path: root/c (follow)
* changed version to 4.0.0Joel Sherrill1998-10-272-2/+2
* Spacing.Joel Sherrill1998-10-271-1/+0
* Merged base line score603e BSPJoel Sherrill1998-10-261-28/+28
* changed version to 4.0.0-beta4bJoel Sherrill1998-10-262-2/+2
* Patches done in conjunction with Juan Zamorano FloresJoel Sherrill1998-10-267-14/+31
| | | | | <jzamora@avellano.datsi.fi.upm.es>. He debugged enough to let me know what was wrong and I supplied the code. :)
* Updated for mvme136.Joel Sherrill1998-10-261-1/+1
* Updated the date.Joel Sherrill1998-10-261-2/+1
* Typos spotted by Ian Lance Taylor <ian@airs.com>.Joel Sherrill1998-10-221-2/+2
* Added missing .rodata and *(.gnu.linkonce.r*) section.Joel Sherrill1998-10-221-0/+4
* Patch from Ian Lance Taylor <ian@airs.com>:Joel Sherrill1998-10-221-0/+1
| | | | | | | | | I noticed that in the 4.0.0-beta4a tar file, the file c/src/lib/libbsp/i386/pc386/startup/linkcmds was changed so that it no longer handles the .gnu.linkonce.r* sections. The appended patch was applied to the file. I'm not sure why. I think this patch should probably be backed out, although it's not critical for the release.
* Patch from Eric Norum.Joel Sherrill1998-10-221-4/+6
* Changed all of these to stubs.Joel Sherrill1998-10-2214-806/+68
* changed version to 4.0.0-beta4aJoel Sherrill1998-10-152-2/+2
* Updated for the i386ex and deprecated BSPs.Joel Sherrill1998-10-151-5/+8
* Added bare bsp, mini-glue layer for POSIX port, and bare bsp information.Joel Sherrill1998-10-151-0/+14
* Added pre_install_src as a dependency to debug and profile per Ralf Corsepius'Joel Sherrill1998-10-151-2/+2
| | | | recommendation.
* Patch from Thomas Doerfler <td@imd.m.isar.de> to include theJoel Sherrill1998-10-151-1/+2
| | | | ppc403 interrupt control libcpu component.
* Uncommented the conditional stuff for "good gas 16 bit code".Joel Sherrill1998-10-151-2/+2
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-10-1422-60/+1817
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1. Rtems contains some perl scripts that use hard-coded paths to /usr/bin/perl or /usr/local/bin/perl I have already fixed these problems by adding some checks to configure.in. While doing this, I also cleaned up some more autoconf related problems for generating shell scripts. This patch might seem a bit scary to you, but I am quite confident it won't break something (I've been testing it for almost a week now, however it might introduce typos for a limited number configurations I don't have access to - But it shouldn't be a problem for you to test them :-). I expect to get this finished tonight, hence you will very likely have the patch when you get up tomorrow. Changes: * Check for PERL and disable all PERL scripts if perl wasn't found. * Generate all KSHELL-scripts with autoconf instead of make-script * Automatic dependency handling for autoconf generated KSHELL or PERL scripts (make/rtems.cfg) Notes: * this patch contains new files and deletes some other files. * The patch is relative to rtems-4.0.0-beta4 with my previous rtems-rc-981014-1.diff patch applied. Testing: I tested it with sh-rtems and posix under linux. Now all targets which are touched by this patch and which are not used while building for sh-rtems and posix still need to be tested. AFAIS, only the sparc/erc32 BSP should be affected by this criterion. And if you like to, you should also consider testing it on a Cygwin32 and a Solaris host for one arbitrary BSP.
* Updated.Joel Sherrill1998-10-141-3/+3
* Added rest of opendir family and made it compile.Joel Sherrill1998-10-133-4/+35
* New files.Joel Sherrill1998-10-1310-0/+656
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to correct minorJoel Sherrill1998-10-133-6/+6
| | | | cosmetic things.
