- Port the jbang code from C++ to C to enable DBGEN.
- Hook the libdebugger ARM backend support to return the base address
of the debug register set.
This fixes the corruption of r3 by the call to
bsp_start_arm_drop_hyp_mode().
Moving the code makes it easier to review changes in start.S.
Close #3773.
This makes it easier to review changes in start.S.
Update #3773.
- Allow the RTEMS_ROOT to be conditionally supplied. This
can be a staging area before being moved to the final
install prefix location.
- Update the default.cfg to use RTEMS_ROOT and to not rely on
the exec_prefix so it's paths can be staged.
- Fix and add the needed configure subs.
Closes #3768
controller support.
Update #3269.
Update #3725.
Remove this BSP option.
Modifications to get xilinx-zynqmp BSP working on an Ultra96 board.
Update #3682.
Source files were copied from xilinx-zynq.
Update #3682.
This driver will be shared with the xilinx-zynqmp BSP.
Update #3682.
Change license to BSD-2-Clause.
Close #3725.
This gets rid of a special include path.
Update #3678.
Update #3678.
Close #3667.
Update #3254.
In order to simplify the use of CPU counter values it is beneficial to
have monotonic increasing values within the range of the CPU counter
ticks data type, e.g. 32-bit unsigned integer. This eases the use of
CPU counter timestamps in external tools which do not know the details
of the CPU counter hardware. The CPU counter is the fastest way to get
a time on an RTEMS system.
Such a CPU counter may be also used as the timecounter. Use it on SPARC
for this purpose to simplify the clock drivers.
Update #3456.
Update #3459.
Move start.o to separate file.
Update #3459.
Update #3599.
Avoid dependencies on the Termios support in case only printk() is used
by the application.
x86_64 is 64-bits and too new for the legacy stack to support.
epiphany is a small target and cannot compile the legacy (or new) stack.
Close #3375.
Update #3375.
Update #3525.
This is needed for building rtems correctly with Clang.
Note that this change does not mean rtems can build correctly with
mainline clang. However the change allows building rtems with a
Clang toolchain that has a rtems frontend similar that of GCC's
builtin rtems specs.
Close #3513.
Update #3513.
Remove the BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN hack. The interrupt
stacks are now allocated by the linker.
Update #3459.
The APIC timer is calibrated by running the i8254 PIT for a fraction of a
second (determined by PIT_CALIBRATE_DIVIDER) and counting how many times the
APIC counter has ticked. The calibration can be run multiple times (determined
by APIC_TIMER_NUM_CALIBRATIONS) and averaged out.
Updates #2898.
Updates #2898.
Updates #2898.
This reduces the link-time dependencies and avoids copy-and-paste.
The genmcf548x partly uses is own implementation of the interrupt
extension API for libbsd support.
Update #3285.
Update #3433.
Update #3433.
Update #3433.
The HTIF is a legacy machinery.
Update #3433.
Remove _CPU_ISR_install_raw_handler() and _CPU_ISR_install_vector()
functions. Applications can install an exception handler via the fatal
error handler to handle synchronous exceptions.
Handle interrupt exceptions via _RISCV_Interrupt_dispatch() which must
be provided by the BSP.
Update #3433.
This addition allows us to successfully run the sample hello.exe test.
Updates #2898.
Current state:
- Basic context initialization and switching code.
- Stubbed console (empty functions).
- Mostly functional linker script (may need tweaks if we ever want to move
away from the large code model (see: CPU_CFLAGS).
- Fully functional boot, by using FreeBSD's bootloader to load RTEMS's ELF for
UEFI-awareness.
In short, the current state with this commit lets us boot, go through the system
initialization functions, and then call user application's Init task too.
Updates #2898.
Update #3433.
