path: root/c (follow)
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-054-16/+227
| | | | | | | | | * cpu_asm.S: Enhanced to save/restore more registers on exceptions. * rtems/score/cpu.h (CPU_Interrupt_frame): Enhanced to list every register individually and document when it is saved. * idtcpu.h: Added constants for the coprocessor 1 registers revision and status.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-052-0/+5
| | | | * .cvsignore: Added stamp-h.in.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-0512-35/+16
| | | | * rtems/Makefile.am, rtems/score/Makefile.am: Removed again.
* 2001-02-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-042-1/+6
| | | | | * rtems/score/cpu.h: IDLE task should not be FP. This was a mistake in the previous patch that has now been confirmed.
* 2001-02-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-042-3/+6
| | | | | * configure.ac: Removed references to rtems/Makefile and rtems/score/Makefile.
* 2001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-02-024-0/+915
| | | | | | * include/lr33000.h, include/lr330x0.h, include/r3000.h, start/mg5.h: New files missed in previous commit. * timer/timer.c: Use rtems/bspIo.h not just bspIo.h.
* Fixed ChangeLog again :(Joel Sherrill2002-02-011-0/+48
* Fixed ChangeLogJoel Sherrill2002-02-011-34/+107
* 2002-02-01 Eric Valette <valette@crf.canon.fr>Joel Sherrill2002-02-0110-3420/+2644
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * So many patches have been posted recently on the mailing list and because we were unable to find correct solution to compile on various linux distros (due to rpcgen incompatibilities), and because the coding style of rdbg was rather inconsistant among various pieces of code, I decided to: 1) make some cleaning regarding global coding style (using indent + manual edits), 2) incorporate/review the paches send by various people (S. Holford, T. Strauman), 3) Fix the bug due to varying rpcgen code generation in remdeb_svc.c, 4) Remove some dead code, 5) Apply a patches enabling to call enterRdbg imediately after rdbg initialization is done, NB : the paches is huge but it is mainly due to coding styke chnages. Only few lines of codes have been really changed and they do not impact rdbg functionnality (AFAIKT). * include/rdbg/servrpc.h, include/rdbg/i386/rdbg_f.h, include/rdbg/m68k/rdbg_f.h, include/rdbg/powerpc/rdbg_f.h, src/_servtgt.c, src/awk.svc, src/excep.c, src/ptrace.c, src/rdbg.c, src/remdeb.x, src/servbkpt.c, src/servcon.c, src/servrpc.c, src/servtgt.c, src/servtsp.c, src/servutil.c, src/i386/excep_f.c, src/i386/rdbg_f.c, src/i386/any/Makefile.am, src/i386/any/remdeb.h, src/i386/any/remdeb_svc.c, src/i386/any/remdeb_xdr.c, src/m68k/excep_f.c, src/m68k/rdbg_f.c, src/m68k/any/Makefile.am, src/m68k/any/remdeb.h, src/m68k/any/remdeb_svc.c, src/m68k/any/remdeb_xdr.c, src/powerpc/excep_f.c, src/powerpc/rdbg_f.c, src/powerpc/new_exception_processing/Makefile.am, src/powerpc/new_exception_processing/remdeb.h, src/powerpc/new_exception_processing/remdeb_svc.c, src/powerpc/new_exception_processing/remdeb_xdr.c: Modified.
* Fixed ChangeLogJoel Sherrill2002-02-011-0/+1
* 2001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-02-013-2/+8
| | | | | | * mongoosev/vectorisrs/vectorisrs.c, shared/interrupts/vectorexceptions.c: Use rtems/bspIo.h, not just bspIo.h.
* 2001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-02-012-1/+7
* 2001-02-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-015-294/+274
| | | | | | * rtems.ads, rtems.adb: Formatting cleaned up. Task based timer directives added. This is Timer_Initiate_Server, Timer_Server_Fire_After, and Timer_Server_Fire_When.
* 2001-02-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-011-0/+4
| | | | * ChangeLog: New file.