* Modified to avoid building certain files under UNIX.Joel Sherrill1998-10-131-3/+11
* Typo which prevented baud rate changes from Thomas Doerfler <td@imd.m.isar.de>.Joel Sherrill1998-10-121-1/+1
* changed version to 4.0.0-beta4Joel Sherrill1998-10-122-2/+2
* New files.Joel Sherrill1998-10-124-0/+328
* Removed fork(), execv(), and wait() since they are now stubbed in theJoel Sherrill1998-10-121-21/+0
| | | | POSIX API.
* Added opendir and readdir.Joel Sherrill1998-10-121-1/+1
* Added helas403 and changed column spacing.Joel Sherrill1998-10-121-36/+40
* Added header files per request from Chris Johns to avoid problemsJoel Sherrill1998-10-123-0/+12
| | | | in include file order.
* NEXT_GAS should have been NEW_GAS. Spotted by Emmanuel Raguet ↵Joel Sherrill1998-10-073-4/+4
| | | | <raguet@crf.canon.fr>.
* changed version to 981006Joel Sherrill1998-10-062-2/+2
* Removed files pc386uart.h and pcibio.h from Makefile since they areJoel Sherrill1998-10-061-1/+0
| | | | now installed from the shared directory.
* Corrected assembly language to use constants instead of addresses.Joel Sherrill1998-10-061-2/+2
| | | | Thanks to Rod Barman for this one.
* Added missing field (idle_task_stack_size) to CPU Table.Joel Sherrill1998-10-061-0/+1
* Patch from Emmanuel Raguet <raguet@crf.canon.fr> to add networkingJoel Sherrill1998-10-061-0/+10
| | | | information to this file to be more like the gen68360.
* Large patch from Erik Ivanenko <erik.ivanenko@utoronto.ca> whichJoel Sherrill1998-10-0531-376/+3515
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | moves pieces of the pc386 bsp up to a shared level for all i386 BSPs and modifies the i386ex BSP to use those shared pieces. Serial remote debugging is included for both targets. Erik's notes: There are several workarounds in it: 1) #define NEXT_GAS is hardcoded in pc386/start/start.s 2) #define NEXT_GAS is hardcoded in i386ex/start/start.s 3) #define NEW_GAS is hardcoded in pc386/start16.s 4) #undef __assert and redeclare _assert hardcoded in console.c for both pc386 and i386ex due to my egcs1.1b ~ newlib problem. Should have modified t-rtems.cfg ( no time ) I've tested pc386 with both video and serial consoles and GDB remote. All work fine, except that GDB acts weird. ( re: other posting) I hope this will work for you. It took quite some time to locate the autoconf error. The remainder was just grunt work. Unfortunately, I think I've unwound the removal of the IBMPCInitVideo stuff. Sorry. I REALLY can't spend more time... I've been at this conversion to 4.0 locally and updating the release since Sept. 8th, and have yet to compile my network driver.... This is as much as I can do right now. I look forward to the next patch to really test i368ex. I did make sure that the sample tests worked for pc386.
* New file based on information from Eric Norum <eric@skatter.usask.ca>.Joel Sherrill1998-10-051-0/+42
* Commented out line which ran psim tests twice.Joel Sherrill1998-10-051-1/+1
* Update from Thomas Doerfler <td@imd.m.isar.de>.Joel Sherrill1998-10-051-0/+58
* Fixed use of incorrect macro for minimum stack size.Joel Sherrill1998-10-051-1/+1
* Patch from Ian Lance Taylor <ian@airs.com>:Joel Sherrill1998-10-012-10/+16
| | | | | | | | The reentrant versions of the malloc functions in c/src/lib/libc/malloc.c do not match the definitions in newlib. These will be used if you use newlib routines such as fdopen. I believe this patch to malloc.c is needed to provide the correct versions.
* changed version to 981001Joel Sherrill1998-10-012-2/+2
* Patch from Thomas Doerfler <td@imd.m.isar.de> to improve 403 support.Joel Sherrill1998-10-014-1/+42
| | | | | | | | | | | | | | | | | - c/src/exec/score/cpu/powerpc/ppc.h: some small changes (added ppc403 characteristics like a exception vector prefix register, some special register definitions). I am quite sure, they are compatible with the existing sources, although I did not check - c/src/exec/score/cpu/powerpc/cpu.c: There is one severe limitation in the exception entries: Due to the current code arrangement, the "branch absolute" to the ISR handler may only jump to the first 128MByte or the last 128MByte of the 4GByte address range. When the ppc403 is running out of ROM, the ROM functions are located in the last 128MByte (0xFFF00000 and up). These addresses were not handled correctly (sign reduced) in "install_raw_handler". The change I added should work on existing ppc BSPs aswell...
