* | added acknowledgement for Motorola MVME147 from Dominique le Campion | Joel Sherrill | 1996-05-24 | 1 | -0/+4 | |
| | | | | | (Dominique.LECAMPION@enst-bretagne.fr), for Telecom Bretagne and T.N.I. (Brest, France) | |||||
* | new file | Joel Sherrill | 1996-05-24 | 1 | -0/+50 | |
* | updates from Tony Bennett to correct calling sequences. | Joel Sherrill | 1996-05-24 | 2 | -0/+2 | |
* | new files | Joel Sherrill | 1996-05-24 | 3 | -4/+111 | |
* | updates to fix typos | Joel Sherrill | 1996-05-24 | 3 | -35/+35 | |
* | new file | Mark Johannes | 1996-05-24 | 1 | -0/+22 | |
* | added use of sporadic server scheduling parameters | Joel Sherrill | 1996-05-24 | 7 | -0/+58 | |
* | new files | Joel Sherrill | 1996-05-24 | 3 | -0/+96 | |
* | clean up on DELAYTIMER_MAX | Joel Sherrill | 1996-05-23 | 3 | -12/+0 | |
* | new files | Joel Sherrill | 1996-05-23 | 6 | -0/+204 | |
* | unused variable | Joel Sherrill | 1996-05-23 | 1 | -1/+0 | |
* | new files | Joel Sherrill | 1996-05-23 | 8 | -0/+208 | |
* | new files | Joel Sherrill | 1996-05-23 | 7 | -0/+184 | |
* | new files | Joel Sherrill | 1996-05-23 | 3 | -0/+75 | |
* | new files | Joel Sherrill | 1996-05-23 | 5 | -0/+144 | |
* | new files | Joel Sherrill | 1996-05-23 | 4 | -0/+110 | |
* | cleanup | Joel Sherrill | 1996-05-23 | 8 | -12/+12 | |
* | new files | Joel Sherrill | 1996-05-23 | 8 | -0/+254 | |
* | cleanup status vs. result | Joel Sherrill | 1996-05-23 | 29 | -48/+48 | |
* | new files | Joel Sherrill | 1996-05-23 | 5 | -0/+152 | |
* | new files | Joel Sherrill | 1996-05-23 | 4 | -0/+134 | |
* | new files | Joel Sherrill | 1996-05-23 | 2 | -0/+60 | |
* | new files | Joel Sherrill | 1996-05-23 | 6 | -0/+200 | |
* | new files | Joel Sherrill | 1996-05-23 | 9 | -0/+288 | |
* | updated to reflect more constants and feature macros | Joel Sherrill | 1996-05-23 | 34 | -5/+160 | |
* | updates from Tony Bennett | Joel Sherrill | 1996-05-23 | 12 | -102/+139 | |
* | added code to insure that delay is always non-zero | Joel Sherrill | 1996-05-23 | 2 | -0/+4 | |
* | updates from tony bennett | Joel Sherrill | 1996-05-23 | 1 | -2/+2 | |
* | added as example of how to do a bsp which is not in this tree. | Joel Sherrill | 1996-05-23 | 2 | -0/+19 | |
* | *** empty log message *** | Joel Sherrill | 1996-05-23 | 1 | -2/+2 | |
* | invoke thread stack free routine instead of Workspace free. | Joel Sherrill | 1996-05-23 | 1 | -2/+26 | |
* | updates from Tony Bennett. | Joel Sherrill | 1996-05-23 | 2 | -60/+78 | |
| | | | | | Broke the setjmp/longjmp pair in the context switch into a separate routine so no code depended on local variables surviving the jump. | |||||
* | created posix test suite with test of header files | Joel Sherrill | 1996-05-22 | 51 | -0/+1379 | |
* | Modified to correct variables which defined the range of object classes | Joel Sherrill | 1996-05-22 | 2 | -2/+2 | |
| | | | | which are tasks. | |||||
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 17 | -7/+28 | |
| | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. | |||||
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 6 | -22/+58 | |
| | | | | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. The removed files were moved to newlib as they were duplicates of files already included there. | |||||
* | added posix test directory | Joel Sherrill | 1996-05-10 | 1 | -3/+8 | |
* | fixed typo | Joel Sherrill | 1996-05-10 | 1 | -1/+1 | |
* | updated to remove workaround for bug in binutils 2.5.2 ld now that we are | Joel Sherrill | 1996-05-08 | 1 | -4/+4 | |
| | | | | up to 2.6 | |||||
* | *** empty log message *** | Joel Sherrill | 1996-05-08 | 1 | -1/+2 | |
* | Updated version to 3.5.15. | Joel Sherrill | 1996-05-02 | 2 | -2/+2 | |
* | Updates from Eric Norum. | Joel Sherrill | 1996-05-01 | 7 | -106/+268 | |
* | Updates from Eric Norum to use the mcpu32 flags and fix comments. | Joel Sherrill | 1996-05-01 | 2 | -30/+17 | |
* | changed version number to 3.5.14 | Joel Sherrill | 1996-04-24 | 2 | -2/+2 | |
* | Hacked so gld will accept this so we can purge the aout toolset. This change | Joel Sherrill | 1996-04-24 | 1 | -2/+21 | |
| | | | | should be undone when the m68k-coff cross toolset is updated next time. | |||||
* | added comment regarding stack alignment issues to thread stack allocation | Joel Sherrill | 1996-04-24 | 1 | -0/+14 | |
| | | | | routine. | |||||
* | Lowered number of messages created to reduce burden on workspace. | Joel Sherrill | 1996-04-22 | 1 | -1/+1 | |
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 62 | -432/+324 | |
* | addition of optional user provided stack allocator means that we can not | Joel Sherrill | 1996-04-22 | 1 | -14/+27 | |
| | | | | | reliably produce the "insufficient memory for stack space" error if this extension is configured. | |||||
* | Updates from Tony Bennett. | Joel Sherrill | 1996-04-22 | 12 | -70/+76 | |
