* | Added port of ppp-2.3.5 from Tomasz Domin <dot@comarch.pl> of ComArch SA. | Joel Sherrill | 1999-11-30 | 46 | -9/+17945 |
| | | | | | | | | | | Tomasz only tested this on the mpc823. The official site for the original source for this PPP implementation is: ftp://cs.anu.edu.au/pub/software/ppp NOTE: As of 11/30/1999, the current version of this source is 2.3.10. | ||||
* | Renamed shm.h to shm_driver.h to avoid conflicts with POSIX shm.h. | Joel Sherrill | 1999-11-30 | 77 | -621/+80 |
| | | | | | Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager). | ||||
* | Removed duplicate definition of rtems_filesystem_umask. | Joel Sherrill | 1999-11-30 | 2 | -12/+0 |
* | Uncommitted remains of a previous patch from Ralf Corsepius | Joel Sherrill | 1999-11-30 | 6 | -1708/+0 |
| | | | | <corsepiu@faw.uni-ulm.de> which converted fiels to automake. | ||||
* | Uncommitted remains of a previous patch from Ralf Corsepius | Joel Sherrill | 1999-11-30 | 26 | -3302/+719 |
* | Split from console.c to eliminate dependencies. | Joel Sherrill | 1999-11-30 | 2 | -0/+122 |
* | Corrected so they would compile with POSIX disabled. | Joel Sherrill | 1999-11-30 | 4 | -4/+6 |
* | Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-29 | 42 | -601/+3112 |
| | | | | | | | | | | | | | | | | | | | | | | | which (among other things) converted the mptests to automake. SUB_DIRS was used instead of SUBDIRS in some Makefile.ins (apparently a leftover from moving the start* directories) Addtional major bugs: * psxtests/include was empty (incomplete psxtests changes). * bogus handling of *.scn in itrontests (screens/sptests vs. screens/itrontests installation dirs) In addition I have added a few more changes (I couldn't resist) * automake support for itrontests * OPERATION_COUNT support in tmitrontests/ * automake support for tmitrontests * automake suppport for mptests * Some (minor) corrections to several configure.in/Makefile.ams => c/src/tests/ is completly under automake control, now. => we could start to sort out the structural issues with c/src/tests (tests/support, stubdr, tools, get "make dist" working) | ||||
* | Made sure POSIX would build with MP enabled. | Joel Sherrill | 1999-11-29 | 7 | -10/+127 |
* | Fixed spacing. | Joel Sherrill | 1999-11-29 | 2 | -2/+2 |
* | Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-24 | 82 | -2456/+1794 |
| | | | | which (among other things) converted the mptests to automake. | ||||
* | Readding files mistakenly removed. | Joel Sherrill | 1999-11-23 | 40 | -0/+2289 |
* | Patch rtems-rc-19991117-16.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-11-23 | 8 | -7/+17 |
| | | | | | | | * the PACKHEX etc problem * prevents the *.rels being removed inside the build-tree * a typo which only shows for when MP is activated * Alters some custom/*cfg files | ||||
* | Readding Makefile.in's accidentally removed. | Joel Sherrill | 1999-11-23 | 1 | -0/+33 |
* | *** empty log message *** | Joel Sherrill | 1999-11-23 | 1 | -27/+21 |
* | Moved pmacros.h to include not support/include. | Joel Sherrill | 1999-11-23 | 21 | -119/+21 |
* | Patch rtems-rc-19991117-15.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 4 | -132/+75 |
| | | | | to convert the tests/support directory from Makefile.in to Makefile.am. | ||||
* | Missed in previous automake conversion patches from Ralf Corsepius | Joel Sherrill | 1999-11-23 | 9 | -0/+408 |
| | | | | <corsepiu@faw.uni-ulm.de>. | ||||
* | Miscellaneous patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 18 | -217/+1216 |
| | | | | | that are part of the Makefile.am conversion effort but were missed in the previous commits. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 8 | -18/+13 |
| | | | | to convert the libmisc directory from Makefile.in to Makefile.am. | ||||
