* configure.ac: Use AS_HELP_STRING(ada).
* aclocal/bspopts.m4: Use AS_HELP_STRING.
* aclocal/bsp-configure.m4: Require autoconf-2.59.
Use AC_CONFIG_HEADERS.
* aclocal/check-custom-bsp.m4: Add bspkit-support.
* aclocal/enable-rtemsbsp.m4: Use AS_HELP_STRING.
* acinclude.m4: Regenerate.
* configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* Makefile.am: include local.am.
* aclocal/version.m4: 4.6.99.0.
* Makefile.am: Don't include host.am.
* automake/compile.am: Further cleanups.
* automake/lib.am: Remove (Unused).
* Makefile.am: Cosmetics.
* wrapup/Makefile.am: Don't include lib.am.
* automake/compile.am: Use automake compilation rules.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Add start*.bin to CLEANFILES.
* Makefile.am: Remove startup/linkcmds.
* Makefile.am: Don't include lib.am.
PR 575/bsps
* startup/linkcmds: Remove.
* libnetworking/pppd/Makefile.am,
libnetworking/rtems_servers/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am,
libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am,
support/Makefile.am: Don't include lib.am.
* libchip/Makefile.am: Don't include lib.am.
* librdbg/src/i386/Makefile.am, librdbg/src/m68k/Makefile.am,
librdbg/src/powerpc/Makefile.am: Don't include lib.am. Remove
unnecessary EXTRA_DISTs.
* Index: m68040/Makefile.am, mcf5206/Makefile.am, shared/Makefile.am:
* wrapup/Makefile.am: Convert to automake-building rules.
* Makefile.am: Add $(TMPINSTALL_FILES) to all-local.
* vectors/vectors.h: Force globalExceptHdl into bss section.
* Makefile.am: Add irq.h and vectors.h
* Makefile.am: Split startup into multiple .rels without reorganizing
the source.
* configure.ac: Add powerpc's <bsp>/wrapup/Makefile.am detection
hack.
* mpc505/Makefile.am, mpc6xx/Makefile.am, mpc8260/Makefile.am,
mpc8xx/Makefile.am, ppc403/Makefile.am: Don't include .../lib.am.
* Makefile.am: Don't include .../lib.am.
* i960ca/Makefile.am, i960ka/Makefile.am, i960rp/Makefile.am: Don't
include .../lib.am.
* sh7032/Makefile.am, sh7045/Makefile.am, sh7750/Makefile.am: Don't
include .../lib.am.
* mongoosev/Makefile.am, r46xx/Makefile.am, tx39/Makefile.am:
Don't include .../lib.am. Remove ACLOCAL_AMFLAGS.
* shared/Makefile.am: Don't include .../lib.am.
* Makefile.am: Pickup files from ../../sparc/shared instead of
../shared. Reformat.
* Makefile.am: Pickup files from ../../c4x/shared instead of
* Makefile.am: Pickup files from ../../arm/shared instead of
* Makefile.am: Pickup files from ../../sh/shared instead of
* Makefile.am: Pickup files from ../../i386/shared instead of
* Makefile.am: Pickup files from ../../m68k/shared instead of
* Makefile.am: Pick up ../mvme167/network/network.c.
* Makefile.am: Use include_*HEADERS for .../shared/*.h.
* Makefile.am: Don't install, just distribute the files.
* Makefile.am: Add missing $ in reference to 3c509.rel.
* Makefile.am: Remove SUBDIRS.
* configure.ac: Reflect having removed shared/*/Makefile.am
* Makefile.am: Merge-in bootloader/Makefile.am, clock/Makefile.am,
console/Makefile.am, include/Makefile.am, irq/Makefile.am,
motorola/Makefile.am, openpic/Makefile.am, pci/Makefile.am,
residual/Makefile.am, start/Makefile.am, startup/Makefile.am,
vectors/Makefile.am, vme/Makefile.am. Use automake compilation rules.
* bootloader/Makefile.am, clock/Makefile.am, console/Makefile.am,
include/Makefile.am, irq/Makefile.am, motorola/Makefile.am,
openpic/Makefile.am, pci/Makefile.am, residual/Makefile.am,
start/Makefile.am, startup/Makefile.am, vectors/Makefile.am,
vme/Makefile.am: Remove.
