* | libchip/serial/z85c30.c: Remove redundant assignment | Josh Oguin | 2014-11-26 | 1 | -1/+0 |
| | | | | This was flagged by CodeSonar. | ||||
* | libchip/serial/ns16550* and z8530*: Assert on baud number to avoid divide by 0 | Josh Oguin | 2014-11-26 | 3 | -1/+14 |
| | | | | | | This was flagged by CodeSonar. It should be impossible to get an incorrect baud number back but ensure this in debug mode. The _Assert() keeps their scanner from evaluating for divide by 0 past this point. | ||||
* | libchip/display/disp_hcms29xx.c: Remove useless variable and check | Josh Oguin | 2014-11-26 | 1 | -6/+1 |
* | libbsp/shared/bspinit.c: Document assumption of NULL returned | Josh Oguin | 2014-11-26 | 1 | -12/+12 |
* | rtems: Move rtems_cache_aligned_malloc() | Sebastian Huber | 2014-11-25 | 12 | -55/+7 |
| | | | | | | Make sure also the size is cache aligned since otherwise we may have some overlap with the next allocation block. A cache invalidate on this area would be fatal. | ||||
* | bsps/arm: L2C 310 avoid infinite loops | Sebastian Huber | 2014-11-25 | 1 | -0/+8 |
* | bsp/ngmp: Use -muser-mode GCC option | Sebastian Huber | 2014-11-24 | 1 | -1/+1 |
| | | | | | This option is necessary to use the latest GCC 4.8, 4.9 and 5.0 versions. | ||||
* | leon2: include <rtems/ringbuf.h> not <ringbuf.h> | Joel Sherrill | 2014-11-23 | 1 | -2/+2 |
| | | | | close #2113 | ||||
* | powerpc/haleakala: Fix warnings | Joel Sherrill | 2014-11-21 | 2 | -1110/+1119 |
* | powerpc/haleakala: Add network driver | Nigel Spon | 2014-11-21 | 9 | -42/+1845 |
| | | | | close 1405 | ||||
* | Delete or rename MIN/MAX macros and defines | Sebastian Huber | 2014-11-21 | 3 | -6/+2 |
| | | | | Include <sys/param.h> if necessary to get the MIN()/MAX() macros. | ||||
* | autotools: regenerate preinstall.am for pc386 | Gedare Bloom | 2014-11-20 | 1 | -1/+2 |
* | i386/pc386: VESA based frame buffer utilizing real mode interrupt 10h | Jan Dolezal | 2014-11-20 | 6 | -0/+1021 |
* | i386/pc386/include: header files for VESA BIOS EXTENSIONS and VESA Extended ↵ | Jan Dolezal | 2014-11-20 | 4 | -0/+986 |
| | | | | Display Identification Data | ||||
* | i386/shared/realmode_int: real mode interrupt interface | Jan Dolezal | 2014-11-20 | 4 | -0/+497 |
* | i386: global descriptor table manipulation functions | Jan Dolezal | 2014-11-20 | 2 | -40/+207 |
* | i386: GDTR manipulation functions parameters changed to use explicit width types | Jan Dolezal | 2014-11-20 | 2 | -5/+7 |
* | i386/pc386: configurable size of descriptor tables | Jan Dolezal | 2014-11-20 | 6 | -8/+51 |
* | bsps/arm: Enable L2C for Cortex-A9 MPCore BSPs | Sebastian Huber | 2014-11-20 | 11 | -65/+98 |
* | bsps/arm: L2C 310 drop exclusive cache support | Sebastian Huber | 2014-11-20 | 1 | -71/+50 |
| | | | | Optimize locking. | ||||
* | bsps/arm: L1 cache support changes | Sebastian Huber | 2014-11-20 | 1 | -16/+21 |
* | bsps/arm: L2C 310 compile-time errata 588369 | Sebastian Huber | 2014-11-20 | 1 | -49/+19 |
* | bsps/arm: L2C 310 compile-time errata 753970 | Sebastian Huber | 2014-11-20 | 1 | -71/+43 |
* | bsps/arm: L2C 310 exclusive config is fatal | Sebastian Huber | 2014-11-20 | 2 | -8/+18 |
* | bsps/arm: L2C 310 use l2c_310_* prefix throughout | Sebastian Huber | 2014-11-20 | 1 | -99/+99 |
* | bsps/arm: L2C 310 use L2C_310_* prefix throughout | Sebastian Huber | 2014-11-20 | 1 | -232/+232 |
* | bsps/arm: L2C 310 add compile time checks | Sebastian Huber | 2014-11-20 | 4 | -85/+80 |
| | | | | Simplify initialization. Replace some assert() with fatal errors. | ||||
* | bsps/arm: L2C 310 delete invalid link | Sebastian Huber | 2014-11-20 | 1 | -2/+0 |
* | bsps/arm: L2C 310 simplify and remove white space | Sebastian Huber | 2014-11-20 | 1 | -292/+177 |
* | bsps/arm: L2C 310 rename BSP_ARM_L2CC_BASE | Sebastian Huber | 2014-11-20 | 3 | -28/+28 |
| | | | | Rename BSP_ARM_L2CC_BASE to BSP_ARM_L2C_310_BASE. | ||||
