path: root/c (follow)
* 2001-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-186-9/+47
| | | | | | | * configure.ac: Add RTEMS_BSPOPTS*(CONSOLE_USE_INTERRUPTS). Add RTEMS_BSPOPTS*(SIMSPARC_FAST_IDLE). Remove RTEMS_OUTPUT_BUILD_SUBDIRS. * include/bsp.h: include bspopts.h.
* 2001-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-182-1/+23
| | | | | | | * configure.ac: Add RTEMS_BPSOPTS_*(CD2401_INT_LEVEL). Add RTEMS_BPSOPTS_*(CD2401_IO_MODE). Add RTEMS_BPSOPTS_*(CD2401_USE_TERMIOS). Add AC_DEFINE_UNQUOTED([mvme167]).
* 2001-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-182-1/+7
| | | | * configure.ac: Add RTEMS_BPSOPTS_* for ARM_RDI_MONITOR.
* 2001-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-183-11/+22
| | | | | | | * configure.ac: Add RTEMS_BSPOPTS_* for SERIAL_INPUT, HIF_INPUT, SERIAL_OUTPUT, HIF_OUTPUT. * console/console.c: Remove NO_BSP_INIT, SERIAL_INPUT, HIF_INPUT, SERIAL_OUTPUT, HIF_OUTPUT, add #include <bsp.h>.
* 2001-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-183-2/+7
| | | | | * asm.h: include cpuopts.h instead of targopts.h * rtems/score/arm.h: Use __arm__.
* 2001-12-07 Eric Norum <eric.norum@usask.ca>Joel Sherrill2001-12-074-12/+34
| | | | * lib/tftpDriver.c: Restore write capability.
* 2001-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-078-9/+18
| | | | * configure.ac: Remove RTEMS_ENABLE_NETWORKING.
* 2001-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-072-2/+4
* 2001-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-073-2/+8
* 2001-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-03104-364/+260
| | | | * configure.ac: Introduce RTEMS_BSP_CONFIGURE.
* 2001-11-30 Jennifer Averett <jennifer@OARcorp.com>Joel Sherrill2001-11-303-14/+51
| | | | | This was tracked as PR88. * libc/scandir.c: Fixed to perform cleanup on error conditions.
* 2001-11-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-292-1/+5
| | | | * configure.ac: Replace RTEMS_BSPOPTS_BSP with RTEMS_BSPOPTS_SET (typo).
* 2001-11-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-285-8/+17
| | | | | | | * include/Makefile.am: Use _HEADER instead of H_FILES. * irq/Makefile.am: Ditto. * openpic/Makefile.am: Ditto. * include/bsp.h: Include <bspopts.h>.
* 2001-11-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-282-0/+8
| | | | * Makefile.am: Add DIST_SUBDIRS.
* 2001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-284-35/+27
| | | | | | | | | This was tracked as PR91. * include/rtems/score/isr.h, inline/rtems/score/isr.inl, macros/rtems/score/isr.inl: Modified to allow any port to provide its own implementation of the macro _ISR_Is_in_progress. If the port overrides this macro, it must provide a non-inlined function implementation.
* 2001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-2812-528/+28
| | | | | | | | | This was tracked as PR87. * README, configure.ac, include/Makefile.am, include/bsp.h, start/start.S, startup/FPGA.c, startup/Makefile.am, tod/Makefile.am: Eliminated conditional code for generation 1 boards as these are no longer available. * include/gen1.h, startup/82378zb.c, tod/tod_g1.c: Deleted.
* 2001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-2832-0/+231
| | | | | | | This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation.
* 2001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-2816-22/+132
| | | | | | | | | | This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation. * rtems/score/c_isr.inl: Deleted and contents merged into cpu.c. * cpu.c: Received contents of c_isr.inl. * Makefile.am: Deleted reference to c_isr.inl.
* 2001-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-284-4/+8
| | | | * wrapup/Makefile.am: Remove HAS_IMFS.
* 2001-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-283-7/+6
| | | | | * ppc403/vectors/vectors.S: Include <bsp.h>. * shared/include/cpu.h: Remove stray empty lines.
* 2001-11-27 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-278-9/+59
| | | | | | | | This was tracked as PR39. * include/bsp.h, start/cpuboot.c, start/reset.S, startup/debugger, startup/linkcmds, startup/rom: Eliminated required definition of macros in the custom file for the BSP to compile. The ROM and ROM address and size settings are now linker script items.
