* wrapup/Makefile.am: Added modem subdir.
* configure.in, Makefile.am: Added modem subdir.
* net/Makefile.am: Added if_pppvar.h, pppcompress.h.
* pppd/Makefile.am: Added pppmain.c (which needs work).
* pppd/chat.c, pppd/fsm.c, pppd/fsm.h, pppd/ipxcp.c, pppd/main.c,
pppd/ppp_tty.c, pppd/upap.c: Changes from Thomas Doerfler
<Thomas.Doerfler@imd-systems.de> and cosmetic changes by me.
Actually main.c and ppp_tty.c should be scratched. The modem
subdir has the real ppp_tty.c and the real pppd main is in pppmain.c.
* libc/res_init.c: Move include to avoid compiler dumping core.
* libc/termios.c, libc/termiostypes.h: Task driver driver model
and line discipline support from Thomas Doerfler
<Thomas.Doerfler@imd-systems.de>.
* The JMR BSP is for a Toshiba TX39 evaluation board but
can also be used with the mips simulator in gdb.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, clock/.cvsignore, clock/Makefile.am,
clock/clockdrv.c, console/.cvsignore, console/Makefile.am,
console/console-io.c, include/.cvsignore,
include/Makefile.am, include/bsp.h, start/.cvsignore,
start/Makefile.am, start/regs.S, start/start.S,
startup/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/linkcmds, wrapup/.cvsignore, wrapup/Makefile.am: New files.
* TESTED: Added jmr3904 entry.
* TESTED: Added new sparc variations (erc32, leon, and Tharsys).
* cpu_asm.S: Fix for CPUs with FPU revision B or C.
* erc32sonic/erc32sonic.c: Minor modifications which enable
network interface to come up and work for some time before
getting an error in the SONIC driver. The error is a bit random,
sometimes MCLGET (m, M_WAIT) tries to access memory way outside the
available ram (and traps) while sometimes there is a panic due
to RBAE/RXEN.
* psxstat/test.c, psxstat/psxstat.scn: Forced inode numbers
to remain consistant across platforms and bsps by forcing
a mount point in front of all paths.
2000-11-17 Jennifer Averret <jennifer@OARcorp.com>
* psxmount/test.c, psxmount/psxmount.scn: Improve output to report
expected error condition in one case.
* psxreaddir/test.c, psxreaddir.scn: Added test cases to exercise
readdir() of root of mounted filesystem. Also corrected the screen
file for some mistakes noticed in this effort.
* itrontask01/system.h: Configure enough stack memory.
* libc/mount.c: Make sure there is space allocated for a device name
in the mount table entry.
* src/imfs/imfs_eval.c: Always return imaginary node at mount points.
* libc/mount.c (search_mt_for_mount_point): Deleted routine.
* libc/mount.c (Is_node_fs_root): Replacement for above that
accounts for the imaginary root node being returned by the
filesystem evaluation routine.
* libc/unmount.c (unmount): Account for imaginary root node
being returned and improved variable names to clarify code.
* libc/unmount.c (file_systems_below_this_mountpoint): Body of
routine replaced to account for imaginary root node being returned.
* Makefile.inc.in: Use * instead of *_FOR_TARGET (BUG-FIX).
* Makefile.am: Cleanup.
* include/Makefile.am: Cleanup.
* psxmount/psxmount.scn, psxmount/test.c: Correct spelling.
* Makefile.am, configure.in: Added support for instruction
cache enabling based on CPU model.
* cache/.cvsignore, cache/Makefile.am, cache/cache.c,
cache/cache_.h: New files.
* shared/src/cache_manager.c
(rtems_cache_invalidate_multiple_instruction_lines): If
CPU_INSTRUCTION_CACHE_ALIGNMENT is defined but 0, then there is
an instruction cache but no notion of line size.
* wrapup/Makefile.am: Pick up cache code from libcpu and pick
up .o's instead of .rel's from libcpu.
* cpu.c, rtems/cpu/sparc.h: Make floating point optional based
on gcc arguments. Do not initialize FP context if there is
no FPU. Flush instruction cache after installing RTEMS trap handler.
* startup/boardinit.S: St 32-bit ram width by default.
* ChangeLog, .cvsignore, Makefile.am, bspclean.c, bspstart.c,
gnatcommon.c, start.S: New files. Largely moved from ERC32
BSP to be able to be shared with LEON and other SPARC BSPs.
