* cpu.c: Spacing issues.
* rtems/score/cpu.h: Removed warning by setting _level.
2000-08-29 Joel Sherrill <joel.sherrill@OARcorp.com>
* Makefile.am: Added S_O_FILES to list of objects.
* include/mvme16x_hw.h: Added NVRAM_CONFIGURE macro in
a manner that should work for 162, 162lx, and 167.
* include/rtems/system.h: Include cpuopts.h for __i386__.
* rtems/score/i386.h: cpu-variant define handling
Rewrite due to introduction of multilib defines.
* asm.h: include cpuopts.h instead of targopts.h
* mpc8xx/console-generic/console-generic.c:
Add support for configuration parameters in NVRAM
* README:
* console/console.c:
* include/bsp.h:
* network/network.c:
* startup/bspstart.c:
* ChangeLog: File paths corrected.
* rtems/score/no_cpu.h: Modified so there are fewer and
more consistent variations on "no cpu" so it is easier
to sed the source as the starting point for a new port.
* inline/rtems/posix/timer.inl, include/rtems/posix/timer.h,
inline/rtems/posix/Makefile.am, src/ptimer1.c: Redid the
style of src/ptimer1.c. Continued effort to make the
POSIX Timer implementation match that of other managers.
Added data structures required to use SuperCore Object Handler.
* libc/fs_null_handlers.c: Added missing rmnod entry.
* libc/isatty.c, libc/imfs_handlers_directory.c, libc/creat.c,
libc/imfs_directory.c: Fixed style issues.
* src/ptimer1.c: Minor formatting fixes.
* src/ptimer1.c: Removed unused routine PRINT_ERRNO_S.
* src/ptimer1.c: Removed unnecessary routine COPY_ITIMERSPEC_S
and used structure copy instead.
* src/ptimer1.c: Renamed timer_alive_t to POSIX_Timer_Control.
* include/rtems/posix/timer.h: Ditto.
* posix/src/ptimer1.c: Switched to using set_errno_and_return_minus_one()
to ensure that errno was always set.
* posix/src/ptimer1.c (timer_settime): Converted use of rtems_clock_get
to use SuperCore _TOD_Current variable.
* Shell added for or32 port based on no_cpu port with names replaced.
* Shell added for or16 port based on no_cpu port with names replaced.
* libc/eval.c: Ditto.
* libc/fcntl.c: Ditto.
* libc/fsync.c: Ditto.
* libc/ioctl.c: Ditto.
* libc/ioman.c: Ditto.
* libc/link.c: Ditto.
* libc/memfile.c: Ditto.
* libc/mknod.c: Ditto.
* libc/symlink.c: Ditto.
* console/console.c: Fix polled input.
* console.c(_BSP_output_char): Output CR after LF for printk.
* README: Updated
Add support for shared printk.
Add support for more flexible polled I/O with and without termios.
I/O mode and console is selectable either from NVRAM or from
mvme167.cfg. Clean up comments.
* README: Updated
2000-08-11 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>
* startup/page_table.c (page_table_init): Reorganize NVRAM parameters.
* include/bsp.h: Reorganize NVRAM parameters.
* times: These are the times for the MVME167, not the MBX860-002.
2000-08-11 John Cotton <john.cotton@nrc.ca>
* network/network.c: Fix NVRAM configuration parameter
handling from previous revision.
Check J1-4, restructure NVRAM parameter handling.
* network/network.c: Cleanup of network driver to reduce warnings.
Addition of second parameter to uti596_attach.
* README: Updated.
* console/console.c: Addition of support for shared printk and
no termios.
* include/bsp.h: Addition of second parameter to
rtems_enet_driver_attach. Removed prototypes for printk and
BSP_output_string.
* network/network.c(rtems_enet_driver_attach): Addition of second
parameter to function.
* console-generic/console-generic.c: Addition of support for shared
printk and no termios.
2000-08-10 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>
* console-generic/console-generic.c(m8xx_uart_pollWrite):
Flush actual buffer.
* shared/src/cache_manager.c (rtems_cache_flush_multiple_data_lines,
rtems_cache_invalidate_multiple_data_lines): Do not operate on the
entire address space when flushing zero bytes.
-4 = {d = -4, i = {0xc0100000, 0x0}} s=1 e=0x80 m=0x100000 (0x0900000)
-3 = {d = -3, i = {0xc0080000, 0x0}} s=1 e=0x80 m=0x080000 (0x0880000)
-2 = {d = -2, i = {0xc0000000, 0x0}} s=1 e=0x80 m=0x000000 (0x0800000)
-1 = {d = -1, i = {0xbff00000, 0x0}} s=1 e=0x7f m=0x000000 (0x0800000)
0 = {d = 0, i = {0x00000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
1 = {d = 1, i = {0x3ff00000, 0x0}} s=0 e=0x7f m=0x000000 (0x0800000)
2 = {d = 2, i = {0x40000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
3 = {d = 3, i = {0x40080000, 0x0}} s=0 e=0 m=0x080000 (0x0880000)
C4X
-4 = {d = -4, i = {0x01800000, 0x0}} s=1 e=1 m=0x800000 (0x1000000)
-3 = {d = -3, i = {0x01c00000, 0x0}} s=1 e=1 m=0xa00000 (0x1400000)
-2 = {d = -2, i = {0x00800000, 0x0}} s=1 e=0 m=0x800000 (0x1000000)
-1 = {d = -1, i = {0xff800000, 0x0}} s=1 e=0xff m=0x000000 (0x1000000)
0 = {d = 0, i = {0x80000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
1 = {d = 1, i = {0x00000000, 0x0}} s=0 e=0x7f m=0x000000 (0x0800000)
2 = {d = 2, i = {0x01000000, 0x0}} s=0 e=1 m=0x400000 (0x0800000)
3 = {d = 3, i = {0x01400000, 0x0}} s=0 e=1 m=0x600000 (0x0c00000)
4 = {d = 4, i = {0x02000000, 0x0}} s=0 e=2 m=0xXXXXXX (0x0000000)
0x1010 0000
0101 0000
0010 1002
fast mutexes that bypass the API level to directly interface with the
SuperCore.
to driver attach routine.
alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
in ROM.
is available.
the correct circumstances of DMA buffer size, serial
line interrupts, and ethernet interrupts the termios osend routine would
lock up waiting for the raw output buffer semaphore.
that switches the sparc from targopts.h to cpuopts.h.