* 2001-11-27 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-2719-5067/+18
| | | | | | | | | | | | | | | | | | * new_exception_processing/Makefile.in, new_exception_processing/.cvsignore, new_exception_processing/Makefile.am, new_exception_processing/c_isr.inl, new_exception_processing/cpu.c, new_exception_processing/cpu.h, new_exception_processing/cpu_asm.S, old_exception_processing/Makefile.in, old_exception_processing/.cvsignore, old_exception_processing/Makefile.am, old_exception_processing/README, old_exception_processing/TODO, old_exception_processing/c_isr.inl, old_exception_processing/cpu.c, old_exception_processing/cpu.h, old_exception_processing/cpu_asm.S, old_exception_processing/irq_stub.S, old_exception_processing/ppc_offs.h, old_exception_processing/ppccache.c, old_exception_processing/rtems.S: Deleted since now under libbsp.
* 2001-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-273-25/+7
| | | | | | * configure.ac: Remove old_exception_processing, new_exception_processing. * Makefile.am: Ditto.
* 2001-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-274-0/+30
| | | | | * configure.ac: Add RTEMS_BSPOPTS_*(DATA_CACHE_ENABLE), RTEMS_BSPOPTS_*(INSTRUCTION_CACHE_ENABLE).
* 2001-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-275-13/+36
| | | | | | | | | | | * Makefile.am: Remove . from SUBDIRS, remove duplicate bsp_specs rules, add @exceptions@ to SUBDIRS. * configure.ac: Add RTEMS_BSPOPTS_*(PPC_USE_SPRG), RTEMS_BSPOPTS_*(PPC_VECTOR_FILE_BASE), RTEMS_PPC_EXCEPTIONS([old]), autoupdate to autoconf 2.52. * include/Makefile.am: Convert PREINSTALL_FILES to TMPINSTALL_FILES, include force-preinstall.am. * wrapup/Makefile.am: Apply @exceptions@.
* 2001-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-275-2/+29
| | | | | | | | | | | * Makefile.am: Remove . from SUBDIRS, add @exceptions@ to SUBDIRS. * configure.ac: Add RTEMS_BSPOPTS_*(PPC_USE_SPRG), RTEMS_BSPOPTS_*(PPC_VECTOR_FILE_BASE), RTEMS_PPC_EXCEPTIONS([old]). * include/Makefile.am: Convert PREINSTALL_FILES to TMPINSTALL_FILES, include force-preinstall.am. * wrapup/Makefile.am: Apply @exceptions@.
* 2001-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-276-0/+24
| | | | * .cvsignore: Add aclocal.m4, autom4te.*, config.*, configure.
* 2001-11-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-272-0/+5
| | | | * vectors/vectors.S: Include <bsp.h> to get PPC_VECTOR_FILE_BASE.
* 2001-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-2627-1792/+15
| | | | | | | | | | | | | | | * acinclude.m4: papyrus reference removed. * papyrus/.cvsignore, papyrus/ChangeLog, papyrus/Makefile.am, papyrus/README, papyrus/bsp_specs, papyrus/configure.ac, papyrus/times, papyrus/dlentry/.cvsignore, papyrus/dlentry/Makefile.am, papyrus/dlentry/dlentry.S, papyrus/flashentry/.cvsignore, papyrus/flashentry/Makefile.am, papyrus/flashentry/flashentry.S, papyrus/include/.cvsignore, papyrus/include/Makefile.am, papyrus/include/bsp.h, papyrus/include/coverhd.h, papyrus/startup/.cvsignore, papyrus/startup/Makefile.am, papyrus/startup/bspclean.c, papyrus/startup/bspstart.c, papyrus/startup/linkcmds, papyrus/startup/setvec.c, papyrus/wrapup/.cvsignore, papyrus/wrapup/Makefile.am: Deleted.
* 2001-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-262-1/+5
| | | | * network/sonic.h: Fix typo.
* 2001-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-264-32/+14
| | | | * src/imfs/Makefile.am: Cleanup.
* 2001-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-264-4/+8
| | | | * arpa/Makefile.am: Remove stray lines.
