it won't run anyway. | Joel Sherrill | 1999-02-10 | 1 | -1/+1 |
* | Changed file name. | Joel Sherrill | 1999-02-10 | 1 | -2/+2 |
* | Set the read/write offset to 0 when the file is opened. The ACVC had a test | Joel Sherrill | 1999-02-10 | 2 | -0/+2 |
| | | | | | that performed the sequence open/write/close/open/read/close on a file. It did not get the correct result since the file descriptor was reused. | ||||
* | Corrected multiple places the file size was not being properly updated. | Joel Sherrill | 1999-02-10 | 3 | -6/+24 |
* | Added getcwd(). | Joel Sherrill | 1999-02-10 | 3 | -1/+561 |
* | POSIX timer support modifications. | Joel Sherrill | 1999-02-10 | 3 | -4/+16 |
* | Comments fixed after problem report from Ian Lance Taylor <ian@airs.com>. | Joel Sherrill | 1999-02-10 | 1 | -19/+10 |
* | Split SONIC chip into appropriate files for libchip'ing. The portable | Joel Sherrill | 1999-02-05 | 17 | -181/+2445 |
| | | | | | | portion is now in the libchip tree and the dmv177 configuration is in the dmv177 bsp. The performance impact of libchip'ing this driver was minimal. | ||||
* | Patch from Eric Norum to correct bug induced by select() patch. | Joel Sherrill | 1999-02-05 | 6 | -15/+33 |
* | Corrected spacing and added some new error checks that were needed | Joel Sherrill | 1999-02-05 | 7 | -57/+77 |
| | | | | to avoid dereferencing NULLs. | ||||
* | Added optional data and instruction caching enable calls. | Joel Sherrill | 1999-02-05 | 1 | -0/+13 |
* | Added caching enable routines. | Joel Sherrill | 1999-02-05 | 1 | -1/+1 |
* | Reorganized into libchip style but not yet split out into multiple files | Joel Sherrill | 1999-02-04 | 1 | -152/+206 |
| | | | | and placed in the right shareable directories. | ||||
* | Works great now. | Joel Sherrill | 1999-02-04 | 1 | -10/+27 |
* | Added printf()'s that can be uncommented to trace MBUF operations. This | Joel Sherrill | 1999-02-04 | 3 | -0/+9 |
| | | | | is very useful when debugging a device driver. | ||||
* | Modifed to reflect transition from device driver to file system. | Joel Sherrill | 1999-02-04 | 3 | -123/+12 |
* | Added debug printf()'s that are commented out. Uncommenting these | Joel Sherrill | 1999-02-04 | 3 | -0/+9 |
| | | | | | | allows one to trace the enqueueing and dequeueing of messages. This can be used to insure that packets are getting to the boundary between the network stack and the device driver. | ||||
* | Added PowerPC specific header checksum code. | Joel Sherrill | 1999-02-04 | 3 | -102/+15 |
* | Added PowerPC specific header checksum code. | Joel Sherrill | 1999-02-04 | 3 | -12/+183 |
| | | | | Added volatile to i386 assembly statements in header checksum code. | ||||
* | Debugged and now works except for handling of minor number. | Joel Sherrill | 1999-02-04 | 3 | -939/+1287 |
* | Modified to include comments on how to get TCPDEBUG turned on and | Joel Sherrill | 1999-02-04 | 6 | -3/+33 |
| | | | | printing messages. | ||||
* | Patch from John S Gwynne <jsg@donet.com> for malloctest. His comments: | Joel Sherrill | 1999-02-03 | 2 | -6/+12 |
| | | | | | | | | | | I have a few patches for the efi332 bsp. If you let me know when you expect the next snapshot release, I will try to have them to you before then. Also, the malloctest has some problems that I would think would prevent it from running on almost any platform. I have enclose patches below to fix (1) Task_id and Task_name dimensioning, (2) end of test message, (3) the amount of memory malloc'ed, and (4) retry on unsuccessful (out of memory) molloc's. | ||||
