2000-06-14 | Patch rtems-rc-20000614-sh.tar.gz from Ralf Corsepius | Joel Sherrill | 35 | -1892/+198 | |
<corsepiu@faw.uni-ulm.de> that migrates the SH port to multilib'ing. This patch involved moving a number of files in the CVS repository, adding new files, and deleting files from their previous location. Ralf gave good instructions (not repeated here) and here are his notes: Note 1: In this version, I did not change the installation points of the headers which are moved inside of the source-tree. This is a temporary hack for not breaking compatibility with 4.5 based BSPs, but will probably not last once having real multilibs (We would have include file conflicts when several BSPs/CPU_MODELS share a common installation prefix). Note 2: I hope not to have broken too much, but I would not be astonished if something goes wrong. Note 3: There are more patches to come :) | |||||
2000-06-14 | Moved PowerPC cache management code to libcpu. Also compiled | Joel Sherrill | 11 | -359/+55 | |
mpc8xx libcpu support for the first time and remove includes of bsp.h, references to BSP_Configuration, and Cpu_table. All of these can be obtained directly from RTEMS now. | |||||
2000-06-14 | Must now pull in cache management code from libcpu. | Joel Sherrill | 4 | -2/+6 | |
2000-06-14 | Removed alloc860.c and mmu.c from C_FILES since they are now in libcpu. | Joel Sherrill | 1 | -2/+2 | |
2000-06-14 | Do not build if networking disabled. | Joel Sherrill | 1 | -0/+2 | |
2000-06-14 | Removed building of libcpu.a. It is now the individual BSPs | Joel Sherrill | 4 | -8/+14 | |
responsibility to explicitly pick up the components they require. This makes it easier to override default implmentations. | |||||
2000-06-14 | Thread iterate not ready for submission -- removed. | Joel Sherrill | 1 | -1/+1 | |
2000-06-14 | Moved to include subdirectory. | Joel Sherrill | 1 | -99/+0 | |
2000-06-14 | New files containing cache manager functionality stripped from | Joel Sherrill | 3 | -0/+220 | |
score/cpu/powerpc. | |||||
2000-06-14 | New file. | Joel Sherrill | 2 | -0/+4 | |
2000-06-14 | Functionality moved from directory above to accomodate building | Joel Sherrill | 9 | -0/+1255 | |
shared source code. | |||||
2000-06-14 | Moved from score/cpu/PowerPC. | Joel Sherrill | 8 | -1150/+4 | |
2000-06-14 | Thread iterator and libgjc support submitted too early. | Joel Sherrill | 25 | -2025/+10 | |
2000-06-14 | Fix typo. | Joel Sherrill | 1 | -1/+1 | |
2000-06-13 | Added crude i960ka support. | Joel Sherrill | 3 | -6/+38 | |
2000-06-13 | Pickup console-polled.c from the libbsp/shared directory. | Joel Sherrill | 1 | -0/+2 | |
2000-06-13 | Removing clock and timer since this BSP does not currently | Joel Sherrill | 1 | -2/+0 | |
have them. | |||||
2000-06-13 | Prototypes for cache manager support functions now agree. | Joel Sherrill | 2 | -7/+3 | |
2000-06-13 | New file. | Joel Sherrill | 1 | -0/+137 | |
2000-06-13 | Moved i386 and m68k cache management code to libcpu. Everything | Joel Sherrill | 25 | -579/+605 | |
now is an implementation of the prototypes in rtems/rtems/cache.h. The libcpu/i386/wrapup directory is no longer needed. The PowerPC needs this done to it. | |||||
2000-06-13 | Added .cvsignore. | Joel Sherrill | 6 | -0/+12 | |
2000-06-13 | Added .cvsignore. | Joel Sherrill | 11 | -0/+33 | |
2000-06-13 | Added .cvsignore files. | Joel Sherrill | 2 | -0/+15 | |
2000-06-13 | Accounted for 1 task used. | Joel Sherrill | 1 | -0/+1 | |
2000-06-13 | Removed unused directories from Makefile.am and warnings | Joel Sherrill | 3 | -1/+17 | |
from cvs by adding .cvsignore files. | |||||
2000-06-13 | Temporary hack to compile. Need to probably address definition | Joel Sherrill | 3 | -0/+3 | |
of all FIO constants and conflict with libnetworking code. | |||||
2000-06-13 | Temporary hack to compile. | Joel Sherrill | 2 | -2/+0 | |
2000-06-12 | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 43 | -7762/+0 | |
<charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860. | |||||
2000-06-12 | Fixed so hppa1.1 compiles with only problems in simhppa BSP. | Joel Sherrill | 3 | -6/+16 | |
2000-06-12 | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 15 | -0/+1790 | |
<charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860 | |||||
2000-06-12 | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 102 | -470/+12509 | |
2000-06-12 | Ensure that when -msoft-float is specified for multilib builds, that | Joel Sherrill | 1 | -1/+2 | |
something indicates this. Eventually this needs to be merged into gcc. | |||||
2000-06-12 | Works on Solaris and Linux. | Joel Sherrill | 1 | -8/+6 | |
2000-06-12 | Removed references to printk as part of moving it to a more shareable | Joel Sherrill | 6 | -171/+6 | |
location in libc. | |||||
2000-06-12 | Added printk as a generic, shared routine. | Joel Sherrill | 7 | -3/+367 | |
2000-06-12 | New file. This is a simple termios console driver which is sufficient | Joel Sherrill | 1 | -0/+148 | |
to do polled IO on a single port with VERY little support code. | |||||
2000-06-12 | Added i960sim BSP which (ignoring the 3 instructions not supported | Joel Sherrill | 18 | -0/+641 | |
by gdb 5.0's i960 simulator) is enough to run hello world. | |||||
2000-06-12 | Merge lossage. Apparently the DOS/UNIX CRLF issue got lost. | Joel Sherrill | 1 | -1438/+1438 | |
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | 1431 | -10240/+81752 | |
2000-05-24 | New file. | Joel Sherrill | 1 | -0/+0 | |
2000-05-08 | New file added on 4.5 branch | Joel Sherrill | 2 | -0/+0 | |
2000-05-08 | New file added on 4.5 branch | Joel Sherrill | 1 | -0/+0 | |
2000-05-03 | Added on 4.5 branch. | Joel Sherrill | 4 | -0/+0 | |
2000-05-01 | Added on 4.5-branch | Joel Sherrill | 8 | -0/+0 | |
2000-04-29 | New files. | Joel Sherrill | 4 | -0/+8 | |
2000-04-29 | New files added as part of librpc upgrade. | Joel Sherrill | 28 | -0/+0 | |
2000-04-29 | New files added as part of librpc upgrade. | Joel Sherrill | 156 | -0/+0 | |
2000-04-29 | New directory added as part of librpc upgrade. | Joel Sherrill | 46 | -0/+0 | |
2000-04-28 | New files added on 4.5 branch. | Joel Sherrill | 4 | -0/+0 | |
2000-04-13 | New file. | Joel Sherrill | 1 | -0/+367 | |
