* mpc8260/clock/clock.c, mpc8260/console-generic/console-generic.c:
Add missing prototypes.
* clock/p_clock.c, console/console.c, irq/irq.c, irq/irq_init.c,
vectors/vectors_init.c: Add missing prototypes.
* shared/showbats.c, shared/console/inch.c, shared/irq/irq_init.c,
shared/pci/detect_raven_bridge.c, shared/startup/bspstart.c,
shared/startup/zerobss.c, shared/vme/vmeconfig.c,
startup/exit.c: Add missing prototypes.
* clock/p_clock.c, irq/irq.c, irq/irq_init.c, vectors/vectors_init.c:
* startup/bspclean.c, startup/sd-card-init.c, tests/tests.c:
* clock/clock.c, irq/irq_init.c, vectors/vectors.h,
* mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c,
ppc403/timer/timer.c, shared/src/cache.c: Add missing prototypes.
* console/mc68360_scc.c, console/rsPMCQ1.c, console/rsPMCQ1.h,
irq/irq_init.c, pci/no_host_bridge.c, startup/bspstart.c:
* irq/irq.c, irq/irq_init.c, startup/bspstart.c:
* libchip/display/disp_hcms29xx.c: Initialize softc_ptr to NULL.
* libchip/network/dec21140.c, libchip/network/if_dc.c: Use uint32_t.
* console/ps2_mouse.c: Fix ps2 mouse interrupt.
* shared/comm/i386-stub.c, shared/irq/irq_init.c: Fix warnings for
prototypes, types, etc.
* clock/ckinit.c, console/serial_mouse.c, ne2000/ne2000.c,
startup/bspstart.c: Fix warnings for prototypes, types, etc.
* bin2boot.c: Fix uninitialized variable warning.
* m68040/fpsp/rtems_fpsp.c: Move extern outside of braces.
* clock/clock.c: Move extern outside of braces.
* libchip/display/disp_hcms29xx.c: Do not make these static. They
appear to be unused that way.
* startup/bspstart.c, startup/init5282.c: Fixed warnings.
* dswifi/arm7/makefile, dswifi/include/netinet/in.h,
libnds/basicARM7/source/defaultARM7.c, libnds/include/gbfs.h,
libnds/include/nds/bios.h, libnds/include/nds/card.h,
libnds/include/nds/dma.h, libnds/include/nds/interrupts.h,
libnds/include/nds/ipc.h, libnds/include/nds/jtypes.h,
libnds/include/nds/registers_alt.h, libnds/include/nds/system.h,
libnds/include/nds/timers.h, libnds/include/nds/arm7/audio.h,
libnds/include/nds/arm7/clock.h, libnds/include/nds/arm7/serial.h,
libnds/include/nds/arm7/touch.h, libnds/include/nds/arm9/boxtest.h,
libnds/include/nds/arm9/cache.h, libnds/include/nds/arm9/console.h,
libnds/include/nds/arm9/ndsmotion.h, libnds/include/nds/arm9/video.h,
libnds/include/nds/arm9/videoGL.h, libnds/source/arm7/audio.c,
libnds/source/arm7/clock.c, libnds/source/arm7/microphone.c,
libnds/source/arm7/touch.c, libnds/source/arm7/userSettings.c,
libnds/source/arm9/boxtest.c, libnds/source/arm9/gurumeditation.c,
libnds/source/arm9/ndsmotion.c, libnds/source/arm9/videoGL.c,
libnds/source/common/card.c,
libnds/source/common/interruptDispatcher.S, touchscreen/reco.c: Fix
various warnings by fixing prototypes. Remove unused .bin files.
Convert all files to UNIX CF/LF.
* libnds/source/arm9/COS.bin, libnds/source/arm9/SIN.bin,
libnds/source/arm9/TAN.bin, libnds/source/arm9/default_font.bin: Removed.
* bin2s.c: Fix various warnings by fixing prototypes. Remove unused
.bin files. Convert all files to UNIX CF/LF.
* startup/bspstart.c: Fixed nested extern declarations.
* libchip/shmdr/shm_driver.h: Correct prototypes.
* sh7032/timer/timer.c, sh7045/timer/timer.c, sh7750/timer/timer.c:
* trap34/console-io.c: Add missing prototypes.
* shared/m68kbspgetworkarea.c: Move extern of global symbols from
linkcmds outside function.
* timerstub.c: Add missing prototypes.
* startup/__main.c: Add missing prototypes.
* include/bootcard.h, bootcard.c, bsplibc.c: Changed parameter types of
bsp_libc_init() to match RTEMS_Malloc_Initialize().
* bsppost.c, bsppredriverhook.c: Include bootcard.h.
* src/irq-generic.c: Fixed warnings.
* shared/clock/clock.c: Fixed warnings.
* include/bsp.h, network/network.c, spi/spi_init.c, startup/cpuinit.c,
startup/uboot_support.c: Fixed warnings.
* libchip/display/disp_hcms29xx.c: Fixed warnings. Initialized
variables and made methods static.
* startup/init5235.c: Add missing prototypes.
* startup/init5206e.c: Add missing prototypes.
* startup/bspstart.c: Add missing prototypes.
* clock/clock.c, startup/init5329.c: Add missing prototypes.
* startup/init5272.c: Add missing prototypes.
* startup/init5282.c: Add missing prototypes.
* clock/clock.c, startup/init52235.c: Add missing prototypes.