* 2001-11-26 Ralf CorsepiusJoel Sherrill2001-11-262-1/+4
| | | | * cdtest/main.cc: Remove RTEMS_TEST_IO_STREAM.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-212-4/+6
| | | | | * configure.ac: Remove mpc750 from new_exception_processing, Remove mpc604 from new_exception_processing.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-215-8/+29
| | | | | | | | | | | | * Makefile.am: Add @exceptions@ to SUBDIRS; Remove need_motorola_powerpc. * configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from make/custom/mcp750.cfg, make/custom/mvme2307.cfg; Remove need_motorola_powerpc; Add RTEMS_PPC_EXCEPTIONS([new]). * include/Makefile.am: Replace PREINSTALL_FILES with TMPINSTALL_FILES, include force-preinstall.am. * wrapup/Makefile.am: Apply @exceptions@.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-216-2/+24
| | | | | * Makefile.am: Preinstall c_isr.inl (HACK). * ChangeLog: New file.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-212-2/+5
| | | | * configure.ac: Remove ppc603e from old_exception_processing.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-218-11/+83
| | | | | | | | | | | | | * Makefile.am: Add @exceptions@ to SUBDIRS. * configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from make/custom/score603e.cfg; Add automake conditional for SCORE_GENERATION_1; Add RTEMS_PPC_EXCEPTIONS([old]). * include/Makefile.am: include force-preinstall.am. * start/start.S: include <bspopts.h> instead of targopts.h. * tod/Makefile.am: Apply SCORE_GENERATION_1 conditional. * vectors/vector.S: include <bsp.h>. * wrapup/Makefile.am: Apply @exceptions@.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-215-3/+50
| | | | | | | | | * Makefile.am: Add @exceptions@ to SUBDIRS. * configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from make/custom/ppcn_60x.cfg; Add RTEMS_PPC_EXCEPTIONS([old]). * include/Makefile.am: include force-preinstall.am. * wrapup/Makefile.am: Apply @exceptions@.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-215-4/+29
| | | | | | | | | | * Makefile.am: Add @exceptions@ to SUBDIRS. * configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from make/custom/psim.cfg; Remove RTEMS_OUTPUT_BUILD_SUBDIRS; Add RTEMS_PPC_EXCEPTIONS([old]). * include/Makefile.am: include force-preinstall.am. * wrapup/Makefile.am: Apply @exceptions@.
* 2001-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-204-2/+10
| | | | | * include/bspopts.h.in: Automatically generated file that should not be in CVS.
* 2001-11-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-202-1/+4
| | | | * configure.ac: Remove mpc8xx from new_exception_processing.
* 2001-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-2011-0/+4762
| | | | | | | | | | | * support/new_exception_processing/configure.ac, support/new_exception_processing/rtems/score/c_isr.inl, support/new_exception_processing/rtems/score/cpu.h, support/old_exception_processing/configure.ac, support/old_exception_processing/rtems/score/c_isr.inl, support/old_exception_processing/rtems/score/cpu.h, support/old_exception_processing/rtems/score/ppc_offs.h: New files missed in previous commit.
* 2001-11-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-206-8/+48
| | | | | | | | | | | | * Makefile.am: Add @exceptions@ to SUBDIRS. * configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from make/custom/dmv177.cfg; Rename PPC_USE_INSTRUCTION_CACHE to DMV177_USE_INSTRUCTION_CACHE, Add RTEMS_PPC_EXCEPTIONS([old]). * include/Makefile.am: include force-preinstall.am. * startup/bspstart.c: Rename PPC_USE_INSTRUCTION_CACHE to DMV177_USE_INSTRUCTION_CACHE. * wrapup/Makefile.am: Apply @exceptions@.
* 2001-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-206-7/+105
| | | | | | | | | | * Makefile.am: Add @exceptions@ to SUBDIRS. * configure.ac: Add RTEMS_BSPOPTS_*(), merge-in settings from make/custom/mbx*.cfg, add RTEMS_PPC_EXCEPTIONS([new]). * include/Makefile.am: Convert PREINSTALL_FILES to TMPINSTALL_FILES, include force-preinstall.am. * vectors/Makefile.am: remove bogus VPATH. * wrapup/Makefile.am: Apply @exceptions@.
| | | | * configure.ac: Remove mpc8620 from new_exception_processing.
* 2001-11-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-205-4/+53
| | | | | | | | | * Makefile.am: Add @exceptions@ to SUBDIRS. * configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from make/custom/mpc8260ads.cfg, add RTEMS_PPC_EXCEPTIONS([new]). * include/Makefile.am: Convert PREINSTALL_FILES to TMPINSTALL_FILES, include force-preinstall.am. * wrapup/Makefile.am: Apply @exceptions@.
* 2001-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-206-5/+35
| | | | | | | | | | * Makefile.am: Add @exceptions@ to SUBDIRS. * configure.ac: Add RTEMS_BSPOPTS_*(UARTS_IO_MODE), RTEMS_PPC_EXCEPTIONS([new]). * include/Makefile.am: Convert PREINSTALL_FILES to TMPINSTALL_FILES, include force-preinstall.am. * irq/Makefile.am: remove irq.h from EXTRA_DIST. * wrapup/Makefile.am: Apply @exceptions@.
* 2001-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-2012-2393/+65
| | | | | | | | | | | | | * support/new_exception_processing/Makefile.am, support/old_exception_processing/Makefile.am, support/old_exception_processing/cpu_asm.S, support/old_exception_processing/irq_stub.S: Modified to reflect old versus new exception processing being a per BSP option. * support/new_exception_processing/c_isr.inl, support/new_exception_processing/cpu.h, support/old_exception_processing/c_isr.inl, support/old_exception_processing/cpu.h, support/old_exception_processing/ppc_offs.h: Removed.
* 2001-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-201-1/+4
| | | | * ChangeLog: Corrected spacing.
