* comm/tty_drv.c, comm/uart.c, comm/uart.h: Adds the capability
to use task driven serial I/O to ti386 BSPs. This patch leaves thex
default I/O mode to be IRQ. If you want to use task I/O mode,
then the tty_drv.c file needs to be modified. Basically, all
you need to change is the data values of the termios callbacks
structure. This callback structure is used in the tty1_open
and tty2_open functions. The values you need to set are commented
out in the source code.
* cpu.c: Fixed typo.
* console/Makefile.am: Remove RTEMS_H_FILES.
* start/start16.S: include <bspopts.h> to get NEW_GAS.
* scitab/Makefile.am: Use @CPU_CLOCK_RATE_HZ@.
* comm/Makefile.am: Use *_HEADERS instead of *H_FILES.
* io/Makefile.am: Ditto.
* irq/Makefile.am: Ditto.
* pci/Makefile.am: Ditto.
* 3c509/Makefile.am: Dito.
* console/Makefile.am: Dito.
* start/start.S: Reverse sense of conditional compilation so the
code will compile for a cpu32.
* include/Makefile.am: Fixed typo.
* scitab/Makefile.am, startup/Makefile.am: Use CPU_CLOCK_RATE_HZ as
it is called in configure.in instead of HZ.
* configure.in: Correct typo.
* rtems_servers/Makefile.am: Deleted blank lines.
* consolex/Makefile.am: Ditto.
* include/Makefile.am: Fix typo in include_HEADERS.
* cdtest/system.h: Removed configure of POSIX mutexes since
there do not appear to be any used in this test.
* rtems_servers/telnetd.c, shell/telnetd.h: Moved from libmisc/shell
so the network stack to address network depenendency.
* rtems_servers/Makefile.am: Modified to reflect above.
* shell/telnetd.c, shell/telnetd.h: Moved to
libnetworking/rtems_servers so the network stack to address network
depenendency.
* shell/Makefile.am: Modified to reflect above.
* configure.in: Remove CONSOLE_USE_POLLED, HAS_RTC.
* configure.in: Add bspopts.h, fix PACKAGE.
* include/.cvsignore: Add bspopts.h*, stamp-h*, coverhd.h.
* mpc8xx/console-generic/console-generic.c:
The printk/printf did not work when loaded by EPPCBUG. They did
work when loaded with the BDM debugger. I suspected EPPBUG
made some nasty things like patching Communication processor
microcode... Anyway, the attached patch:
1) Enables to have printk nearly immediately after boot,
2) Make printf work automagically (I do not know why except I make a
different initialization for printk that should be overwritten by
console init later ?)
I let the default to be using EPPCBUG embedded firmware to boot and
using this printk early enabler code (LOADED_BY_EPPCBUG and
EARLY_CONSOLE) are on.
* console/console.c, include/commproc.h, startup/start.S:
* shell/cmds.c: Removed code from inappropriate source.
* clock/Makefile.am, console/Makefile.am, spurious/Makefile.am,
wrapup/Makefile.am: Modified to include compile.am.
* startup/bspstart.c: Removed include of <libcsupport.h>
* macros/rtems/score/coresem.inl, inline/rtems/score/coresem.inl:
Cut and paste problem incorrectly enabled interrupts twice with
the first time being too early.
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*.
* include/Makefile.am: Use *_HEADERS instead of *H_FILES, add
bspopts.h.
* include/.cvsignore: Add bspopts.h.
* include/bsp.h: Add bspopts.h.
* console/Makefile.am: Use *_HEADERS instead of H_FILES.
* TESTED: Corrected the name of the MRM332 BSP.
* .cvsignore, ChangeLog Makefile.am, README, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in,
console/.cvsignore, console/Makefile.am, console/console.c,
include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c,
spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c,
start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM,
timer/.cvsignore, timer/Makefile.am, timer/timer.c, times,
wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
* TESTED: Updated the list of BSPs.
* TOOLS_TARGETS: Updated the list of tools and object formats.
* src/imfs/imfs_initsupp.c: Create the root node with the
desired permissions. Nodes should be created with the right
permissions because chmod() is not supported by the miniIMFS
so changing after creation is not possible.
* libc/base_fs.c: Deleted chmod() now that IMFS creates the
root node with the desired permissions. chmod() is also not
supported by the miniIMFS so this is not allowable.
* Added once version of psxchroot01 test for user review.
* psxchroot01: New directory.
* psxchroot01/Makefile.am, psxchroot01/main.c, psxchroot01/test.c,
psxchroot01/psxchroot01.scn, psxchroot01/.cvsignore: New files.
* configure.in, Makefile.am: Modified to reflect above.
* include/rtems/libio_.h: Added login name, uid, gid, euid, and egid
so they can be part of the private environment.
* monitor/mon-prmisc.c: Correct print line.
* shell/Makefile.am: Added new file telnetd.c.
* shell/telnetd.c, shell/telnetd.h, shell/pty.c: New files.
* shell/shell.c, shell/cmds.c, shell/shell.h: Numerous improvments:
- The shell_init has a new parameter 'forever' because in
/dev/console you need that this process runs forever but in
tcp/ip not. (respawn?)
- A new task for every session opened trought tcp/ip telnet client.
(the chargen,daytime and more are possible of implementation but
I ask me if they are necesary)
- Exit from the session delete the task and when the client fails too.
- More cmds have been implemented. (very reduced version of these)
umask, chmod, id, whoami, rm, cat, ...
- A reduced line edit has been implemented.
Ctrl-C abort the input,
Ctrl-d in the first position gives EOF (logout).
'\b' and DEL makes the rubout operation.
I think that readline() for every session spents a lot of resources.
* libc/ttyname.c (ttyname_r): Removed duplicate call to closedir().
* libc/getpwent.c: Create a more robust /etc/passwd and /etc/group.
* libc/base_fs.c: Change permissions of files and directories. Now uses
octal constants.
* src/getegid.c, src/geteuid.c, src/getgid.c, src/getlogin.c,
src/getuid.c: Now save their values in private user environment.
* start/start.S: Increased BAT0 mapping of RAM from 64 meg to
256 meg to allow operation on boards with larger RAM sizes.
* vectors/vectors_init.c: Modified to call 'generic' powerpc
vector function (mpc60x_vector_is_valid) instead of MPC750
specific function to allow operation on boards with CPUs other
than the MPC750.
* mpc6xx/timer/timer.c: Added include of bsp.h and removed
external declaration of BSP_Convert_decrementer() to
correct unresolved reference to this routine.
* mpc8xx/console-generic/console-generic.c: Bug found by Yacine
<elkolli@crf.canon.fr> where the initialization or irq data structure
was incomplete in case a SMC channel was used first and later a SCC one.
* start/Makefile.am: Dito.
* network/Makefile.am: Dito.