* | POSIX Timers submitted by Juan Zamorano Flores | Joel Sherrill | 1999-02-03 | 7 | -11/+1014 |
| | | | | <jzamora@avellano.datsi.fi.upm.es>. | ||||
* | New test from Juan Zamorano Flores <jzamora@avellano.datsi.fi.upm.es> | Joel Sherrill | 1999-02-03 | 1 | -1/+1 |
| | | | | that is part of the addition of POSIX timers. | ||||
* | New files from Juan Zamorano Flores <jzamora@avellano.datsi.fi.upm.es> | Joel Sherrill | 1999-02-03 | 4 | -0/+508 |
| | | | | that are part of the addition of POSIX timers. | ||||
* | New file. | Joel Sherrill | 1999-02-02 | 1 | -0/+61 |
* | Added debug #define and commented it out. | Joel Sherrill | 1999-02-02 | 3 | -0/+3 |
* | Added PowerPC specific in_cksum file. | Joel Sherrill | 1999-02-02 | 3 | -0/+12 |
* | New file. Based on the i386 version. | Joel Sherrill | 1999-02-02 | 3 | -0/+606 |
* | Added debug print routines for TX and RX descriptors. | Joel Sherrill | 1999-02-02 | 1 | -65/+89 |
| | | | | | Fixed bug where only the mbuf associated with the first TX fragment was being freed. | ||||
* | Converted from DOS text file. | Joel Sherrill | 1999-02-02 | 1 | -373/+373 |
* | Removed unneeded include of libio_.h. | Joel Sherrill | 1999-01-31 | 1 | -2/+0 |
* | Prepended macro variables with "_" to avoid name conflicts in expansions. | Joel Sherrill | 1999-01-31 | 3 | -234/+234 |
* | Added bump buffer. | Joel Sherrill | 1999-01-31 | 2 | -2/+4 |
* | Added dump buffer. | Joel Sherrill | 1999-01-31 | 1 | -1/+1 |
* | Can send and receive packets but fails when TDA wraps. There appears | Joel Sherrill | 1999-01-31 | 2 | -45/+113 |
| | | | | to be a problem with overwriting the TX descriptors during an RX. | ||||
* | Split psignal.c into many more files. This reduced the amount of | Joel Sherrill | 1999-01-31 | 22 | -919/+1350 |
| | | | | | object code that has to be loaded just for initializing the signal manager. | ||||
* | New files added to ease debugging. | Joel Sherrill | 1999-01-31 | 6 | -0/+302 |
* | Patch from Eric Norum <eric@skatter.usask.ca> to avoid dereferencing a | Joel Sherrill | 1999-01-28 | 3 | -3/+12 |
| | | | | NULL pointer. | ||||
* | Patch from Eric Norum <eric@skatter.usask.ca> to set more flags in | Joel Sherrill | 1999-01-28 | 2 | -4/+4 |
| | | | | rtems_bsdnet_makeFdForSocket(). | ||||
* | Added include of <rtems/posix/priority.h> so a macro would expand | Joel Sherrill | 1999-01-26 | 1 | -0/+1 |
| | | | | and eliminate a link error. | ||||
* | Changed prototype of rtems_bsdnet_makeFdForSocket to (void *) pointer | Joel Sherrill | 1999-01-26 | 3 | -3/+3 |
| | | | | so that the libc code did not have to know about (struct socket). | ||||
* | Switched from printf() to puts(). | Joel Sherrill | 1999-01-26 | 3 | -3/+3 |
* | Added libio_sockets.c to hold support routines for networking code. | Joel Sherrill | 1999-01-26 | 3 | -1/+117 |
* | Added prototype information about the SONIC driver. | Joel Sherrill | 1999-01-26 | 1 | -0/+9 |
* | Split most of POSIX Threads Manager into multiple files. | Joel Sherrill | 1999-01-25 | 31 | -958/+1362 |
* | Added enough prototypes to allow most of POSIX Threads Manager to be | Joel Sherrill | 1999-01-25 | 1 | -0/+26 |
| | | | | split into multiple files. | ||||
* | Made to compile after hacking tftp driver into beginnings of a mini-filesystem. | Joel Sherrill | 1999-01-21 | 15 | -117/+897 |
