* aclocal/bsp-alias.m4: New (Copied from ../../../aclocal).
* aclocal/canonical-host.m4: New (Copied from ../../../aclocal).
* aclocal/canonicalize-tools.m4: New (Copied from ../../../aclocal).
* aclocal/canonical-target-name.m4: New (Copied from ../../../aclocal).
* aclocal/check-cpu.m4: New (Copied from ../../../aclocal).
* aclocal/check-custom-bsp.m4: New (Copied from ../../../aclocal).
* aclocal/check-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/check-itron.m4: New (Copied from ../../../aclocal).
* aclocal/check-multiprocessing.m4: New (Copied from ../../../aclocal).
* aclocal/check-networking.m4: New (Copied from ../../../aclocal).
* aclocal/check-posix.m4: New (Copied from ../../../aclocal).
* aclocal/check-tool.m4: New (Copied from ../../../aclocal).
* aclocal/config-subdirs.m4: New (Copied from ../../../aclocal).
* aclocal/enable-bare.m4: New (Copied from ../../../aclocal).
* aclocal/enable-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/enable-itron.m4: New (Copied from ../../../aclocal).
* aclocal/enable-multiprocessing.m4: New (Copied from ../../../aclocal).
* aclocal/enable-networking.m4: New (Copied from ../../../aclocal).
* aclocal/enable-posix.m4: New (Copied from ../../../aclocal).
* aclocal/enable-rtemsbsp.m4: New (Copied from ../../../aclocal).
* aclocal/enable-tests.m4: New (Copied from ../../../aclocal).
* aclocal/env-rtemsbsp.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-isystem.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-pipe.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-specs.m4: New (Copied from ../../../aclocal).
* aclocal/multilib.m4: New (Copied from ../../../aclocal).
* aclocal/path-ksh.m4: New (Copied from ../../../aclocal).
* aclocal/prog-cc.m4: New (Copied from ../../../aclocal).
* aclocal/prog-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/project-root.m4: New (Copied from ../../../aclocal).
* aclocal/quoting.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-flags.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-test-no-pause.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-top.m4: New (Copied from ../../../aclocal).
* aclocal/target.m4: New (Copied from ../../../aclocal).
* aclocal/tool-paths.m4: New (Copied from ../../../aclocal).
* aclocal/version.m4: New (Copied from ../../../aclocal).
* configure.ac: Remove stray comments.
* automake/local.am, automake/host.am: Remove "debug".
tm01/Makefile.am: Reflect having moved automake.
tm02/Makefile.am: Reflect having moved automake.
tm03/Makefile.am: Reflect having moved automake.
tm04/Makefile.am: Reflect having moved automake.
tm05/Makefile.am: Reflect having moved automake.
tm06/Makefile.am: Reflect having moved automake.
tm07/Makefile.am: Reflect having moved automake.
tm08/Makefile.am: Reflect having moved automake.
tm09/Makefile.am: Reflect having moved automake.
tm10/Makefile.am: Reflect having moved automake.
tm11/Makefile.am: Reflect having moved automake.
tm12/Makefile.am: Reflect having moved automake.
tm13/Makefile.am: Reflect having moved automake.
tm14/Makefile.am: Reflect having moved automake.
tm15/Makefile.am: Reflect having moved automake.
tm16/Makefile.am: Reflect having moved automake.
tm17/Makefile.am: Reflect having moved automake.
tm18/Makefile.am: Reflect having moved automake.
tm19/Makefile.am: Reflect having moved automake.
tm20/Makefile.am: Reflect having moved automake.
tm21/Makefile.am: Reflect having moved automake.
tm22/Makefile.am: Reflect having moved automake.
tm23/Makefile.am: Reflect having moved automake.
tm24/Makefile.am: Reflect having moved automake.
tm25/Makefile.am: Reflect having moved automake.
tm26/Makefile.am: Reflect having moved automake.
tm27/Makefile.am: Reflect having moved automake.
tm28/Makefile.am: Reflect having moved automake.
tm29/Makefile.am: Reflect having moved automake.
tmck/Makefile.am: Reflect having moved automake.
tmoverhd/Makefile.am: Reflect having moved automake.
tmitronsem01/Makefile.am: Reflect having moved automake.
sp01/Makefile.am: Reflect having moved automake.
sp02/Makefile.am: Reflect having moved automake.
sp03/Makefile.am: Reflect having moved automake.
sp04/Makefile.am: Reflect having moved automake.
sp05/Makefile.am: Reflect having moved automake.
sp06/Makefile.am: Reflect having moved automake.
sp07/Makefile.am: Reflect having moved automake.
sp08/Makefile.am: Reflect having moved automake.
sp09/Makefile.am: Reflect having moved automake.
