path: root/c (unfollow)
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill11-11/+17
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * debug_ada/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * debug_c/Makefile.am: Remove AUTOMAKE_OPTIONS. * dos_sup/Makefile.am: Remove AUTOMAKE_OPTIONS. * network_ada/adasockets/Makefile.am: Remove AUTOMAKE_OPTIONS. * network_ada/Makefile.am: Remove AUTOMAKE_OPTIONS. * network_ada/listener/Makefile.am: Remove AUTOMAKE_OPTIONS. * network_ada/tcprelay/Makefile.am: Remove AUTOMAKE_OPTIONS. * ts_1325_ada/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill6-5/+8
* comm/Makefile.am: Remove AUTOMAKE_OPTIONS. * io/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * irq/Makefile.am: Remove AUTOMAKE_OPTIONS. * pci/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill13-13/+19
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * 3c509/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * ne2000/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * wd8003/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill9-9/+15
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * shmsupp/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * tty/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill4-4/+10
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill22-22/+34
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * irq/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill4-3/+6
* comm/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * irq/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill8-8/+14
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-272002-03-27 Thomas.Doerfler@imd-systems.deJoel Sherrill4-18/+92
* PR144 * nfs/bootp_subr.c bootpc_init(): Performs a write to memory address 0 when called for the first time. This is done when trying to clear the variable "dhcp_hostname".
2002-03-272002-03-27 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill8-26/+52
* PR162 * net/if_ppp.c ppp_txdaemon(), net/if_pppvar.h pppstart(): Local variables must not be used in a device write routines. Now ppp_softc structure have own character for writing to device (sc_outchar). I think that converting local variables to static is not a right solution, because problems will occur in the case of two or more ppp instances. * net/ppp_tty.c pppstart(): Type of the ioffset variable must be u_long, otherwise in the case of the big output packet endless loop may occur.
2002-03-212001-03-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-10/+0
* ChangeLog: Undo incorrect addition of entry.
2002-03-212002-03-21 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill8-32/+96
* net/if_ppp.c, net/ppp_tty.c: Initial preparations for multiple PPPD connections.
2002-03-212002-03-21 Alexander Kukuta <kam@oktet.ru>Joel Sherrill6-1220/+778
* src/bdbuf.c (avl_insert, avl_remove): Reimplemented from scratch to avoid using GPLed sources in RTEMS core. * src/bdbuf.c, include/rtems/bdbuf.h: Remove "binary tree" implementation which was used for debugging only.
2002-03-202001-03-20 Till Straumann <strauman@SLAC.Stanford.EDU>Joel Sherrill6-4/+70
* PR158 * libc/rcmd.c, libc/rcmd.c: Enable the rcmd() library call by commenting out the parts that deal with signals. This enables RTEMS to 'rsh' command to a server connecting fd to remote stdio. The 'server-side' parts of this file which deal with authentication are disabled since they are not needed.
2002-03-202002-03-20 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2-0/+11
* cpu_asm.S: Now compiles on 4600 and 4650.
2002-03-202001-03-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-2/+8
* PR143 * lib/include/rtems/termiostypes.h: Removed unneeded volatile on "theBuf" since no byte is read more than once anyway.
2002-03-202002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill3-2/+9
* PR145. * sp04/task1.c, sp04/tswitch.c: Test fails if other tasks present in system (e.g. driver tasks). Also exit on minimum number of switches not precise number.
2002-03-202002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill2-0/+10
* PR148. * monitor/mon-prmisc.c: Fixed to print task states correctly.
2002-03-202002-03-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill4-3/+11
PR 149 * src/i386/any/Makefile.am: s/$(SED)/sed/. * src/m68k/any/Makefile.am: s/$(SED)/sed/. * src/powerpc/new_exception_processing/Makefile.am: s/$(SED)/sed/. (Reported by Till Straumann <strauman@SLAC.Stanford.EDU>)
2002-03-202002-03-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill10-10/+40
Addressing PR 140. * src/dosfs/config.h.in: Removed. * src/dosfs/stamp-h2.in: Removed. * .cvsignore: Add config.h*, stamp-h*. * configure.ac: Remove AC_SRC_DIR(.../dosfs.h). Remove AM_CONFIG_HEADER(src/dosfs/config.h). Remove AM_CONFIG_HEADER(src/imfs/config.h). Add AM_CONFIG_HEADER(config.h). * src/dosfs/Makefile.am: INCLUDES = -I../.. . * src/imfs/Makefile.am: INCLUDES = -I../.. .
