* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 3 | -9/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 47 | -127/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -6/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 109 | -217/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 6 | -16/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 6 | -18/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 10 | -30/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 36 | -111/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 4 | -12/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 13 | -42/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 48 | -144/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 5 | -14/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 8 | -25/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 20 | -68/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -8/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -7/+0 |
* | nds/linkcmds - Remove execute permission | Joel Sherrill | 2012-05-03 | 1 | -0/+0 |
* | libcpu misc m68k and sh - Correct formatting and remove weird Id strings | Joel Sherrill | 2012-05-03 | 6 | -59/+41 |
* | General - Remove extraneous blank line in license message | Joel Sherrill | 2012-05-03 | 98 | -85/+0 |
| | | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | ||||
* | Libcpu misc files - Remove execute permission on source files. | Joel Sherrill | 2012-05-03 | 10 | -0/+0 |
* | rtems-message_queue.adb - Convert DOS to UNIX CF/LF | Joel Sherrill | 2012-05-03 | 1 | -245/+245 |
* | smdk2410 - Remove odd $Id$ | Joel Sherrill | 2012-05-02 | 1 | -2/+0 |
* | gp32 - Remove odd $Id$ | Joel Sherrill | 2012-05-02 | 1 | -3/+0 |
* | pc386 - Remove odd $Id$ | Joel Sherrill | 2012-05-02 | 7 | -14/+0 |
* | libchip hcms29xx - Remove odd $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 5 | -17/+1 |
* | score603e - Remove bad $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 1 | -4/+6 |
* | libcpu/m68k/mcf532x - Remove bad $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 1 | -3/+3 |
* | libchip z85c30 - Remove bad $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 1 | -4/+6 |
* | LEON3 - Remove bad $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 1 | -4/+6 |
* | LEON2 - Remove bad $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 1 | -4/+6 |
* | MRM332 - Remove incorrect $Id$ string and correct file header | Joel Sherrill | 2012-05-02 | 2 | -2/+26 |
* | bsps/stackalloc: Add initialization hook | Sebastian Huber | 2012-04-26 | 2 | -16/+23 |
* | bsp/mpc55xxevb: Enable stack allocator | Sebastian Huber | 2012-04-24 | 6 | -4/+10 |
* | bsps/stackalloc: Use stack section symbols | Sebastian Huber | 2012-04-24 | 5 | -55/+26 |
