* optman/sapi/no-ext.c, optman/sapi/no-io.c: Convert SAPI manager and
SuperCore Handler initialization routines to directly pull parameters
from configuration table.
* optman/rtems/no-barrier.c, optman/rtems/no-dpmem.c,
optman/rtems/no-event.c, optman/rtems/no-mp.c, optman/rtems/no-msg.c,
optman/rtems/no-part.c, optman/rtems/no-region.c,
optman/rtems/no-rtmon.c, optman/rtems/no-sem.c,
optman/rtems/no-signal.c, optman/rtems/no-timer.c: Convert manager
initialization routines to directly pull parameters from
configuration table. Eliminate empty routines sportted.
* libchip/serial/ns16550.c: Add CVS-Id. Fix #define mess.
* GT64260/MVME5500I2C.c: Include <stdint.h> instead of
<rtems/stdint.h>.
* libchip/network/i82586.c, libchip/network/smc91111config.h: Eliminate
all public use of TOD conversion routines.
* include/rtems++/rtemsEvent.h, include/rtems++/rtemsMessageQueue.h,
include/rtems++/rtemsSemaphore.h, include/rtems++/rtemsTimer.h,
src/rtemsTask.cc: Eliminate all public use of TOD conversion
routines.
* include/rtems++/rtemsTimer.h: Use public API not
_TOD_Microseconds_per_tick.
* rtems.adb: Use public API not _TOD_Microseconds_per_tick.
include/rtems++/rtemsSemaphore.h, src/rtemsTask.cc: Use public API
* bootcard.c: Eliminate pointers to API configuration tables in the
main configuration table. Reference the main configuration table and
the API configuration tables directly using the confdefs.h version
rather than obtaining a pointer to it. This eliminated some
variables, a potential fatal error, some unnecessary default
configuration structures. Overall, about a 4.5% reduction in the code
size for minimum and hello on the SPARC.
* startup/cpu.c: Add missing prototype.
* clock_driver_stub.c: Remove (unused).
* shared/clockdrv_shell.c: Turn warning into error.
* at91rm9200/clock/clock.c, lpc22xx/clock/clockdrv.c,
mc9328mxl/clock/clockdrv.c, s3c2400/clock/clockdrv.c,
s3c24xx/clock/clockdrv.c:
Include ../../../../libbsp/shared/clockdrv_shell.h
instead of ../../../../libbsp/shared/clockdrv_shell.c.
* configure.ac: Add RTEMS_BSPOPTS(LPC24XX_OSCILLATOR_RTC).
Add RTEMS_BSPOPTS(LPC24XX_OSCILLATOR_MAIN).
* include/bsp.h: #include <bspopts.h>.
* misc/system-clocks.c: Receive LPC24XX_OSCILLATOR_RTC,
LPC24XX_OSCILLATOR_MAIN through bspopts.h.
* lpc22xx/include/lpc22xx.h, mc9328mxl/include/mc9328mxl.h:
#include <stdint.h> instead of <rtems/stdint.h>.
* at91rm9200/dbgu/dbgu.c: Add missing prototype.
* aclocal/prog-cc.m4: Use -r instead of -Wl,-r to build *.rels.
* aclocal/rtems-cpu-subdirs.m4: Remove obsolete cpus.
* bsp_specs: Update to reflect comments.
* bsp_specs: Remove -Qy from *link.
* psim-shared, runtest-bottom: Tidy up more bugs.
* .cvsignore: New file.
* bsp_specs: Remove motld_start_g.o.
* bsp_specs: Cosmetics.
* bsp_specs: Remove start_g.o, remove -e start.
* TOOL_TARGETS: Add Lattice Mico32 support.
* aclocal/rtems-cpu-subdirs.m4: Add Lattice Mico32 support.
* ChangeLog, Makefile.am, configure.ac, preinstall.am,
shared/cache/cache.c, shared/cache/cache_.h, shared/misc/memcpy.c: New files.
* ChangeLog, Makefile.am, README, acinclude.m4, configure.ac,
shared/clock/ckinit.c, shared/clock/clock.h,
shared/console/console.c, shared/console/uart.c,
shared/console/uart.h, shared/start/start.S,
shared/startup/bspstart.c, shared/startup/setvec.c,
shared/timer/timer.c, shared/tsmac/dp83848phy.h,
shared/tsmac/tsmac.c, shared/tsmac/tsmac.h: New files.
* ChangeLog, Makefile.am, bsp_specs, configure.ac, preinstall.am,
include/.cvsignore, include/bsp.h, include/coverhd.h,
include/irq-config.h, include/system_conf.h, include/tm27.h,
startup/linkcmds: New files.
* shared/irq/openpic_i8259_irq.c: Line wrap.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* bsp_specs, start/start.S: Move -e start from *link to *startfile to
avoid warning for undefined entry symbol when linking relocatables
with binutils 2.19. Also rename entry from _init to _start to avoid
conflict with C++ constructor method name on other architectures.
* bsp_specs, tools/runtest.in: Move -e start from *link to *startfile
to avoid warning for undefined entry symbol when linking relocatables
with binutils 2.19.
* psim-bottom, psim-gdb-bottom, psim-gdb-top.in, psim-shared,
psim-top.in: Clean up and works better. Uses argv[0] to override
configured target name.
PR 1344/bsps
* clock/ckinit.c: Committed code was not final. Corrections.
* bsp_specs: Remove references to start_g.o.
* psim-bottom, psim-gdb-bottom, psim-shared, psim-top.in: Add ability
to force psim configuration to include System V IPC devices even when
the test does not appear to be multiprocessing. This is used by some
RTEMS application developers for system simulation and could be used
to simulate a framebuffer if a UNIX process mirrored the buffer.