sp11/Makefile.am: Reflect having moved automake.
sp12/Makefile.am: Reflect having moved automake.
sp13/Makefile.am: Reflect having moved automake.
sp14/Makefile.am: Reflect having moved automake.
sp15/Makefile.am: Reflect having moved automake.
sp16/Makefile.am: Reflect having moved automake.
sp17/Makefile.am: Reflect having moved automake.
sp19/Makefile.am: Reflect having moved automake.
sp20/Makefile.am: Reflect having moved automake.
sp21/Makefile.am: Reflect having moved automake.
sp22/Makefile.am: Reflect having moved automake.
sp23/Makefile.am: Reflect having moved automake.
sp24/Makefile.am: Reflect having moved automake.
sp25/Makefile.am: Reflect having moved automake.
sp26/Makefile.am: Reflect having moved automake.
sp27/Makefile.am: Reflect having moved automake.
sp28/Makefile.am: Reflect having moved automake.
sp29/Makefile.am: Reflect having moved automake.
sp30/Makefile.am: Reflect having moved automake.
sp31/Makefile.am: Reflect having moved automake.
sp32/Makefile.am: Reflect having moved automake.
spfatal/Makefile.am: Reflect having moved automake.
spsize/Makefile.am: Reflect having moved automake.
base_mp/Makefile.am: Reflect having moved automake.
base_mp/node1/Makefile.am: Reflect having moved automake.
base_mp/node2/Makefile.am: Reflect having moved automake.
base_sp/Makefile.am: Reflect having moved automake.
cdtest/Makefile.am: Reflect having moved automake.
fileio/Makefile.am: Reflect having moved automake.
hello/Makefile.am: Reflect having moved automake.
loopback/Makefile.am: Reflect having moved automake.
minimum/Makefile.am: Reflect having moved automake.
paranoia/Makefile.am: Reflect having moved automake.
pppd/Makefile.am: Reflect having moved automake.
ticker/Makefile.am: Reflect having moved automake.
unlimited/Makefile.am: Reflect having moved automake.
psx01/Makefile.am: Reflect having moved automake.
psx02/Makefile.am: Reflect having moved automake.
psx03/Makefile.am: Reflect having moved automake.
psx04/Makefile.am: Reflect having moved automake.
psx05/Makefile.am: Reflect having moved automake.
psx06/Makefile.am: Reflect having moved automake.
psx07/Makefile.am: Reflect having moved automake.
psx08/Makefile.am: Reflect having moved automake.
psx09/Makefile.am: Reflect having moved automake.
psx10/Makefile.am: Reflect having moved automake.
psx11/Makefile.am: Reflect having moved automake.
psx12/Makefile.am: Reflect having moved automake.
psx13/Makefile.am: Reflect having moved automake.
psxcancel/Makefile.am: Reflect having moved automake.
psxchroot01/Makefile.am: Reflect having moved automake.
psxfile01/Makefile.am: Reflect having moved automake.
psxhdrs/Makefile.am: Reflect having moved automake.
psxmount/Makefile.am: Reflect having moved automake.
psxmsgq01/Makefile.am: Reflect having moved automake.
psxreaddir/Makefile.am: Reflect having moved automake.
psxsem01/Makefile.am: Reflect having moved automake.
psxstat/Makefile.am: Reflect having moved automake.
psxtime/Makefile.am: Reflect having moved automake.
psxtimer/Makefile.am: Reflect having moved automake.
mp01/Makefile.am: Reflect having moved automake.
mp01/node1/Makefile.am: Reflect having moved automake.
mp01/node2/Makefile.am: Reflect having moved automake.
mp02/Makefile.am: Reflect having moved automake.
mp02/node1/Makefile.am: Reflect having moved automake.
mp02/node2/Makefile.am: Reflect having moved automake.
mp03/Makefile.am: Reflect having moved automake.
mp03/node1/Makefile.am: Reflect having moved automake.
mp03/node2/Makefile.am: Reflect having moved automake.
mp04/Makefile.am: Reflect having moved automake.
mp04/node1/Makefile.am: Reflect having moved automake.
mp04/node2/Makefile.am: Reflect having moved automake.
mp05/Makefile.am: Reflect having moved automake.
mp05/node1/Makefile.am: Reflect having moved automake.
mp05/node2/Makefile.am: Reflect having moved automake.
mp06/Makefile.am: Reflect having moved automake.
mp06/node1/Makefile.am: Reflect having moved automake.
mp06/node2/Makefile.am: Reflect having moved automake.
mp07/Makefile.am: Reflect having moved automake.
mp07/node1/Makefile.am: Reflect having moved automake.
mp07/node2/Makefile.am: Reflect having moved automake.
