* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* start/.cvsignore: Remove.
* ACKNOWLEDGEMENTS: Remove efi68k and efi332 references as they are no
longer in the tree.
* times, console/sci.c: Remove efi68k and efi332 references as they are
no longer in the tree.
* acinclude.m4: Remove efi68k and efi332 references as they are no
longer in the tree.
* timer/timer.c: Remove efi68k and efi332 references as they are no
longer in the tree.
Per John S. Gwynne <jgwynne@mrcday.com>, there are no longer any
users of these boards so we are removing them.
* efi332/.cvsignore, efi332/ChangeLog, efi332/Makefile.am,
efi332/README, efi332/bsp_specs, efi332/configure.ac, efi332/times,
efi332/clock/.cvsignore, efi332/clock/Makefile.am,
efi332/clock/ckinit.c, efi332/console/.cvsignore,
efi332/console/Makefile.am, efi332/console/console.c,
efi332/include/.cvsignore, efi332/include/bsp.h,
efi332/include/efi332.h, efi332/misc/dotests, efi332/misc/gdbinit68,
efi332/misc/interr.c, efi332/spurious/.cvsignore,
efi332/spurious/Makefile.am, efi332/spurious/spinit.c,
efi332/start/.cvsignore, efi332/start/Makefile.am,
efi332/start/except_vect_332_ROM.S, efi332/start/ram_init.ld,
efi332/start/ram_init.sed, efi332/start/start.c,
efi332/startup/.cvsignore, efi332/startup/Makefile.am,
efi332/startup/bspclean.c, efi332/startup/bspstart.c,
efi332/startup/linkcmds, efi332/startup/linkcmds_ROM,
efi332/timer/.cvsignore, efi332/timer/Makefile.am,
efi332/timer/timer.c, efi332/wrapup/.cvsignore,
efi332/wrapup/Makefile.am, efi68k/.cvsignore, efi68k/ChangeLog,
efi68k/Makefile.am, efi68k/README, efi68k/bsp_specs,
efi68k/configure.ac, efi68k/times, efi68k/clock/.cvsignore,
efi68k/clock/Makefile.am, efi68k/clock/ckinit.c,
efi68k/console/.cvsignore, efi68k/console/Makefile.am,
efi68k/console/console.c, efi68k/include/.cvsignore,
efi68k/include/16550.h, efi68k/include/DP8570A.h,
efi68k/include/bsp.h, efi68k/include/efi68k.h,
efi68k/spurious/.cvsignore, efi68k/spurious/Makefile.am,
efi68k/spurious/spinit.c, efi68k/start/.cvsignore,
efi68k/start/start.c, efi68k/startup/.cvsignore,
efi68k/startup/Makefile.am, efi68k/startup/bspclean.c,
efi68k/startup/bspstart.c, efi68k/startup/efi68k_tcp.c,
efi68k/startup/efi68k_wd.c, efi68k/startup/linkcmds,
efi68k/startup/m68k-stub.c, efi68k/startup/setvec.c,
efi68k/timer/.cvsignore, efi68k/timer/Makefile.am,
efi68k/timer/timer.c, efi68k/wrapup/.cvsignore,
efi68k/wrapup/Makefile.am: Removed.
* aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port
more completely covers the MIPS family.
* mips64orion/.cvsignore, mips64orion/ChangeLog,
mips64orion/Makefile.am, mips64orion/configure.ac,
mips64orion/clock/.cvsignore, mips64orion/clock/Makefile.am,
mips64orion/clock/ckinit.c, mips64orion/clock/clock.S,
mips64orion/clock/clock.h, mips64orion/timer/.cvsignore,
mips64orion/timer/Makefile.am, mips64orion/timer/gettime.S,
mips64orion/timer/timer.c: Removed.