* * So many patches have been posted recently on the mailing list andJoel Sherrill2002-02-0135-5885/+6155
* 2001-02-01 Mike Siers <mikes@poliac.com>Joel Sherrill2002-02-013-1/+20
| | | | | | * pppd/rtemspppd.c (rtems_pppd_disconnect): Modified to avoid bringing the link down too fast. NOTE: Mike reports successfully running at 56K baud on a direct link.
* 2001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-02-018-425/+1071
| | | | | | | * Update of BSP to address problems restarting, provide more information during boot, and better handle ROM vs RAM images. * README, include/bsp.h, start/regs.S, start/start.S, startup/bspstart.c, startup/linkcmds, timer/timer.c: Updated
* 2001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-02-015-109/+315
| | | | | | | | | | | | | | | | * Lots of tinkering and tuning as part of improving interrupt latency and improving the per-task interrupt level control and FP mask handling. With these modifications interrupt latency was measured at a worst-case of 100us, average below 60 us on a 12 Mhz R3000 class CPU with 50 RTEMS tasks in the application. * mongoosev/README: Updated. * mongoosev/include/mongoose-v.h: Masks modified. * mongoosev/vectorisrs/vectorisrs.c: Significant overhaul to address software prioritization of interrupts. If a higher priority interrupt occurs while we are looking for new interrupts, we will reinitiate the scan of all interrupts. * shared/interrupts/vectorexceptions.c: Removed warning and deleted blank lines.
* 2001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-02-014-148/+244
| | | | | | | | | * cpu.c: Enhancements and fixes for modifying the SR when changing the interrupt level. * cpu_asm.S: Fixed handling of FP enable bit so it is properly managed on a per-task basis, improved handling of interrupt levels, and made deferred FP contexts work on the MIPS. * rtems/score/cpu.h: Modified to support above changes.
* 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-02-012-11/+26
| | | | * Makefile.am: Reflect 2002-01-23 changes.
* 2001-01-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-012-0/+26
| | | | | * include/rtems/rtems/timer.h: Missed merging these modifications in previous merge of new timer functionality.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-02-013-0/+32
| | | | * pppd/rtemsdialer.h: New file missed in previous commit.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-01-313-0/+29
| | | | | | | | | | | * Nice Update of PPPD support which eliminates the requiremetn that drivers be in the termios TASK_DRIVEN mode. Mike did significant testing and reports that it seems to be more stable and handle larger packets better. This patch replaces the termios tasks with more general pppd network driver tasks. The functions pppinput() and pppstart() get called from the interrupt service routine. * libc/termios.c: Added PPCDISC.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-01-3154-1459/+21277
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Nice Update of PPPD support which eliminates the requiremetn that drivers be in the termios TASK_DRIVEN mode. Mike did significant testing and reports that it seems to be more stable and handle larger packets better. This patch replaces the termios tasks with more general pppd network driver tasks. The functions pppinput() and pppstart() get called from the interrupt service routine. * Makefile.am, configure.ac, net/Makefile.am, net/bpf.h, net/ethernet.h, net/if.c, net/if.h, net/if_arp.h, net/if_dl.h, net/if_ethersubr.c, net/if_llc.h, net/if_loop.c, net/if_ppp.h, net/if_pppvar.h, net/if_types.h, net/netisr.h, net/ppp-comp.h, net/ppp_defs.h, net/pppcompress.h, net/radix.c, net/radix.h, net/raw_cb.c, net/raw_cb.h, net/raw_usrreq.c, net/route.c, net/route.h, net/rtsock.c, pppd/Makefile.am, pppd/README, pppd/STATUS, pppd/auth.c, pppd/cbcp.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h, pppd/pathnames.h, pppd/pppd.8, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/upap.c, pppd/upap.h, pppd/utils.c, pppd/example/README, pppd/example/netconfig.h, wrapup/Makefile.am: Modified. * net/bsd-comp.c, net/if_ppp.c, net/ppp-deflate.c, net/ppp.h, net/ppp_tty.c, net/pppcompress.c, net/zlib.c, net/zlib.h: New file. * modem/, modem/.cvsignore, modem/Makefile.am, modem/ppp.c, modem/ppp.h, modem/ppp_tty.c, modem/pppcompress.c: Subdirectory removed.
* 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-313-26/+31
* 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-313-29/+31
| | | | | | | * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. * Makefile.am: Reflect changes above.