* | Added clock06.c to the compile list. | Joel Sherrill | 1999-11-23 | 1 | -4/+2 |
* | Files only used by psxfile01, so moved there. | Joel Sherrill | 1999-11-23 | 5 | -10/+1 |
* | Test psxfile02 unused and removed. | Joel Sherrill | 1999-11-23 | 2 | -4/+1 |
* | Unused and removed. | Joel Sherrill | 1999-11-23 | 4 | -119/+0 |
* | Patch rtems-rc-19991117-14.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 56 | -2012/+1082 |
| | | | | to convert the psxtests directory from Makefile.in to Makefile.am. | ||||
* | Patch rtems-rc-19991117-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 1 | -0/+23 |
| | | | | to convert the libtests directory from Makefile.in to Makefile.am. | ||||
* | Patch rtems-rc-19991117-13.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 18 | -588/+359 |
* | Patch rtems-rc-19991117-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 63 | -2297/+1397 |
| | | | | to convert the tmtests directory from Makefile.in to Makefile.am. | ||||
* | Patch rtems-rc-19991117-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 76 | -3216/+755 |
| | | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib." | ||||
* | Patch rtems-rc-19991117-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-22 | 236 | -535/+709 |
* | Patch rtems-rc-19991117-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-22 | 39 | -39/+2 |
| | | | | to fix some minor bugs in the conversion to automake. | ||||
* | Patch rtems-rc-19991117-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-22 | 21 | -711/+464 |
| | | | | to convert the sample tests to automake. | ||||
* | Converted to automake. | Joel Sherrill | 1999-11-22 | 59 | -2995/+1120 |
* | Now replaced by an automake file. | Joel Sherrill | 1999-11-22 | 1 | -360/+0 |
* | Corrected. | Joel Sherrill | 1999-11-22 | 1 | -5/+1 |
* | Added ifndef around build_time so pmacros.h and tmacros.h could be included | Joel Sherrill | 1999-11-22 | 1 | -0/+2 |
| | | | | by the same application. | ||||
* | tmitrontests directory listed twice. | Joel Sherrill | 1999-11-22 | 1 | -1/+1 |
* | Fixed dispatching and cleaned up code. | Jennifer Averett | 1999-11-22 | 2 | -30/+14 |
* | + Corrected enable/disable of dispatch. | Jennifer Averett | 1999-11-22 | 1 | -23/+31 |
| | | | | + Cleaned up code. | ||||
* | + Updated comments. | Jennifer Averett | 1999-11-22 | 1 | -9/+20 |
| | | | | + Corrected enable/disable of dispatch. | ||||
* | + Corrected bug in error check. | Jennifer Averett | 1999-11-22 | 1 | -2/+1 |
* | + Added description of routine to comment. | Jennifer Averett | 1999-11-22 | 1 | -0/+4 |
* | + Corrected error processing code. | Jennifer Averett | 1999-11-22 | 1 | -14/+15 |
* | + Added checks for NULL and NULL string names (for sem_open & sem_unlink). | Jennifer Averett | 1999-11-22 | 1 | -1/+7 |
* | + Cleaned up comments. | Jennifer Averett | 1999-11-22 | 1 | -6/+16 |
* | + Corrected error messages. | Jennifer Averett | 1999-11-22 | 1 | -30/+80 |
| | | | | | | | | + Added tests for sem_open, sem_close, and sem_unlink. + Yellow lined sem_open, sem_close, sem_unlink, _POSIX_Semaphore_Delete, _POSIX_Semaphore_Name_to_id, and _POSIX_Semaphore_Create_support. Except for MP, pshared OBJECT_REMOTE, and out of memory paths. | ||||
* | Added ifndef around build_time macro so tmacros.h and pmacros.h | Joel Sherrill | 1999-11-22 | 2 | -0/+4 |
| | | | | can be included from the same file. | ||||
* | Use PGM consistently. | Joel Sherrill | 1999-11-22 | 2 | -3/+3 |
* | Made it agree on PGM versus PGM/PGMS. | Joel Sherrill | 1999-11-22 | 3 | -3/+3 |
* | Changed name of W, X, and Y macros for fields in the Clock | Joel Sherrill | 1999-11-22 | 1 | -9/+9 |
| | | | | Synthesizer Control Register to remove use of single letter names. |
