* | Transitioned to shared bsp_libc_init() and cleaned up comments. | Joel Sherrill | 1998-04-15 | 63 | -1435/+604 |
* | Initial sets of user extensions now have memory allocated on the fly | Joel Sherrill | 1998-04-15 | 1 | -2/+1 |
| | | | | for them. | ||||
* | Stack check now initialized as part of initial extension set. | Joel Sherrill | 1998-04-15 | 6 | -0/+130 |
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 27 | -351/+13 |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | ||||
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 9 | -28/+83 |
* | changed version to ralf-980414 | Joel Sherrill | 1998-04-14 | 2 | -2/+2 |
* | Account for interrupt stack space | Joel Sherrill | 1998-04-14 | 2 | -2/+24 |
* | Ralf Corsepius suggested a way to get rid of UNIX compiler files and use ↵ | Joel Sherrill | 1998-04-14 | 3 | -3/+2 |
| | | | | gcc-target-default.cfg | ||||
* | Stack checker extension now accounted for in confdefs.h | Joel Sherrill | 1998-04-14 | 27 | -201/+3 |
* | Added stack checker extension | Joel Sherrill | 1998-04-14 | 2 | -4/+28 |
* | Now accounts for region used by RTEMS malloc and extension used | Joel Sherrill | 1998-04-14 | 28 | -408/+32 |
| | | | | by newlib. | ||||
* | Removed recursive call to exit | Joel Sherrill | 1998-04-14 | 1 | -2/+0 |
* | Moved bspclean from assembly to C and made exit act properly. | Joel Sherrill | 1998-04-14 | 2 | -2/+19 |
* | new file | Joel Sherrill | 1998-04-14 | 3 | -6/+54 |
* | Removed delay macro | Joel Sherrill | 1998-04-14 | 1 | -16/+0 |
* | Refreshing effort from Avenger. | Joel Sherrill | 1998-04-14 | 8 | -322/+1046 |
* | removed shmsupp | Joel Sherrill | 1998-04-14 | 1 | -1/+1 |
* | Corrected comment | Joel Sherrill | 1998-04-14 | 1 | -3/+2 |
* | new files | Joel Sherrill | 1998-04-14 | 35 | -0/+3397 |
* | Increased stack space of the monitor task. | Joel Sherrill | 1998-04-06 | 2 | -2/+2 |
* | Increased stack size so test would run in debug mode. | Joel Sherrill | 1998-04-06 | 5 | -5/+6 |
* | More stuff removed as a result of using newlib's isatty() implementation. | Joel Sherrill | 1998-04-06 | 3 | -26/+0 |
| | | | | These were noticed by Eric Norum. | ||||
* | Added stanzas for debug_tests and profile_tests. | Joel Sherrill | 1998-04-06 | 1 | -0/+6 |
* | Added test so the build procedure would stop if a directory did not exist. | Joel Sherrill | 1998-04-03 | 1 | -0/+2 |
| | | | | | This typically indicates a bug in a directory level Makefile or a configure scrip bug. | ||||
* | Removed isatty() since we are now using newlib's implementation as | Joel Sherrill | 1998-04-03 | 5 | -22/+0 |
| | | | | a result of enabling the newlib POSIX directory. | ||||
* | Made these have real constants. | Joel Sherrill | 1998-04-03 | 4 | -44/+52 |
* | changed version to 4.0.0-beta2 | Joel Sherrill | 1998-03-31 | 2 | -2/+2 |
* | Added "sigemptyset()" call to insure that the memcmp() would work. | Joel Sherrill | 1998-03-31 | 1 | -0/+4 |
| | | | | | It appears that the new glibc does not clear all the bits of the signal set with a sigprocmask. | ||||
* | Were looking at the wrong C++ variable. | Joel Sherrill | 1998-03-30 | 1 | -1/+1 |
* | Moved bsp_postdriver_hook() to a shared file and made it a common | Joel Sherrill | 1998-03-30 | 47 | -666/+118 |
| | | | | component. | ||||
* | Renamed crt0.o to crt0_go32.o to avoid build problems. | Joel Sherrill | 1998-03-30 | 1 | -1/+1 |
* | Update from "erik.ivanenko" <erik.ivanenko@utoronto.ca>. | Joel Sherrill | 1998-03-30 | 12 | -130/+1432 |
| | | | | | Also removed bsp_postdriver_hook() from every bsp possible and moved to shared version. | ||||
* | GO32 does not have sockets. | Joel Sherrill | 1998-03-27 | 1 | -0/+2 |
* | Changed int to unsigned32 to match cpu.h. | Joel Sherrill | 1998-03-27 | 1 | -1/+1 |
* | Should have included <rtems.h> before checking for ifdef RTEMS_UNIX. | Joel Sherrill | 1998-03-27 | 2 | -4/+4 |
| | | | | Bug report from Olivier Hainque <hainque@inf.enst.fr> on SPARC Solaris 2.6. | ||||
* | HAS_CPLUSPLUS should have been RTEMS_HAS_CPLUSPLUS. | Joel Sherrill | 1998-03-26 | 1 | -1/+1 |
* | Moved memcpy to newlib/libc/machine/m68k | Joel Sherrill | 1998-03-25 | 1 | -1/+1 |
* | m68k software interrupt stack support from Chris Johns and Eric Norum. | Joel Sherrill | 1998-03-25 | 5 | -36/+40 |
* | Corrected argument passing. | Joel Sherrill | 1998-03-25 | 1 | -3/+2 |
* | Corrected definition of main and boot_card to be more ANSI compliant. | Joel Sherrill | 1998-03-25 | 1 | -3/+5 |
* | Corrected invocation of boot_card(). | Joel Sherrill | 1998-03-25 | 1 | -4/+6 |
* | Added _XOPEN_SOURCE definition to allow use of UNIX IPC. | Joel Sherrill | 1998-03-24 | 1 | -0/+1 |
* | changed version to 4.0.0-beta1 | Joel Sherrill | 1998-03-24 | 2 | -2/+2 |
* | Real definition for the beginning of the data section per Eric Norum's | Joel Sherrill | 1998-03-24 | 1 | -2/+2 |
| | | | | suggestion. | ||||
* | Corrected register constraints per suggestion from Thomas Doerfler, IMD | Joel Sherrill | 1998-03-24 | 2 | -6/+6 |
| | | | | <td@imd.m.isar.de>. | ||||
* | More cpu model flags converted to using cpp predefines. | Joel Sherrill | 1998-03-24 | 1 | -2/+2 |
* | Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for | Joel Sherrill | 1998-03-24 | 12 | -50/+48 |
| | | | | the CPU family name constants. | ||||
* | new file | Joel Sherrill | 1998-03-24 | 1 | -0/+54 |
* | Renamed hppa1_1 to hppa1.1 | Joel Sherrill | 1998-03-23 | 1 | -4/+1 |
* | renamed ppc to powerpc | Joel Sherrill | 1998-03-23 | 1 | -1/+0 |