mips64orion/Makefile.am, mips64orion/README,
mips64orion/acinclude.m4, mips64orion/configure.ac,
mips64orion/p4000/.cvsignore, mips64orion/p4000/ChangeLog,
mips64orion/p4000/Makefile.am, mips64orion/p4000/README,
mips64orion/p4000/bsp_specs, mips64orion/p4000/configure.ac,
mips64orion/p4000/times, mips64orion/p4000/console/.cvsignore,
mips64orion/p4000/console/Makefile.am,
mips64orion/p4000/console/console.c, mips64orion/p4000/console/led.S,
mips64orion/p4000/include/.cvsignore,
mips64orion/p4000/include/bsp.h, mips64orion/p4000/include/coverhd.h,
mips64orion/p4000/liblnk/.cvsignore,
mips64orion/p4000/liblnk/Makefile.am,
mips64orion/p4000/liblnk/lnklib.S,
mips64orion/p4000/start/.cvsignore,
mips64orion/p4000/start/Makefile.am, mips64orion/p4000/start/start.S,
mips64orion/p4000/startup/.cvsignore,
mips64orion/p4000/startup/Makefile.am,
mips64orion/p4000/startup/bspclean.c,
mips64orion/p4000/startup/bspstart.c,
mips64orion/p4000/startup/ghlinkcmds,
mips64orion/p4000/startup/idtmem.S,
mips64orion/p4000/startup/idttlb.S,
mips64orion/p4000/startup/inittlb.c,
mips64orion/p4000/startup/linkcmds,
mips64orion/p4000/startup/setvec.c,
mips64orion/p4000/wrapup/.cvsignore,
mips64orion/p4000/wrapup/Makefile.am: Removed.
* Makefile.am: Regenerate.
* start/regs.S: Remove.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* tod/Makefile.am: Cosmetics.
* console/Makefile.am: Eliminate *.rel.
Use $(top_srcdir)/../../shared instead of ../../../shared.
* start/Makefile.am: Add BUILD-VARIANTS.
* vectors/Makefile.am: Fix typos.
* vme/Makefile.am: Fix typos.
* PCI_bus/Makefile.am: Eliminate VPATH.
* clock/Makefile.am: Eliminate VPATH.
* console/Makefile.am: Eliminate VPATH.
* start/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
* timer/Makefile.am: Eliminate VPATH.
* tod/Makefile.am: Eliminate VPATH.
* vectors/Makefile.am: Eliminate VPATH.
* shmsupp/Makefile.am: Eliminate VPATH.
* network/Makefile.am: Eliminate VPATH.
* nvram/Makefile.am: Eliminate VPATH.
* pci/Makefile.am: Eliminate VPATH.
* universe/Makefile.am: Eliminate VPATH.
* irq/Makefile.am: Eliminate VPATH.
* bootloader/Makefile.am: Eliminate VPATH.
* motorola/Makefile.am: Eliminate VPATH.
* openpic/Makefile.am: Eliminate VPATH.
* residual/Makefile.am: Eliminate VPATH.
* vme/Makefile.am: Eliminate VPATH.
* ide/Makefile.am: Eliminate VPATH.
* dlentry/Makefile.am: Eliminate VPATH.
* flashentry/Makefile.am: Eliminate VPATH.
* canbus/Makefile.am: Eliminate VPATH.
* scv64/Makefile.am: Eliminate VPATH.
* sonic/Makefile.am: Eliminate VPATH.
PR 545/bsps
* startup/setvec.c: Removed.
PR 545/bsps
* ppc403/Makefile.am: Fix typo in vectors' compilation rule.
* shared/Makefile.am: Use $(top_srcdir)/../shared instead of
relative subdirs.
PR 545/bsps
* wrapup/Makefile.am: Reflect changes to shmdr.
* shmdr/addlq.c, shmdr/cnvpkt.c, shmdr/dump.c, shmdr/fatal.c,
shmdr/getlq.c, shmdr/getpkt.c, shmdr/init.c, shmdr/initlq.c,
shmdr/intr.c, shmdr/mpci.h, shmdr/mpisr.c, shmdr/poll.c,
shmdr/README, shmdr/receive.c, shmdr/retpkt.c, shmdr/send.c,
shmdr/setckvec.c, shmdr/shm_driver.h: Remove (Moved to
c/src/libchip/shmdr).
2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bspstart.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Remove shmdr.
2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Use $(mkdir_p) instead of $(mkinstalldirs).
2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Use mkdir_p.
Remove dirs from PRE/TMPINSTALL_FILES.
* bsp.am: Replace bsplibdir by project_libdir.
Use mkdir_p instead of mkinstalldirs.
2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Remove project_libdir.
* Makefile.am: Misc. fixes.
* bsp.am: Add project_libdir.
2003-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bspstart.am: New.
2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Merge-in shared/Makefile.am, shmdr/Makefile.am.
* shared/Makefile.am: Remove.
* shmdir/Makefile.am: Remove.
* bsp.am: Add preinstallation dirstamp support.
2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Remove all-local: $(ARCH).
2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Reworked.
2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Reflect having moved automake/.
* shmdr/Makefile.am: Reflect having moved automake/.
2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Reflect having merged configure.ac into
../../configure.ac.
