* | removed Thread_queue_Get_number_waiting | Mark Johannes | 1996-08-13 | 4 | -50/+0 |
* | deleted a line for spacing correction | Joel Sherrill | 1996-08-13 | 1 | -1/+0 |
* | _POSIX_Condition_variables_Wait_support: changed status of lock and unlock ↵ | Mark Johannes | 1996-08-13 | 1 | -2/+2 |
| | | | | to return EINVAL is there is an error | ||||
* | task_2: added comments and print statement for task exit | Mark Johannes | 1996-08-13 | 1 | -0/+1 |
* | task_1: added comments and print statement for task exit | Mark Johannes | 1996-08-13 | 1 | -0/+5 |
* | Init.c: added timewait case, added broadcast case | Mark Johannes | 1996-08-13 | 1 | -3/+28 |
* | _POSIX_Condition_variables_Wait_support: fixed the timeout sequence. | Mark Johannes | 1996-08-13 | 1 | -7/+25 |
* | fixed spacing | Joel Sherrill | 1996-08-13 | 1 | -2/+2 |
* | corrected problem in which sigtimedwait() was being invoked with | Joel Sherrill | 1996-08-13 | 1 | -60/+3 |
| | | | | | | the wrong mask. removed code which was commented out. This code was in another test. | ||||
* | chenaged format of output | Joel Sherrill | 1996-08-13 | 1 | -2/+6 |
* | added include of errno.h so the test can check for EINTR. | Joel Sherrill | 1996-08-13 | 1 | -0/+1 |
* | nanosleep now returns -1 and EINTR when a signal interrupts EINTR. | Joel Sherrill | 1996-08-13 | 1 | -2/+8 |
* | removed errors for TOD not set yet. | Joel Sherrill | 1996-08-13 | 1 | -9/+9 |
| | | | | made nanosleep return -1/EINTR for being interrupted for a signal. | ||||
* | added page break before sysconf() | Joel Sherrill | 1996-08-13 | 1 | -1/+3 |
* | task_1: added to handle cases of waiting tasks on condition variables | Mark Johannes | 1996-08-12 | 1 | -0/+60 |
* | system.h: added protoypes for task and task2, added mutex id, and task ids | Mark Johannes | 1996-08-12 | 1 | -1/+10 |
* | Init.c: added cases for signal, wait and broadcast | Mark Johannes | 1996-08-12 | 1 | -7/+26 |
* | Task2: new task for broadcast case | Mark Johannes | 1996-08-12 | 1 | -0/+46 |
* | added test cases for clock_getres | Joel Sherrill | 1996-08-12 | 1 | -9/+27 |
* | clock_getres: added error check for NULL pointer being passed in. | Joel Sherrill | 1996-08-12 | 1 | -0/+3 |
* | sleep: wrong page number | Joel Sherrill | 1996-08-12 | 1 | -1/+1 |
* | removed comment about NO_UNINITIALIZED_WARNINGS since that macro | Joel Sherrill | 1996-08-12 | 1 | -7/+0 |
| | | | | no longer exists. | ||||
* | added test case for stack too large | Joel Sherrill | 1996-08-12 | 1 | -0/+7 |
* | nanosleep: verify rqtp parameter is non-NULL. | Joel Sherrill | 1996-08-12 | 1 | -0/+7 |
| | | | | nanosleep: return 0 time remaining for a yield case. | ||||
* | added test cases for clock_gettime (invalid id), clock_settime (invalid_id), | Joel Sherrill | 1996-08-12 | 1 | -0/+48 |
| | | | | nanosleep (yield cpu), and numerous error cases in nanosleep | ||||
* | added test case for non-NULL parameter to time() | Joel Sherrill | 1996-08-12 | 1 | -0/+6 |
* | time: It is not an error if the TOD is not set. | Joel Sherrill | 1996-08-12 | 1 | -2/+4 |
* | Wait_support: removed the calls to mutex core to posix status codes | Mark Johannes | 1996-08-12 | 1 | -2/+2 |
* | mutex.h: removes the promotion of core status code to POSXI status codes | Mark Johannes | 1996-08-12 | 2 | -24/+0 |
* | fixed spacing ; moved a dummy MP support routine to clean up printout. | Joel Sherrill | 1996-08-12 | 1 | -9/+10 |
* | _POSIX_Mutex_Get: made null id an error | Joel Sherrill | 1996-08-12 | 2 | -0/+10 |
* | pthread_mutex_getprioceiling: added error check for null old_ceiling | Joel Sherrill | 1996-08-12 | 1 | -2/+4 |
| | | | | | pthread_mutex_setprioceiling: added comment indicating an error was impossible to generate. | ||||
* | added numerous error test cases. | Joel Sherrill | 1996-08-12 | 2 | -14/+157 |
* | mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status | Mark Johannes | 1996-08-12 | 2 | -0/+24 |
* | _POSIX_Condition_variables_Wait_support: added ↵ | Mark Johannes | 1996-08-12 | 1 | -4/+5 |
| | | | | _POSIX_Mutex_From_core_mutex_status for the two calls to the mutex manager | ||||
* | _POSIX_Condition_variables_Signal_support: added setting mutex back to NULL | Mark Johannes | 1996-08-12 | 1 | -5/+7 |
| | | | | | | if the queue has been emptied of waiting tasks. _POSIX_Condition_variables_Wait_support: added error check for different mutexesfor the same condition variable. Also added _Thread_queue_Enter_critical_section | ||||
* | pthread_mutexattr_setprioceiling: fixed typo | Joel Sherrill | 1996-08-12 | 1 | -1/+1 |
* | pthread_mutexattr_setprioceiling: valid priority ceiling check looked at | Joel Sherrill | 1996-08-12 | 1 | -1/+1 |
| | | | | value in attribute structure instead of passed in priority | ||||
* | pthread_mutexattr_getprotocol: added check for attribute structure being | Joel Sherrill | 1996-08-12 | 1 | -1/+1 |
| | | | | initialized | ||||
* | Init: added pthread_cond_init with an attr non-NULL, initialized the attr again | Mark Johannes | 1996-08-12 | 1 | -0/+8 |
* | Init: added prliminary phtread_cond_init and destroy cases. | Mark Johannes | 1996-08-12 | 1 | -0/+9 |
* | system.h: added condition variable #define for 10 condition variables | Mark Johannes | 1996-08-12 | 1 | -0/+2 |
* | added test cases for errors in pthread_mutexattr_getpshared | Joel Sherrill | 1996-08-09 | 1 | -1/+16 |
* | added code to catch NULL pointers for return values passed to get routines | Joel Sherrill | 1996-08-09 | 1 | -6/+9 |
* | added test cases for EINVAL cases in pthread_mutexattr_destroy | Joel Sherrill | 1996-08-09 | 1 | -1/+21 |
* | added test case for pthread_mutexattr_init being passed a null pointer. | Joel Sherrill | 1996-08-09 | 1 | -0/+4 |
* | changed style of output to match other tests | Joel Sherrill | 1996-08-09 | 1 | -40/+51 |
* | system.h: initial cvs | Mark Johannes | 1996-08-09 | 1 | -0/+53 |
* | lowered maximum number of threads to 2 to make test case easier. | Joel Sherrill | 1996-08-09 | 1 | -0/+3 |
| | | | | include sched.h so test can invoke scheduler routines. | ||||
* | added test case for sched_yield. | Joel Sherrill | 1996-08-09 | 1 | -6/+14 |
| | | | | changed format of some output. |