* Updated to reflect Thomas Doerfler (td@imd.m.isar.de) submitting theJoel Sherrill1998-10-011-0/+4
| | | | helas403 BSP.
* BSP submitted by Thomas Doerfler <td@imd.m.isar.de>:Joel Sherrill1998-09-307-221/+1192
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Finally I am through: I have found the last bugs that made RTEMS- 4.0-beta3 start on my ppc403 board from ROM. So now the '403 support is up to date again. Roughly I have added the following features: - support for the on-chip interrupt controller (in a separate module) - interrupt support for the console device - termios support for the console device ============================================== Since the BSP behaivour changed in some details (console no longer is polling, other memory layout etc) I have created a new BSP "helas403" rather than changing the "papyrus" BSP. The old "polled" console driver still sticks around in "console.c.polled" To get the BSP up and running, I had to create the new BSP files (derived from papyrus). Besides that, the following source areas have been changed: - c/src/lib/libcpu/powerpc/ppc403: changes to console driver, small changes to clock driver, new "ictrl" interrupt controller driver - c/src/exec/score/cpu/powerpc/ppc.h: some small changes (added ppc403 characteristics like a exception vector prefix register, some special register definitions). I am quite sure, they are compatible with the existing sources, although I did not check - c/src/exec/score/cpu/powerpc/cpu.c: There is one severe limitation in the exception entries: Due to the current code arrangement, the "branch absolute" to the ISR handler may only jump to the first 128MByte or the last 128MByte of the 4GByte address range. When the ppc403 is running out of ROM, the ROM functions are located in the last 128MByte (0xFFF00000 and up). These addresses were not handled correctly (sign reduced) in "install_raw_handler". The change I added should work on existing ppc BSPs aswell... - c/src/lib/libc/termios.c: During my tests, I added one change you sent me, so this patch will already be incorporated in the current source tree. There are some smaller changes, see the attached diff file. ========================================= Concerning the GNU toolchain: I tried several tool chains. Finally I almost succeeded with egcs-1.0.3a with patch egcs-1.0.3-rtems-diff-19980527 I had to add the following lines to the egcs files. Without them configure complaint that the cross compiler could not generate executable output. - additional lines needed in egcs distribution in file gcc/config/rs6000/rtems.h: +++ lines start #undef STARTFILE_DEFAULT_SPEC #define STARTFILE_DEFAULT_SPEC "ecrti.o%s" #undef ENDFILE_DEFAULT_SPEC #define ENDFILE_DEFAULT_SPEC "ecrtn.o%s" ++++ lines end As far as I have seen in the Changelog of egcs, you have recently sent two patches affecting the powerpc support, but they were added in the wrong order.... :-( egcs-19980628 with patch egcs-19980628-rtems-diff-19980707 does not work! I used binutils 2.9.1 with patch binutils-2.9.1-rtems-diff-19980515 (binutils 2.8.1 does not work, internal error in gas) and newlib-1.8.0 with patch newlib-1.8.0-rtems-diff-19980707 Finally I had to poke a line in the "bit" script, since, on my LINUX machine, the GNU make is only available as "make", not as "gmake"... For all the tools and newlib I selected configuration "powerpc- rtems". -------------------------------------------- IMD Ingenieurbuero fuer Microcomputertechnik Thomas Doerfler Herbststrasse 8 D-82178 Puchheim Germany email: td@imd.m.isar.de
* BSP submitted by Thomas Doerfler <td@imd.m.isar.de>:Joel Sherrill1998-09-3019-0/+2091
* Added new autoconf test for i386 code16/code32 support. The guts of theJoel Sherrill1998-09-304-7/+10
| | | | | | test were suggested by Ian Taylor <ian@airs.com> and Joel did the hard part of putting it in aclocal and editting all the offending Makefiles and source code which could use this feature.
* New file from Ralf.Joel Sherrill1998-09-301-0/+91