* configure.ac: Remove (Merged into ../../configure.ac).
* Makefile.am: Reflect having merged configure.ac into
../../configure.ac.
2003-03-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: Remove AC_CONFIG_AUX_DIR.
2003-02-14 Joel Sherrill <joel@OARcorp.com>
AMD a29k port declared obsolete.
* a29k/.cvsignore, a29k/ChangeLog, a29k/Makefile.am, a29k/acinclude.m4,
a29k/configure.ac, a29k/portsw/.cvsignore, a29k/portsw/ChangeLog,
a29k/portsw/Makefile.am, a29k/portsw/README, a29k/portsw/bsp_specs,
a29k/portsw/configure.ac, a29k/portsw/times,
a29k/portsw/console/.cvsignore, a29k/portsw/console/Makefile.am,
a29k/portsw/console/concntl.h, a29k/portsw/console/console.c,
a29k/portsw/console/serial.c, a29k/portsw/console/serial.h,
a29k/portsw/include/.cvsignore, a29k/portsw/include/Makefile.am,
a29k/portsw/include/bsp.h, a29k/portsw/start/.cvsignore,
a29k/portsw/start/Makefile.am, a29k/portsw/start/amd.ah,
a29k/portsw/start/pswmacro.ah, a29k/portsw/start/register.S,
a29k/portsw/start/register.ah, a29k/portsw/start/start.S,
a29k/portsw/startup/.cvsignore, a29k/portsw/startup/Makefile.am,
a29k/portsw/startup/bspclean.c, a29k/portsw/startup/bspstart.c,
a29k/portsw/startup/linkcmds, a29k/portsw/startup/main.c,
a29k/portsw/startup/ramlink, a29k/portsw/startup/romlink,
a29k/portsw/startup/setvec.c, a29k/portsw/wrapup/.cvsignore,
a29k/portsw/wrapup/Makefile.am: Removed.
2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2003-02-03 Joel Sherrill <joel@OARcorp.com>
* shmdr/Makefile.am: Add .h files to PREINSTALL_FILES not
TMPINSTALL_FILES.
2003-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: install mpci.h and shm_driver.h.
Eliminate OBJS.
2003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Don't include @RTEMS_BSP@.cfg.
2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Use .$(OBJEXT) instead of .o.
2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/.cvsignore: Remove.
* include/rtems/.cvsignore: Remove.
* include/rtems/score/Makefile.am: Remove.
* include/rtems/score/.cvsignore: Remove.
* configure.ac: Remove RTEMS_BSP_ALIAS.
Add RTEMS_CHECK_BSP_CACHE.
Replace $bspdir with $RTEMS_BSP_FAMILY.
* configure.ac: Remove include/Makefile, include/rtems/Makefile,
include/rtems/score/Makefile (Eliminate targopts.h).
* Makefile.am: Remove include from SUBDIRS (Eliminate targopts.h)
2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Add bsplib_DATA = bsp_specs.
2002-06-25 Joel Sherrill <joel@OARcorp.com>
* Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k
support to the shared gdb stub glue thus adding a directory at the
top shared level.
* shared/gdbstub: New directory.
* configure.ac: Modified to reflect above.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rtems/score/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rtems/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shmdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Add line break, remove comment.
2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Use @subdirs@ instead of RTEMS_LIBBSP_CPU_SUBDIR.
* configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS, remove
2001-09-28 Joel Sherrill <joel@OARcorp.com>
* shared/bootcard.c, shared/main.c: Now call int c_rtems_main()
not main().
2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='.
* shmdr/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Use SUBDIRS = instead of SUBDIRS += to make
automake-1.5 happy.
* include/rtems/score/Makefile.am: Use CLEANFILES = to make
automake-1.5 happy.
* bsp.am: Use PREINSTALL_FILES = to make automake-1.5 happy.
2001-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Fix automake version number in comment.
2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-09-25 Joel Sherrill <joel@OARcorp.com>
* shmdr/shm_driver.h: Added _AM29K entry. May not be correct.
2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Include compile.am
2000-08-10 Joel Sherrill <joel@OARcorp.com>
* ChangeLog: New file.
* wrapup/Makefile.am: Remove GENERIC_FILES.
* Makefile.am: Add shmdr. Use noinst_DATA instead of TMP_LIBS.
shmdr/setckvec.c, shmdr/shm_driver.h: Copied from libbsp/shmdr.
* aclocal/version.m4: Updated to rtems-20031217-test.
* c/src/aclocal/version.m4: Updated to rtems-20031217-test.