* | bsp/xilinx-zynq: Add Cadence I2C bus driver | Sebastian Huber | 2014-11-20 | 6 | -0/+645 |
* | bsp/xilinx-zynq: Add zync_clock_cpu_1x() | Sebastian Huber | 2014-11-20 | 3 | -2/+14 |
* | bsp/xilinx-zynq: Rename BSP_ARM_A9MPCORE_UARTCLK | Sebastian Huber | 2014-11-20 | 2 | -5/+5 |
| | | | | | Rename BSP_ARM_A9MPCORE_UARTCLK to ZYNQ_CLOCK_UART since this clock has nothing to do with the Cortex-A9 MPCore. | ||||
* | bsp/xilinx-zynq: Adjust BSP_ARM_A9MPCORE_PERIPHCLK | Sebastian Huber | 2014-11-20 | 1 | -1/+1 |
* | bsps/arm: Adjust stacks for ARMv4 | Sebastian Huber | 2014-11-20 | 2 | -19/+7 |
| | | | | | | | | Reduce non-IRQ stacks to size zero. All non-IRQ stacks overlap now the IRQ stack. This is all right since the SVC stack is used only during startup and here interrupts are disabled. The other exception stacks lead to a system termination by default, so we can here also use the IRQ stack since interrupts are disabled on exception entry. | ||||
* | ARM removed shared/abort from several ARM BSPs | Alan Cudmore | 2014-11-20 | 6 | -54/+55 |
* | lpc23xx_tli800-testsuite.tcfg: Add dl02 | Joel Sherrill | 2014-11-05 | 1 | -0/+1 |
* | lpc2362-testsuite.tcfg: Add dl02 | Joel Sherrill | 2014-11-05 | 1 | -0/+1 |
* | lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add a handful more tests | Joel Sherrill | 2014-11-05 | 1 | -0/+8 |
* | lm3s3749-testsuite.tcfg: Add dl02 | Joel Sherrill | 2014-11-05 | 1 | -0/+1 |
* | lpc23xx_tli800-testsuite.tcfg: Add dl01 | Joel Sherrill | 2014-11-04 | 1 | -0/+1 |
* | lpc2362-testsuite.tcfg: Add dl01 | Joel Sherrill | 2014-11-04 | 1 | -0/+1 |
* | lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add rbheap01 | Joel Sherrill | 2014-11-04 | 1 | -0/+1 |
* | lm3s3749-testsuite.tcfg: Add dl01 | Joel Sherrill | 2014-11-04 | 1 | -0/+1 |
* | Regenerated preinstall.am file. | Chris Johns | 2014-11-04 | 1 | -0/+1 |
* | BSP for several Beagle products | Ben Gras | 2014-11-03 | 36 | -3221/+1485 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Specifically the beagleboard, beagleboard xM, beaglebone, beaglebone black. More info on these targets: http://www.beagleboard.org/ This commit forms a basic BSP by combining Claas's work with . new clock and irq code and definitions for beagle targets (beagleboard and beaglebones), mostly reused from the Minix codebase, thus making irqs, ticks and non-polled console mode work too . new timer code for ns timing with high timer resolution, 24MHz on the AM335X and 13MHz on the DM37XX . select the console uart based on target at configure time . removing all the lpc32xx-specific macros and code and other unused code and definitions that the beagle bsp was based on . re-using some standard functions instead of lpc32xx versions . fixed some whitespace problem in preinstall.am . fixed some compile warnings . configure MMU: set 1MB sections directly in the TTBR, just to show the difference between cacheable RAM and non-cacheable device memory and invalid ranges; this lets us turn on caches and not rely on boot loader MMU configuration. Verified to work when MMU is initially either on or off when RTEMS gets control. Thanks for testing, commentary, improvements and fixes to Chris Johns, Brandon Matthews, Matt Carberry, Romain Bornet, AZ technology and others. Signed-Off-By: Ben Gras <beng@shrike-systems.com> | ||||
* | Added BeagleBoard BSP | Claas Ziemke | 2014-11-03 | 29 | -0/+4596 |
| | | | | | | | Coding done in course of GSoC2012. Commit edited to be brought up-to-date with mainline by Ben Gras <beng@shrike-systems.com>. | ||||
* | Add some generic ARM am335x and omap definitions | Ben Gras | 2014-11-03 | 3 | -0/+692 |
* | libcpu/bfin/clock/tod.h: Delete - missed on previous commits | Joel Sherrill | 2014-10-31 | 1 | -61/+0 |
* | bsp/mpc55xxevb: Fix flash settings for MPC5510 | Sebastian Huber | 2014-10-31 | 2 | -23/+45 |