mp08/Makefile.am: Reflect having moved automake.
mp08/node1/Makefile.am: Reflect having moved automake.
mp08/node2/Makefile.am: Reflect having moved automake.
mp09/Makefile.am: Reflect having moved automake.
mp09/node1/Makefile.am: Reflect having moved automake.
mp09/node2/Makefile.am: Reflect having moved automake.
mp10/Makefile.am: Reflect having moved automake.
mp10/node1/Makefile.am: Reflect having moved automake.
mp10/node2/Makefile.am: Reflect having moved automake.
mp11/Makefile.am: Reflect having moved automake.
mp11/node1/Makefile.am: Reflect having moved automake.
mp11/node2/Makefile.am: Reflect having moved automake.
mp12/Makefile.am: Reflect having moved automake.
mp12/node1/Makefile.am: Reflect having moved automake.
mp12/node2/Makefile.am: Reflect having moved automake.
mp13/Makefile.am: Reflect having moved automake.
mp13/node1/Makefile.am: Reflect having moved automake.
mp13/node2/Makefile.am: Reflect having moved automake.
mp14/Makefile.am: Reflect having moved automake.
mp14/node1/Makefile.am: Reflect having moved automake.
mp14/node2/Makefile.am: Reflect having moved automake.
cpuuse/Makefile.am: Reflect having moved automake.
malloctest/Makefile.am: Reflect having moved automake.
monitor/Makefile.am: Reflect having moved automake.
putenvtest/Makefile.am: Reflect having moved automake.
rtems++/Makefile.am: Reflect having moved automake.
rtmonuse/Makefile.am: Reflect having moved automake.
stackchk/Makefile.am: Reflect having moved automake.
termios/Makefile.am: Reflect having moved automake.
itronhello/Makefile.am: Reflect having moved automake.
itronmbf01/Makefile.am: Reflect having moved automake.
itronmbox01/Makefile.am: Reflect having moved automake.
itrontask01/Makefile.am: Reflect having moved automake.
itrontask02/Makefile.am: Reflect having moved automake.
itrontask03/Makefile.am: Reflect having moved automake.
itrontask04/Makefile.am: Reflect having moved automake.
itrontime01/Makefile.am: Reflect having moved automake.
* automake/compile.am, automake/host.am, automake/leaf.am
automake/local.am, automake/subdirs.am: New (copied from
../../../automake).
tools/Makefile.am: Reflect having moved automake.
lib/Makefile.am: Reflect having moved automake.
support/Makefile.am: Reflect having moved automake.
debug_ada/Makefile.am: Reflect having moved automake.
debug_c/Makefile.am: Reflect having moved automake.
dos_sup/Makefile.am: Reflect having moved automake.
network_ada/Makefile.am: Reflect having moved automake.
network_ada/adasockets/Makefile.am: Reflect having moved automake.
network_ada/listener/Makefile.am: Reflect having moved automake.
network_ada/tcprelay/Makefile.am: Reflect having moved automake.
ts_1325_ada/Makefile.am: Reflect having moved automake.
shmdr/Makefile.am: Reflect having moved automake.
shmsupp/Makefile.am: Reflect having moved automake.
tty/Makefile.am: Reflect having moved automake.
comm/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
pci/Makefile.am: Reflect having moved automake.
3c509/Makefile.am: Reflect having moved automake.
ide/Makefile.am: Reflect having moved automake.
ne2000/Makefile.am: Reflect having moved automake.
wd8003/Makefile.am: Reflect having moved automake.
consolex/Makefile.am: Reflect having moved automake.
tod/Makefile.am: Reflect having moved automake.
spurious/Makefile.am: Reflect having moved automake.
i2c/Makefile.am: Reflect having moved automake.
nvram/Makefile.am: Reflect having moved automake.
bootloader/Makefile.am: Reflect having moved automake.
motorola/Makefile.am: Reflect having moved automake.
openpic/Makefile.am: Reflect having moved automake.
residual/Makefile.am: Reflect having moved automake.
vme/Makefile.am: Reflect having moved automake.
PCI_bus/Makefile.am: Reflect having moved automake.
universe/Makefile.am: Reflect having moved automake.
dlentry/Makefile.am: Reflect having moved automake.
flashentry/Makefile.am: Reflect having moved automake.
canbus/Makefile.am: Reflect having moved automake.
scv64/Makefile.am: Reflect having moved automake.
sonic/Makefile.am: Reflect having moved automake.
liblnk/Makefile.am: Reflect having moved automake.
gdbsci/Makefile.am: Reflect having moved automake.
scitab/Makefile.am: Reflect having moved automake.
trap34/Makefile.am: Reflect having moved automake.
hw_init/Makefile.am: Reflect having moved automake.
