path: root/c (follow)
* 2002-07-22 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2002-07-222-1/+7
| | | | | | * mpc6xx/mmu/bat.c: Per PR241, fix a tiny bug introduced by the fix for an earlier patch (PR213) which added support for setting BAT0 to setdbat().
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-07-222-8/+10
| | | | | | * startup/bspstart.c: Per PR252 removed hack that tripled size of RTEMS Workspace when POSIX is configured. This was probably done to account for confdefs.h missing some application requirements.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-222-1/+5
| | | | * configure.ac: AC_CONFIG_SRCDIR([../libmisc]).
* Remove, moved to cpukit.Ralf Corsepius2002-07-221684-265553/+0
* Remove everything.Ralf Corsepius2002-07-2239-1370/+0
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-222-9/+7
| | | | | | | * configure.ac: Remove RTEMS_ENABLE_MULTIPROCESSING, RTEMS_ENABLE_POSIX, RTEMS_ENABLE_ITRON, RTEMS_ENABLE_INLINES, RTEMS_ENABLE_RTEMS_DEBUG, RTEMS_CHECK_RTEMS_DEBUG, RTEMS_CHECK_NEWLIB.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-223-645/+7
| | | | | * acinclude.m4: Add test "$multilib" != "yes". * config-ml.in: Remove.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-222-9/+14
| | | | | * src/Makefile.am: Add bsplib_DATA. Eliminate LIBNAME. Cosmetical changes.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-223-14/+13
| | | | | | | * acinclude.m4: Cleanups. * configure.ac: Build ${srcdir}/../../cpukit/ as ./exec/ instead of ${srcdir}/exec/. Further adaptations to autoconf >= 2.50.
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-213-2/+10
| | | | * Makefile.am: Fix oversights in previous patch.
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-212-4/+7
| | | | * startup/Makefile.am: Reformat.
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-214-139/+14
| | | | | | * rtems.S: Remove. * Makefile.am: Reflect having removed rtems.S. Use AM_CPPFLAGS instead of INCLUDES (Latest automake standard).
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-212-1/+6
| | | | | * start/Makefile.am: Fix bug in previous patch. Really add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o.
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-212-7/+11
| | | | | * start/Makefile.am: Eliminate PGM. Add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o.
| | | | | * start/Makefile.am: Fix bsplib_DATA = $(PROJECT_RELEASE)/lib/rxgen_romld$(LIB_VARIANT).o.
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-212-0/+8
| | | | | | * start/Makefile.am: Add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o (Didn't make it into cvs at 2002-07-20 :( )
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-2112-24/+48
| | | | | * start/Makefile.am: Eliminate PGMS. Add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o.
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-2114-42/+70
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-2130-90/+150
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-214-12/+20
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-212-0/+6
| | | | | | | | * start/Makefile.am: Eliminate PGM. Add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o. bsplib_DATA += $(PROJECT_RELEASE)/lib/except_vect_332_ROM$(LIB_VARIANT).o bsplib_DATA += $(PROJECT_RELEASE)/lib/ram_init$(LIB_VARIANT) bsplib_DATA += $(PROJECT_RELEASE)/lib/ram_init_FW$(LIB_VARIANT)
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-216-18/+30
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-212-6/+10
| | | | | * start/Makefile.am: Eliminate PGM. Add bsplib_DATA = $(PROJECT_RELEASE)/lib/rxgen_romld$(LIB_VARIANT).o.
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-214-12/+20
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-212-3/+4
| | | | * start/Makefile.am: Remove leftover from eliminating PGM.
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-214-6/+14
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-212-3/+9
| | | | | | * start/Makefile.am: Eliminate PGM. Add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o. Add bsplib_DATA += $(PROJECT_RELEASE)/lib/start16$(LIB_VARIANT).bin.
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-209-20/+36
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-203-0/+7
| | | | * capture/capture.c: include <string.h> for memset.
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-202-6/+10
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-202-6/+12
* 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-201-0/+4
| | | | * startup/Makefile.am: Add bsplib_DATA = linkcmds.
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-2030-0/+90
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-202-0/+6
| | | | * startup/Makefile.am: Add bsplib_DATA = linkcmds device-tree.
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-202-1/+7
| | | | * startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds-le.
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-202-0/+7
| | | | | * startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds.rom linkcmds.rom2ram.
| | | | * startup/Makefile.am: Add bsplib_DATA = linkcmds ghlinkcmds.
* 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-202-0/+6
* 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-2028-0/+84
| | | | * startup/Makefile.am: Add bsplib_DATA = linkcmds rom debugger.
* 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-204-0/+12
| | | | * startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds_ROM.
* 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-202-0/+7
| | | | | * startup/Makefile.am: Add bsplib_DATA = linkcmds gdbinit linkcmds.flash.
| | | | | * startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds.prom linkcmds.bootp.
* 2002-07-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-192-0/+6
| | | | | * include/rtems/score/apimutex.h (_API_Mutex_Lock): Added missing _ISR_Disable.
* 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-1914-0/+42
* 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-192-0/+6
| | | | * startup/Makefile.am: Add bsplib_DATA = linkcmds ramlink romlink.
* 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-196-0/+18
* 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-192-1/+4
| | | | * Makefile.am: Remove setting up bsplibdir.
| | | | * bsp.am: Add bsplib_DATA = bsp_specs.
