* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 3 | -4/+8 |
| | | | | * startup/bspclean.c, timer/timer.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 2 | -3/+6 |
| | | | | * startup/init5235.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 3 | -2/+7 |
| | | | | * console/leds.c, timer/timer.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 3 | -1/+7 |
| | | | | * console/m340uart.c, startup/init68340.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 3 | -4/+11 |
| | | | | * startup/init68360.c, timer/timer.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 2 | -6/+6 |
| | | | | * shared/gdbstub/mips-stub.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 2 | -1/+4 |
| | | | | * gdbstub/rtems-stub-glue.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 2 | -7/+9 |
| | | | | * mongoosev/duart/mg5uart.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 2 | -0/+5 |
| | | | | * startup/linkcmds: Needed to be assigned to a memory region. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 6 | -23/+36 |
| | | | | | | * shared/bootloader/em86.c, shared/bootloader/mm.c, shared/console/polled_io.c, shared/irq/irq_init.c, shared/startup/bspstart.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 5 | -60/+60 |
| | | | | | * mpc5xx/clock/clock.c, mpc5xx/console-generic/console-generic.c, mpc5xx/irq/irq_init.c, mpc5xx/timer/timer.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 4 | -18/+21 |
| | | | | * irq/irq.h, startup/iss555.c, startup/tm27supp.c: Remove warnings. | ||||
| | | | | * libchip/network/if_dc.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 3 | -6/+11 |
| | | | | * network/xiltemac.c, startup/bspstart.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 3 | -8/+12 |
| | | | | * startup/bspclean.c, startup/bspstart.c: Remove warnings. | ||||
* | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-27 | 2 | -16/+5 |
| | | | | * startup/init5206e.c: Remove warnings. | ||||
* | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-27 | 2 | -19/+9 |
| | | | | * startup/init5272.c: Remove warnings. | ||||
* | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-27 | 2 | -112/+116 |
| | | | | * network/network.c: Remove warnings. | ||||
* | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-27 | 3 | -64/+105 |
| | | | | | * network/network.c, startup/bspstart.c: Remove warnings. hwaddr handling changed to avoid use of unitialized variable. | ||||
* | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-27 | 4 | -65/+72 |
| | | | | | * network/network.c, startup/bspclean.c, startup/init5282.c: Remove warnings. | ||||
* | 2010-04-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-27 | 10 | -13/+32 |
| | | | | | * startup/linkcmds: Revert previous change. Remove .reginfo from .bss section where it was present. | ||||
* | 2010-04-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-27 | 3 | -3/+7 |
| | | | | | * start/start.S, startup/linkcmds: Revert previous change. Remove .reginfo from .bss section where it was present. | ||||
* | * startup/bspstart.c: Clean up some warnings. | Eric Norum | 2010-04-26 | 3 | -4/+10 |
| | | | | * network/network.c: Fix up full/half duplex printout and some warnings. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-26 | 2 | -2/+6 |
| | | | | * console/uart.c: Fix warnings. | ||||
| | | | | * console/console.c: Fix warnings. | ||||
| | | | | * console/fbcons.c: Fix warnings. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-26 | 2 | -1/+6 |
| | | | | * network/network.c: Fix warning. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-26 | 2 | -2/+7 |
| | | | | * startup/bspstart.c: Fix warning. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-26 | 2 | -4/+8 |
| | | | | * console/console.c: Fix prototypes. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-26 | 7 | -20/+27 |
| | | | | | | | * libchip/serial/mc68681.c, libchip/serial/mc68681_reg.c, libchip/serial/ns16550.c, libchip/serial/serial.h, libchip/serial/z85c30.c, libchip/serial/z85c30_reg.c: Use uintptr_t or intptr_t instead of uint32_t or int32_t. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-25 | 5 | -8/+16 |
| | | | | | * console/console.c, ide/pcmcia_ide.c, startup/bspstart.c, startup/imbx8xx.c: Fix some warnings. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-25 | 7 | -24/+30 |
| | | | | | | | * libchip/rtc/ds1375-rtc.h, libchip/rtc/ds1375.c, libchip/rtc/icm7170.c, libchip/rtc/icm7170_reg.c, libchip/rtc/m48t08_reg.c, libchip/rtc/rtc.h: Use uintptr_t instead of uint32_t. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-25 | 12 | -8/+34 |
| | | | | * startup/linkcmds: Add NOLOAD to .bss to eliminate warnings. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-25 | 4 | -139/+49 |
| | | | | | | * ppc403/clock/clock.c, ppc403/console/console405.c, ppc403/tty_drv/tty_drv.c: Remove warnings and simple vectored interrupt support. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-25 | 2 | -2/+5 |
| | | | | * console/consolebsp.h: Remove extraneous #warning. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-25 | 2 | -1/+5 |
| | | | | * bsp_specs: Remove warning on __start not found. | ||||
| | | | | * bsp_specs: Remove extra } to eliminate warning. | ||||
* | 2010-04-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-24 | 10 | -23/+20 |
| | | | | * start/start.S: Verify boot_card is invoked properly with argc, argv. | ||||
* | 2010-04-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-20 | 2 | -4/+8 |
| | | | | * console/console.c: Reflect termios-API having changed. | ||||
* | 2010-04-18 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-18 | 3 | -0/+16 |
| | | | | * .cvsignore, include/.cvsignore: New files. | ||||
* | 2010-04-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-15 | 4 | -131/+169 |
| | | | | | * cpuModel.S, cpuModel.h, displayCpu.c: Update to include more reserved bits and pick out a bit more information. | ||||
* | 2010-04-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-15 | 1 | -0/+5 |
| | | | | | * sh7045/include/sci_termios.h, sh7045/sci/sci.c, sh7045/sci/sci_termios.c: Reflect termios API changes. | ||||
* | Reflect termios API changes. | Ralf Corsepius | 2010-04-15 | 3 | -10/+10 |
* | 2010-04-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-14 | 2 | -4/+8 |
| | | | | * console/uart.c: Reflect termios API changes. | ||||
* | 2010-04-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-14 | 2 | -4/+9 |
| | | | | | * shared/umon/umoncons.c: Reflect changes to rtems_termios_callbacks->write. | ||||
* | Include <unistd.h>. | Ralf Corsepius | 2010-04-14 | 1 | -0/+2 |
* | 2010-04-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-14 | 1 | -0/+4 |
| | | | | * console/conscfg.c: Include <unistd.h>. | ||||
* | 2010-04-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-14 | 2 | -1/+9 |
| | | | | * shared/flash/flash.c: Include <unistd.h>. | ||||
| | | | | * network/support/bsp_attach.c: Include <unistd.h>. | ||||