* network/sonic.c: Added ipalign() routine to align the
received packet so that the ip header is on a 32-bit boundary.
Necessary for cpu's that do not allow unaligned loads and stores
and when the 32-bit DMA mode is used.
* Makefile.am, configure.in: Added shared directory as part
of enhancing ERC32 and adding LEON.
configure.in, times, clock/.cvsignore, clock/Makefile.am,
clock/ckinit.c, console/.cvsignore, console/Makefile.am,
console/console.c, console/consolereserveresources.c,
console/debugputs.c, gnatsupp/.cvsignore,
gnatsupp/Makefile.am, gnatsupp/gnatsupp.c,
include/coverhd.h, include/leon.h, start/.cvsignore,
start/Makefile.am, startup/.cvsignore, startup/Makefile.am,
startup/boardinit.S, startup/linkcmds, startup/setvec.c,
startup/spurious.c, timer/.cvsignore, timer/Makefile.am,
timer/timer.c, tools/.cvsignore, tools/Makefile.am,
tools/configure.in, tools/runtest.in, wrapup/.cvsignore,
wrapup/Makefile.am: New file.
* Makefile.am, configure.in, gnatsupp/Makefile.am,
gnatsupp/gnatsupp.c, include/Makefile.am, include/bsp.h,
start/Makefile.am, startup/Makefile.am, startup/setvec.c,
wrapup/Makefile.am:
* erc32sonic: New directory.
* erc32sonic/Makefile.am, erc32sonic/erc32sonic.c,
erc32sonic/.cvsignore: New files.
* include/erc32.h: New file.
* startup/boardinit.S: New file.
Big update of SPARC support for ERC32 and LEON.
Added support for ERC32 without floating point.
Added SONIC support as configured on Tharsys ERC32 board.
The bsp's share various code in the shared directory:
gnat-support, start-up code, etc.
To decrease the foot-print, I removed the 16 kbyte start-up
stack that was put in .bss and never reused once the system
was up. The stack is now put between the heap and the
workspace. To reclaim it, the user can do a rtems_region_extend
to merge the stack to the heap region once the system is up.
* clock_driver_stub.c: This is a stub of a clock driver that
is sufficient for linking the ticker application. Some
simulators do not have a soruce for a clock tick. Also
this can be used while constructing a BSP so everything links.
* Makefile.am, console/Makefile.am, include/Makefile.am,
start/Makefile.am: VPATH was not setup correctly
* configure.in: catch -enable-rtemsbsp (Allowed by autoconf).
Autoconf allows one to pass -enable-*, but this file expected --enable*.
* libc/libio.c: Special treatment of O_NDELAY for Cygwin.
* Makefile.am, clock/Makefile.am, clock/.cvsignore, wrapup/Makefile.am:
Added include of stub clock driver so ticker would link.
* configure.in, Makefile.am, clock/Makefile.am, clock/.cvsignore,
wrapup/Makefile.am: Added include of stub clock driver so ticker
would link.
* include/rtems/system.h: Use proper conditional (RTEMS_POSIX_API)
so prototypes for POSIX_MP_NOT_IMPLEMENTED(), POSIX_NOT_IMPLEMENTED(),
POSIX_BOTTOM_REACHED() are actually included.
* network/README.cs8900, network/cs8900.c, network/cs8900.h: New files.
* network/Makefile.am: Modified to reflect above.
* aclocal/canonicalize-tools.m4, aclocal/check-tool.m4,
aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL
with an RTEMS specific but more restrictive autoconf macro.
* stubdr/Makefile.am: Replace leaf.cfg w/ automake/lib.am.
* bsp_specs: Remove -Tlinkcmds from *link rule.
* startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and
* startup/bspstart.c, startup/bspstart.c: assoc.h, error.h, libio_.h,
libio.h, and libcsupport.h moved from libc to lib/include/rtems and
Also removed obsolete references to STACK_CHECKER_ON.
* startup/bspstart.c, startup/bspstart.c.nocache: assoc.h, error.h,
libio_.h, libio.h, and libcsupport.h moved from libc to
lib/include/rtems and now must be referenced as <rtems/XXX.h>.
Header file order was cleaned up while doing this.
* bsplibc.c: assoc.h, error.h, libio_.h, libio.h, and
