* | Corrected to include shared console driver. | Joel Sherrill | 1999-05-28 | 1 | -1/+1 |
* | At the request of Gumby, the cpu is now halted rather than spinning | Joel Sherrill | 1999-05-28 | 1 | -1/+1 |
| | | | | on a fatal exception. | ||||
* | Renamed config.c to conscfg.c to avoid naming conflicts. | Joel Sherrill | 1999-05-28 | 2 | -284/+1 |
* | Renamed config.s to todcfg.c to avoid naming conflicts. | Joel Sherrill | 1999-05-28 | 2 | -80/+1 |
* | Renamed fatal.c to bspfatal.c to avoid name conflicts with | Joel Sherrill | 1999-05-28 | 2 | -128/+1 |
| | | | | Fatal Error handler in SuperCore. | ||||
* | Renamed tod.c to coretod.c to remove conflicts with "Time Of Day" | Joel Sherrill | 1999-05-28 | 2 | -240/+2 |
| | | | | device drivers. | ||||
* | Renamed clock.c to rtclock.c to avoid conflicts with clock drivers | Joel Sherrill | 1999-05-28 | 2 | -24/+1 |
| | | | | in various BSPs. | ||||
* | Switched from picking up the .rel for each subdirectory in the | Joel Sherrill | 1999-05-27 | 33 | -33/+33 |
| | | | | | BSP (BSP_PIECES) to picking up the .o files. This should help reduce the minimum size of an application. | ||||
* | Patch from Eric Norum <eric@pollux.usask.ca> to eliminate a panic when the | Joel Sherrill | 1999-05-27 | 9 | -441/+264 |
| | | | | network stack runs out of mbufs. | ||||
* | Split out the routine rtems_assoc_name_bad(). | Joel Sherrill | 1999-05-27 | 10 | -58/+166 |
* | Removed usage of printf. | Joel Sherrill | 1999-05-27 | 5 | -5/+5 |
* | Split initialization and reserve resources from termios to reduce | Joel Sherrill | 1999-05-27 | 7 | -119/+188 |
| | | | | size of mininum application. | ||||
* | Split out polled io, debug puts, and console reserve resources to | Joel Sherrill | 1999-05-27 | 4 | -83/+146 |
| | | | | reduce dependencies and shrink minimum executable size. | ||||
* | Disabled running size_rtems until all file splitting is finished. | Joel Sherrill | 1999-05-27 | 1 | -1/+1 |
* | Regenerated. | Joel Sherrill | 1999-05-27 | 12 | -947/+1693 |
* | Corrected so rtems.o is built and installed on all targets. | Joel Sherrill | 1999-05-27 | 10 | -31/+20 |
* | Corrected macro names. | Joel Sherrill | 1999-05-27 | 1 | -2/+6 |
* | Initiated updating this to reflect split up. | Joel Sherrill | 1999-05-26 | 1 | -2/+4 |
* | Renamed to rtemstimer.c to avoid conflict with timer drivers in EVERY | Joel Sherrill | 1999-05-20 | 2 | -53/+2 |
| | | | | BSP as we transition to more .o's and less .rel's. | ||||
* | Removed all post 4.0 changes. | Joel Sherrill | 1999-05-20 | 3 | -243/+234 |
* | Patch from Daniel Kelley <dank@icube.com>: | Joel Sherrill | 1999-05-18 | 2 | -8/+8 |
| | | | | | | I found a small buglet in the mips64orion _CPU_ISR_Set_level; the original was wiping out the level argument, and then comparing the current interrupt level with some random value of v0. See patch below. | ||||
* | Regenerated. | Joel Sherrill | 1999-05-18 | 14 | -1695/+949 |
* | Spacing correction. | Joel Sherrill | 1999-05-18 | 1 | -1/+0 |
* | Reworked to avoid pulling in the jump point entry in EVERY executable. | Joel Sherrill | 1999-05-17 | 11 | -19/+50 |
* | Fixed some typos. | Joel Sherrill | 1999-05-17 | 1 | -4/+4 |
* | Split Interrupt Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 3 | -41/+63 |
* | Split Signal Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 4 | -109/+158 |
* | Dual-Ported Memory Manager split into one routine per file. | Joel Sherrill | 1999-05-17 | 7 | -237/+351 |
* | Split Partition Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 7 | -307/+429 |
* | Split Timer Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 10 | -618/+475 |
* | Split Event Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 7 | -343/+460 |
* | Split Rate Monotonic Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 9 | -417/+573 |
* | Split the Semaphore Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 8 | -485/+771 |
* | Moved some MP routines to semmp.c. | Joel Sherrill | 1999-05-17 | 2 | -55/+54 |
* | Forgot to actually remove the routines. :) | Joel Sherrill | 1999-05-17 | 1 | -748/+0 |
* | Split Message Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 13 | -1/+1112 |
* | Moved an MP routine from msg.c to here. | Joel Sherrill | 1999-05-17 | 1 | -0/+26 |
* | Cleaned up some multiprocessing issues. | Joel Sherrill | 1999-05-17 | 1 | -17/+15 |
* | Split Clock Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 6 | -259/+199 |
* | Split Region Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 9 | -456/+623 |
* | Splitting the Thread Handler forced the inclusion of more prototypes. | Joel Sherrill | 1999-05-17 | 1 | -0/+33 |
* | Moved _Entry_Table to its own file to avoid having every RTEMS directive | Joel Sherrill | 1999-05-17 | 3 | -95/+107 |
| | | | | pulled in. | ||||
* | Added simple test to find minimum code size of executive with this BSP | Joel Sherrill | 1999-05-17 | 5 | -1/+125 |
| | | | | and RTEMS configuration. | ||||
* | Split Task Manager into multiple files. Eventually this effort will | Joel Sherrill | 1999-05-17 | 16 | -962/+1387 |
| | | | | reduce the size of executables. | ||||
* | Thread Handler split into multiple files. Eventually, as RTEMS is | Joel Sherrill | 1999-05-17 | 26 | -1305/+1990 |
| | | | | split into one function per file, this will decrease the size of executables. | ||||
* | Patch from D. V. Henkel-Wallace <gumby@zembu.com> to remove compiler | Joel Sherrill | 1999-05-17 | 9 | -12/+12 |
| | | | | warnings. | ||||
* | Patch from D. V. Henkel-Wallace <gumby@zembu.com>: | Joel Sherrill | 1999-05-17 | 1 | -0/+16 |
| | | | | | | Here's a tiny patch that shreds memory returned to the pool (such as by free() and delete). This may help people find some nasty bugs, so here it is. | ||||
* | Added testing for C++ exceptions from Rosimildo DaSilva | Joel Sherrill | 1999-05-14 | 1 | -17/+90 |
| | | | | <rdasilva@connecttel.com>. | ||||
* | Added 3COM 3C509 driver from Rosimildo DaSilva <rdasilva@connecttel.com>. | Joel Sherrill | 1999-05-14 | 7 | -2/+2247 |
* | Enabled compilation of rtems_servers at request of Jake Janovetz | Joel Sherrill | 1999-05-14 | 8 | -12/+16 |
| | | | | <janovetz@tempest.ece.uiuc.edu>. |
