* | bsps: Use CPPASCOMPILE for startfile | Sebastian Huber | 2018-01-02 | 78 | -293/+362 | |
| | | | | Update #3254. | |||||
* | bsps: Add EXTRA_DIST to all BSP Makefile.am | Sebastian Huber | 2018-01-02 | 83 | -45/+123 | |
| | | | | | | | | | | This makes it possible to easily use EXTRA_DIST += foobar in fragments. Update #3254. | |||||
* | bsps: Include bsp.am in all BSP Makefile.am | Sebastian Huber | 2018-01-02 | 73 | -0/+73 | |
* | beatnik, motorola_powerpc, mvme3100, mvme5500: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 17 | -31/+53 | |
| | | | | | | | | | This collection of BSPs shared the linker script shared/startup/linkcmds. I renamed that ot shared/startup/linkcmds.share and made a BSP family specific startup/linkcmds. This was needed because each BSP family had a different combination of start file name, undefined symbols, etc. Updates #3520. | |||||
* | qemuppc: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -2/+4 | |
* | haleakala: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+3 | |
* | mpc8260ads: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+3 | |
* | ss555: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+2 | |
* | virtex4: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -7/+3 | |
* | virtex5: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -7/+3 | |
* | gen5200, gen83xx, gen83x, mpc55xxevb, psim, qoriq, t32mppc, tqm8xx, virtex: ↵ | Joel Sherrill | 2017-12-20 | 20 | -41/+31 | |
| | | | | | | | | | | Simplify bsp_specs These BSPs all use shared/startup/linkcmds.base and thus needed to be modified at the same time. Variations in the arguments were reflected into the BSP specific portions of the linkcmds. Updates #3520. | |||||
* | uC5282: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+4 | |
* | mcf5235: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 4 | -5/+8 | |
* | mcf5225x: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+4 | |
* | mcf5206elite: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 3 | -5/+7 | |
* | mcf52235: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+3 | |
* | gen68340: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+5 | |
* | gen68360: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+4 | |
* | csb360: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+4 | |
* | av5282: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 4 | -5/+7 | |
* | genmcf548x, mvme147, mvme147s, mvme162, mvme167: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 6 | -25/+9 | |
| | | | | | | | These BSPs used shared/startup/linkcmds.base and had to be modified as a set. Updates #3520. | |||||
* | mrm332: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 2 | -5/+3 | |
* | mcf5329: Simplify bsp_specs | Joel Sherrill | 2017-12-20 | 3 | -5/+3 | |
* | Add support for arguments in ISRs | Kilian Holzinger | 2017-12-20 | 1 | -0/+3 | |
* | gensh4: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 4 | -5/+7 | |
| | | | | Updates #3250. | |||||
* | gensh2: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 4 | -7/+4 | |
* | gensh1: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 | |
* | shsim: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 5 | -242/+2 | |
| | | | | | | | | | | This bsp_specs included non-standard logic to pass endian arguments to the linker. These should not be necessary. If they are, it is a bug in the sh gcc target. The code was "%{ml:-EL}%{mb:-EB}" Also the file linkcmds.sim was not referenced and was deleted. Updates #3250. | |||||
* | rbtx4938: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+4 | |
* | rbtx4925: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+4 | |
* | malta: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+4 | |
* | jmr3904: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+4 | |
* | hurricane: Simplifies bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+4 | |
* | csb350: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+3 | |
* | sparc64 BSPs: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 3 | -11/+4 | |
* | ARM BSPs: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 21 | -100/+21 | |
* | riscv_generic: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 | |
* | TLL6527M: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 | |
* | eZKit533: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 | |
* | bf537Stamp: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 | |
* | nios2_iss: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -6/+3 | |
* | generic_or1k: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 | |
* | m32cbsp: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 | |
* | moxiesim: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 | |
* | milkymist: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -6/+3 | |
* | lm32_evr: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -6/+3 | |
* | pc386: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 3 | -7/+4 | |
| | | | | | | | | If this has any issues, check that the change in linking the 16-bit startup code in Makefile.am generates the same code. This was odd code and didn't need the RTEMS linkcmds anyway. Updates #3520. | |||||
* | epiphany: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -5/+2 | |
* | gdbv850sim: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 2 | -9/+2 | |
* | mvme167: Simplify bsp_specs | Joel Sherrill | 2017-12-19 | 1 | -7/+0 | |
| | | | | | | | | | This bsp-specs added many libraries which it should not have. It also added the non-standard -qjava option which if actually used will have to be addressed by adding linker options on the GCC command line. Updates #3520. |