2002-03-202002-03-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-2/+7
* PR139 * configure.ac: Remove stray ';', breaks building with automake-1.6.
2002-03-202002-03-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill4-2/+10
* configure.ac: Remove stray ';', PR 139.
2002-03-202002-03-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-4/+11
* cpuModel.h: PR 146. Adding guards. Remove unnecessary headers.
2002-03-152002-03-13 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill3-24/+42
* cpu_asm.S: Fixed a sneaky return from int w/ ints disabled bug. * rtems/score/cpu.h: Fixed register numbering in comments and made interrupt enable/disable more robust.
2002-03-152002-03-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill6-80/+48
Reported and tracked as PR130. * src/dosfs/Makefile.am: Reworked, Disable dosfs for UNIX. * wrapup/Makefile.am: Disable dosfs for UNIX.
2002-03-152001-03-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill6-120/+186
* src/extension.c: Split to reduce minimum code size per PR134. * src/extensioncreate.c, src/extensiondelete.c, src/extensionident.c: New files. src/Makefile.am: Modified to reflect above.
2002-03-152002-03-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-3/+17
* configure.ac: Special treatment of the bare BSP. Add RTEMS_BSP_ALIAS. Add HAS_LIBBSP. * Makefile.am: Append libbsp.a to SRC conditionally.
2002-03-152002-03-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+5
* rtems/score/m68k.h: m68k_swap_u32 fix typo.
2002-03-082001-03-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-5/+8
* mips-stub.c: Removed warnings.
2002-03-082001-03-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-1/+6
* start/start.S, startup/bspstart.c: Removed warnings.
2002-03-082002-03-05 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill3-0/+17
* shared/interrupts/installisrentries.c: Added support for debug exception vector. * shared/interrupts/isr_entries.S: Added support for debug exception vector.
2002-03-082001-03-05 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill7-753/+1341
* mips-stub.c: Debugged & tweaked the gdb command processing, zbreak stuff, breakpoint and step code. Implemented 'T' command support and debugged remote gdb support w/ the Mongoose bsp. Added the memory segment support. * memlimits.h: Disabled all contents in favor of memory sement support. This file could probably go away. * rtems-stub-glue.c (rtems_gdb_index_to_stub_id()): New routine. rtems_gdb_stub_get_register_from_context(): Implemented MIPS version. rtems_gdb_stub_get_offsets(): Implemented MIPS version. * README: Updated.
2002-03-082002-03-05 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill3-6/+53
* startup/gdb-support.c: Added calls into the mips-support gdb stub for configuring the memory regions. Any bsp that wants to use the gdbstub will need to do something similar. * startup/Makefile.am: Added shared/gdbstub directory to include path.
2002-03-082002-03-05 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill6-49/+268
* cpu_asm.S: Added support for the debug exception vector, cleaned up the exception processing & exception return stuff. Re-added EPC in the task context structure so the gdb stub will know where a thread is executing. Should've left it there in the first place... * idtcpu.h: Added support for the debug exception vector. * cpu.c: Added ___exceptionTaskStack to hold a pointer to the stack frame in an interrupt so context switch code can get the userspace EPC when scheduling. * rtems/score/cpu.h: Re-added EPC to the task context.
2002-03-062002-03-06 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2-0/+39
* rtems/score/m68k.h [M68K_COLDFIRE_ARCH] (CPU_swap_u16, CPU_swap_u32): Generic implementation of endian swap primitives added for Coldfire family.
2002-03-012002-03-01 Eric Norum <eric.norum@usask.ca>Joel Sherrill2-7/+15
* src/pthreadonce.c: Task is not preemptable while running a pthread_once init function. This is slightly less heavy handed than disabling dispatching and seems better than consuming a mutex.
2002-03-012002-03-01 Eric Norum <eric.norum@usask.ca>Joel Sherrill3-20/+24
* libc/gxx_wrappers.c: Task is not preemptable while running a pthread_once init function. This is slightly less heavy handed than disabling dispatching and seems better than consuming a mutex.
