PR 505/bsps
* setvec.c: Rework to remove punned pointer warning generated by gcc
3.3 and newer.
* startup/linkcmds: Add more memory and sections so tests can link.
This is a generic BSP for a CPU model so OK to do this.
* vectors/vectors.h, vectors/vectors_init.c: Undo previous change.
* irq/irq.h: Correct typo.
* Makefile.am: Correct typo.
* startup/linkcmds: Add more memory so tests can link. This is a
* Makefile.am: Cosmetics.
* acinclude.m4: Fix loosing arguments when configuring cpukit and
testsuites (Was exposed with --enable-multilib, only).
Remove RTEMS_SUBCONFIGURE_ARGS_QUOTE. RTEMS_CONFIG_SUBDIR.
Add RTEMS_BSP_CONFIG_SUBDIR.
* configure.ac: Reflect changes to acinclude.m4. Reflect new args to
testsuites's configure.
* aclocal/rtems-top.m4: Remove ENDIF hack.
Rework and fix setting up PROJECT_TOPdir (PACKHEX wasn't found).
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am,
wrapup/Makefile.am: Fix automake problems having been introduced
in previous patch.
* bootloader/Makefile.am: Fix preinstall dir handling.
* bootloader/Makefile.am: Preinstall dirs.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Don't install *.rels. Reflect changes to bsp.am.
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am:
Preinstall dirs.
* wrapup/Makefile.am: Preinstall dirs. Cosmetics.
* aclocal/check-multiprocessing.m4: Cosmetics.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT.
* aclocal/project-root.m4: Remove obsolete comments. Remove PACKHEX.
* Makefile.am: Preinstall dirs.
* bsp.am: Remove everything but CPPASCOMPILE.
* mpc505/Makefile.am: Fix typo.
* configure.ac: Add support for --disable-rtemsbsp. Cosmetics.
* librdbg/Makefile.am: Merge-in librdbg/include/Makefile.am,
librdbg/src/Makefile.am.
* librdbg/include/Makefile.am, librdbg/src/Makefile.am: Remove.
Unconditionally apply RTEMS_CHECK_MULTIPROCESSING.
* Makefile.am: Add DIST_SUBDIRS = @BSP_SUBDIRS@.
* bootloader/Makefile.am: Fix up paths having been broken in
previous patch.
* bsp.am: Add CPPASCOMPILE.
* aclocal/check-rdbg.m4: Don't AC_SUBST(HAS_RDBG).
* Makefile.am: DISTCLEANFILES += @CUSTOM_CFG_FILES.
* bootloader/Makefile.am: Remove references to $(top_srcdir).
Remove NM, LD. Cosmetics.
* wrapup/Makefile.am: Reflect new location of librdbg.a.
* librdbg/src/i386/Makefile.am, librdbg/src/m68k/Makefile.am,
librdbg/src/powerpc/Makefile.am:
Remove.
* librdbg/src/Makefile.am: Merge-in librdbg/src/i386/Makefile.am,
librdbg/src/m68k/Makefile.am, librdbg/src/powerpc/Makefile.am.
* configure.ac: Explicitly check for NM.
* configure.ac: Explicitly check for OBJCOPY.
* aclocal/canonicalize-tools.m4: Don't check for NM, OBJCOPY, SIZE,
STRIP.
* bsp.am: DISTCLEANFILES = include/bspopts.h.
* librdbg/include/Makefile.am: Merge-in
librdbg/include/rdbg/i386/Makefile.am,
librdbg/include/rdbg/m68k/Makefile.am, librdbg/include/rdbg/Makefile.am,
librdbg/include/rdbg/powerpc/Makefile.am.
* librdbg/include/rdbg/i386/Makefile.am,
librdbg/include/rdbg/powerpc/Makefile.am: Remove.
* configure.ac: Use AS_HELP_STRING(ada).
* aclocal/bspopts.m4: Use AS_HELP_STRING.
* aclocal/bsp-configure.m4: Require autoconf-2.59.
Use AC_CONFIG_HEADERS.
* aclocal/check-custom-bsp.m4: Add bspkit-support.
* aclocal/enable-rtemsbsp.m4: Use AS_HELP_STRING.
* acinclude.m4: Regenerate.
* configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* Makefile.am: include local.am.
* aclocal/version.m4: 4.6.99.0.
* Makefile.am: Don't include host.am.
* automake/compile.am: Further cleanups.
* automake/lib.am: Remove (Unused).
* wrapup/Makefile.am: Don't include lib.am.
* automake/compile.am: Use automake compilation rules.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Add start*.bin to CLEANFILES.
* Makefile.am: Remove startup/linkcmds.
* Makefile.am: Don't include lib.am.