* 2001-01-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-302-3/+20
| | | | * Makefile.am: Corrected so .h files from rtems/score/ are installed.
* 2002-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-3029-226/+146
* 2002-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-3025-273/+184
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-302-1/+4
| | | | * shell/shell.c: Remove #undef __STRICT_ANSI__.
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-302-2/+6
| | | | * Makefile.am: Adapt to automake-1.5.
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-302-7/+11
| | | | * include/Makefile.am: Adapt to automake-1.5.
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-3015-161/+103
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-302-8/+21
| | | | * Makefile.am: Reflect changes from 2002-01-23.
* 2002-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-291-4/+0
| | | | * ChangeLog: Deleted bad entry.
* 2001-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-291-0/+4
| | | | * src/powerpc/new_exception_processing/remdeb.h: Regenerated.
* 2001-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-294-6/+88
| | | | | | | | | * Fixed bug where resetting a timer that was not at the head of one of the task timer chains resulted in the Timer Server task waking up too far in the future. * Added rtems_timer_get_information() directive to support testing. * sp31/init.c, sp31/system.h, sp31/task1.c: Modified to test for above condition.
* 2002-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-292-0/+6
| | | | * include/rtems/score/watchdog.h: Added WATCHDOG_MAXIMUM_INTERVAL.
* 2001-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-294-50/+184
| | | | | | | | | | * Fixed bug where resetting a timer that was not at the head of one of the task timer chains resulted in the Timer Server task waking up too far in the future. * Added rtems_timer_get_information() directive to support testing. * src/timerserver.c, include/rtems/rtems/timer.h, * src/timergetinfo.c: New file. * src/Makefile.am: Modified to reflect above.
* 2002-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-244-39/+9
| | | | | | | * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. AC_CONFIG_SRCDIR(asm.h).
* 2002-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-248-78/+14
* 2002-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-247-57/+63
| | | | | | | | | | | * Makefile.am: Merge in rtems/Makefile.am and rtems/score/Makefile.am. Remove gensize. Require automake-1.5. * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * rtems/score/.cvsignore: Add unixsize.h*. Add stamp-h*. * configure.ac: Add AM_CONFIG_HEADER(rtems/score/unixsize.h). * rtems/score/cpu.h: Replace CPU_CONTEXT_SIZE_IN_BYTES with SIZEOF_CPU_CONTEXT.
* 2001-01-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-225-1/+19
| | | | | * sp09/screen14.c, sp09/sp09.scn, sp30/init.c, sp31/init.c: Modified because priority added as argument to rtems_timer_initiate_server().
* 2001-01-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-223-19/+41
| | | | | * include/rtems/rtems/timer.h, src/timerserver.c: Add priority argument to rtems_timer_initiate_server().
* 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-2210-1159/+60
| | | | | | | | | | | | | | | | | * rtems/Makefile.am: New. * rtems/.cvsignore: New. * rtems/score/Makefile.am: New. * rtems/score/.cvsignore: New. * rtems/score/ppc.h: Relocated from shared/. * rtems/score/ppctypes.h: Relocated from shared/. * asm.h: Relocated from shared/. * shared/Makefile.am: Removed. * shared/asm.h: Removed. * shared/ppc.h: Removed. * shared/ppctypes.h: Removed. * shared/.cvsignore: Removed. * Makefile.am: Reflect changes above. * configure.ac: Reflect changes above.
* 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-223-6/+17
| | | | | | * rtems_telnetd/pty.c: Move config.h to were it belongs. Remove printf (Reported by Till Straumann <strauman@SLAC.Stanford.EDU>).
* 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-221-1/+1
| | | | | * compilers/gcc-target-default.cfg: Add missing \. Reported by Ilya Alexeev <ilya@continuum.ru>.
* 2002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-202-1/+6
| | | | | * include/rtems/system.h: Fix typo in yesterday's change: RTEMS_MULTILIBS.
* 2001-01-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-182-13/+18
| | | | | | | * include/rtems/system.h: Only include cpuopts.h when building a multilib configuration. Some ports still need targopts.h but this small modification lets those ports work non-multilib while fixing being fixed for multilib.