2002-03-012002-02-27 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2-3/+9
* mongoosev/include/mongoose-v.h: Added cache constants. * mongoosev/vectorisrs/vectorisrs.c: More tinkering to improve performance.
2002-03-012002-02-27 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill1-0/+5
2002-03-012001-03-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-2/+5
* ChangeLog: Corrected previous entry.
2002-03-012002-02-27 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2-23/+55
* shared/gdbstub/README: Added text. * shared/gdbstub/mips-stub.c: Modified isr install routine to capture all exceptions.
2002-03-012002-02-27 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill7-135/+444
* start/start.S: Added kseg1 test to enable cache flush code * bsp_specs: Added -qnostartfile to disable including bsp's start.o * startup/bspstart.c: Made clear_cache actually work, tweaked cpu init to only turn on whats needed. * startup/gdb-support.c: Added calls to uart 2 for gdb stub I/O and a handy init function.
2002-03-012002-02-27 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill6-124/+281
* cpu_asm.S: Fixed exception return address, modified FP context switch so FPU is properly enabled and also doesn't screw up the exception FP handling. * idtcpu.h: Added C0_TAR, the MIPS target address register used for returning from exceptions. * iregdef.h: Added R_TAR to the stack frame so the target address can be saved on a per-exception basis. The new entry is past the end of the frame gdb cares about, so doesn't affect gdb or cpu.h stuff. * rtems/score/cpu.h: added an #ifdef so cpu_asm.S can include it to obtain FPU defines without systax errors generated by the C defintions. * cpu.c: Improved interrupt level saves & restores.
2002-03-012001-03-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-0/+10
* src/imfs/.cvsignore: Added stamp-h1.in
2002-02-282002-02-28 Mike Panetta <ahuitzot@mindspring.com>Joel Sherrill15-609/+2333
* console/sci.c, console/sci.h, console/console.c: Added new SCI driver. * start/start.c: Removed file. * start/start.S: New file, the asm portion of the updated start code. * start/configure.am: Added start.S, removed start.c * startup/start_c.c: New file, the C portion of the updated start code. Contains most of the code that was in the old start.c. * startup/configure.am: Added start_c.c to C_FILES. * include/bsp.h: Added include <rtems/bspIo.h>
2002-02-282002-02-28 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2-0/+6
* DOS filesystem including FAT12, FAT16, and FAT32 support submitted. * Makefile.am: Modified to reflect addition.
* DOS filesystem including FAT12, FAT16, and FAT32 support submitted. * configure.ac: Modified to reflect addition.
2002-02-282002-02-28 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill56-4/+13329
* DOS filesystem including FAT12, FAT16, and FAT32 support submitted. * src/dosfs, src/dosfs/Makefile.am, src/dosfs/stamp-h2.in, src/dosfs/config.h.in, src/dosfs/dosfs.h, src/dosfs/fat.c, src/dosfs/fat.h, src/dosfs/fat_fat_operations.c, src/dosfs/fat_fat_operations.h, src/dosfs/fat_file.c, src/dosfs/fat_file.h, src/dosfs/msdos.h, src/dosfs/msdos_create.c, src/dosfs/msdos_dir.c, src/dosfs/msdos_eval.c, src/dosfs/msdos_file.c, src/dosfs/msdos_free.c, src/dosfs/msdos_fsunmount.c, src/dosfs/msdos_handlers_dir.c, src/dosfs/msdos_handlers_file.c, src/dosfs/msdos_init.c, src/dosfs/msdos_initsupp.c, src/dosfs/msdos_misc.c, src/dosfs/msdos_mknod.c, src/dosfs/msdos_node_type.c, src/dosfs/.cvsignore: New files. * configure.ac, src/Makefile.am, wrapup/Makefile.am: Modified to reflect addition.
2002-02-282002-02-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill36-0/+7642
* Submitted by Victor V. Vengerov <vvv@oktet.ru> and merged into the RTEMS source. * ChangeLog, Makefile.am, README, configure.ac, include/Makefile.am, include/rtems/bdbuf.h, include/rtems/blkdev.h, include/rtems/diskdevs.h, include/rtems/ramdisk.h, include/rtems/.cvsignore, include/.cvsignore, src/Makefile.am, src/bdbuf.c, src/blkdev.c, src/diskdevs.c, src/ramdisk.c, src/.cvsignore, .cvsignore: New files.
