Update #3285.
Update #3285.
The VME support is only used by powerpc BSPs.
Update #3285.
The umon support is only used by the csb337 BSP.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3375.
Update #3285.
Update #3285.
Started to eliminate warnings and then realized that only one one-line
macro in the file was used by a few files. The rest of the file was
was not needed. Eliminate the file.
Closes #3354.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3339.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
The boot/stack.h header contains duplicated macros that are
redundant to arch/stack.h. Delete the boot/stack.h and replace
its one use by the arch/stack.h.
Closes #3341.
Update #3285.
Update #3285.
Use only one timer driver variant based on the standard PowerPC time
base.
Update #3285.
The only consumer of this variable was the ppc403 clock driver used by
the
* haleakala,
* virtex, and
* virtex4
BSPs which set bsp_timer_internal_clock unconditionally to true.
Update #3285.
