* Makefile.am, README.IceCube, preinstall.am, include/bsp.h,
vectors/vectors.S: Rename EP5200 to IceCube since that is the
nickname for the Freescale evaluation board it is based upon. BSP was
tested on a Freescale MPC5200LITE.
* bsp.cfg.in: Hard-code HAS_RDBG = no.
* target.cfg.in: Hard-code RTEMS_HAS_RDBG = no.
* shared/start/start.S: Fix typo of pO versus p0.
* configure.ac, wrapup/Makefile.am: Remove RDBG.
* aclocal/check-rdbg.m4, aclocal/enable-rdbg.m4, librdbg/.cvsignore,
librdbg/Makefile.am, librdbg/preinstall.am,
librdbg/include/rdbg/rdbg.h, librdbg/include/rdbg/servrpc.h,
librdbg/include/rdbg/i386/rdbg_f.h, librdbg/include/rdbg/i386/reg.h,
librdbg/include/rdbg/m68k/rdbg_f.h, librdbg/include/rdbg/m68k/reg.h,
librdbg/include/rdbg/powerpc/rdbg_f.h,
librdbg/include/rdbg/powerpc/reg.h, librdbg/src/_servtgt.c,
librdbg/src/awk.svc, librdbg/src/excep.c, librdbg/src/ptrace.c,
librdbg/src/rdbg.c, librdbg/src/remdeb.x, librdbg/src/servbkpt.c,
librdbg/src/servcon.c, librdbg/src/servrpc.c, librdbg/src/servtgt.c,
librdbg/src/servtsp.c, librdbg/src/servutil.c,
librdbg/src/i386/excep_f.c, librdbg/src/i386/rdbg_cpu_asm.S,
librdbg/src/i386/rdbg_f.c, librdbg/src/i386/any/remdeb.h,
librdbg/src/i386/any/remdeb_f.x, librdbg/src/i386/any/remdeb_svc.c,
librdbg/src/i386/any/remdeb_xdr.c, librdbg/src/m68k/excep_f.c,
librdbg/src/m68k/rdbg_cpu_asm.S, librdbg/src/m68k/rdbg_f.c,
librdbg/src/m68k/any/remdeb.h, librdbg/src/m68k/any/remdeb_f.x,
librdbg/src/m68k/any/remdeb_svc.c, librdbg/src/m68k/any/remdeb_xdr.c,
librdbg/src/powerpc/excep_f.c, librdbg/src/powerpc/rdbg_cpu_asm.S,
librdbg/src/powerpc/rdbg_f.c,
librdbg/src/powerpc/new_exception_processing/remdeb.h,
librdbg/src/powerpc/new_exception_processing/remdeb_f.x,
librdbg/src/powerpc/new_exception_processing/remdeb_svc.c,
librdbg/src/powerpc/new_exception_processing/remdeb_xdr.c: Removed.
* configure.ac: Remove RDBG.
* debug_ada/cmds, debug_c/cmds: Remove RDBG.
* shared/startup/bspstart.c: Split out ShowBATS() so it can be shared
by more BSPs.
* shared/showbats.c: New file.
* ide/pcmcia_ide.c: Added prototype of mpc5200_pcmciaide_dma_blockop to
eliminate warning.
* Makefile.am: Add shared ShowBATS().
* startup/cpuinit.c: Split out BAT initialization into subroutine
that is defined based upon conditionals set. More critically
added code to detect and correct for a buggy U-Boot found on
some Freescale LITE5200B boards which report Flash memory to
be for 32MB at 0xFF000000 instead of 0xFE000000. If we use
the reported information, the system gives an exception just
after the BAT is programmed.
* vectors/vectors_init.c: Turn off message unless verbose is on.
* Makefile.am: ShowBATS() split out to helper routine so sharable by
more BSPs.
* Makefile.am, startup/bspstart.c: Use shared ShowBATS() method.
* Makefile.am, preinstall.am: You need main() to link all applications.
There is no C++ specific way to link currently.
PR 1249/build
* configure.ac: Jerry Needell <jerry.needell@unh.edu> reported that the
leon3 was left out of the cache enable logic. Thus the cache
management support code was empty on LEON3 CPUs.
* nfsclient/src/dirutils.c: Use PATH_MAX instead of MAXPATHLEN.
* wrapup/Makefile.am: Create archive from a file for hosts
with a limited command line size.
* wrapup/Makefile.am: Create archive from a file for hosts with
* nfsclient/src/rpcio.c: Use size_t instead of uint32_t for message
sizes.
* configure.ac: Add nfsclient.
* nfsclient/Makefile.am: New.
* nfsclient/proto/Makefile, nfsclient/Makefile,
nfsclient/src/Makefile: Remove.
* nfsclient/ChangeLog: Remove (Rename into ChangeLog.slac).
* nfsclient/ChangeLog.slac: New (Renamed from ChangeLog).
* nfsclient/README, nfsclient/proto/nfs_prot_xdr.c,
nfsclient/proto/mount_prot.x, nfsclient/proto/mount_prot_xdr.c,
nfsclient/proto/Makefile, nfsclient/proto/mount_prot.h,
nfsclient/proto/nfs_prot.h, nfsclient/proto/nfs_prot.x,
nfsclient/Makefile, nfsclient/ChangeLog, nfsclient/src/dirutils.c,
nfsclient/src/nfsTest.c, nfsclient/src/rpcio.h,
nfsclient/src/nfs.modini.c, nfsclient/src/xdr_mbuf.c,
nfsclient/src/cexphelp.c, nfsclient/src/Makefile,
nfsclient/src/sock_mbuf.c, nfsclient/src/nfs.c,
nfsclient/src/librtemsNfs.h, nfsclient/src/rpcio.modini.c
nfsclient/src/rpcio.c, nfsclient/rtems-filesystem-patch,
nfsclient/rfc1094.txt, nfsclient/LICENSE: Import from rtems-nfs-1.5.
which included commits to RCS files with non-trunk default branches.
* Makefile.am, preinstall.am, startup/linkcmds: Save the old linker
script as linkcmds.sim and use one with enough memory to link all
tests so we can at least build things.
* startup/linkcmds.sim: New file.
* Makefile.am, startup/main.c: Now can link with C compiler and not
require C++ compiler to link. The file rtems-ctor.cc is not being
built but if there is a need for C++ code to run on this BSP, then it
will have to be addressed. The simplest solution which might work is
to check the RTEMS system state before calling bsp_start() in main().
* start/preload.S: Fix symbolic reference. Did earlier modifications
change the conditionals specificed when this BSP is built?
* Makefile.am, vectors/vectors_init.c: Print stack trace on exception.
removed timed abort in ns16550.c transmit code
* Makefile.am, preinstall.am: Install a linkcmds all the time.
* startup/bspstart.c, startup/cpuinit.c,
startup/linkcmds.mpc8349eamds, startup/mpc83xx_regs.c: Add missing $Id$.
* startup/linkcmds: New file.
* Makefile.am: Correct so it now links.
* startup/linkcmds.brs5l: Add .jcr section.
* README.IceCube: New file.
* console/console.c: Fix typo accidentally introduced.
* network_5200/network.c: Fix warning.
* include/.cvsignore: New file.
* startup/linkcmds.ep5200: Add .jcr section.
* network/network.c: Removed warning.
