* PCI_bus/Makefile.am, clock/Makefile.am, console/Makefile.am,
tod/Makefile.am, vectors/Makefile.am, wrapup/Makefile.am: Include
compile.am
vectors/Makefile.am, wrapup/Makefile.am: Include compile.am
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
nvram/Makefile.am, pci/Makefile.am, start/Makefile.am,
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am,
universe/Makefile.am, vectors/Makefile.am, wrapup/Makefile.am:
Include compile.am
* dlentry/Makefile.am, flashentry/Makefile.am, startup/Makefile.am,
* bootloader/Makefile.am, clock/Makefile.am, console/Makefile.am,
irq/Makefile.am, motorola/Makefile.am, openpic/Makefile.am,
pci/Makefile.am, residual/Makefile.am, start/Makefile.am,
startup/Makefile.am, vectors/Makefile.am, wrapup/Makefile.am:
Include compile.am
* console/Makefile.am, network/Makefile.am, startup/Makefile.am,
* canbus/Makefile.am, console/Makefile.am, network/Makefile.am,
start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Include
compile.am
* clock/Makefile.am, console/Makefile.am, scv64/Makefile.am,
sonic/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, tod/Makefile.am, wrapup/Makefile.am: Include
compile.am
* console/Makefile.am, liblnk/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
* clock/Makefile.am, console/Makefile.am, fatal/Makefile.am,
wrapup/Makefile.am, network/Makefile.am: Include compile.am
* clock/Makefile.am, console/Makefile.am, consolex/Makefile.am,
tod/Makefile.am, wrapup/Makefile.am, network/Makefile.am: Include
compile.am
* rtems/rtems_syscall.c: Changed from O_NONBLOCK to internal
RTEMS_LIBIO_FLAGS_NO_DELAY to avoid O_NONBLOCK/O_NDELAY confusion
and to work with the converted flags.
* libio.c: Added O_NONBLOCK to list of flags.
* clock/Makefile.am, console/Makefile.am, spurious/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am,
start/Makefile.am: Include compile.am
* console/Makefile.am, start/Makefile.am, startup/Makefile.am,
wrapup/Makefile.am, clock/Makefile.am: Include compile.am
* 3c509/Makefile.am, clock/Makefile.am, console/Makefile.am,
ne2000/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wd8003/Makefile.am, wrapup/Makefile.am: Include
compile.am
* shmsupp/Makefile.am, start/Makefile.am, startup/Makefile.am,
tty/Makefile.am, wrapup/Makefile.am: Include compile.am
Include compile.am
* clock/Makefile.am, console/Makefile.am, irq/Makefile.am,
Include compile.am.
* console/Makefile.am, shmsupp/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Include compile.am.
* Makefile.am: Include compile.am, formatting.
* rtems/Makefile.am: formatting.
* rtems/score/Makefile.am: formatting.
* Makefile.am: Include compile.am, remove duplicate includes.
* rtems/Makefile.am: Formatting.
* rtems/score/Makefile.am: Formatting.
* src/Makefile.am: Include compile.am.
* optman/Makefile.am, src/Makefile.am: Include compile.am.
* wrapup/itron/Makefile.am, wrapup/posix/Makefile.am,
wrapup/rtems/Makefile.am: Include compile.am
* network/Makefile.am, rtc/Makefile.am, serial/Makefile.am:
Include compile.am.
* cpuuse/Makefile.am, dummy/Makefile.am, dumpbuf/Makefile.am,
monitor/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am,
untar/Makefile.am, wrapup/Makefile.am, mw-fb/Makefile.am:
Include compile.am.
* wrapup/Makefile.am: Include compile.am.
* emfdb.c: Removed stray semi-colon. Reported on GoAhead
mailing lists by Jim Rudnicki <jdrudnicki@yahoo.com>
* Merged version 2.1 of GoAhead webserver. This update
was submitted by Antti P Miettinen <antti.p.miettinen@nokia.com>.
* NOTES, base64.c, ejIntrn.h, emfdb.c, emfdb.h, md5.h, md5c.c,
um.c, um.h: New files.
* wbase64.c: Removed.
* Makefile.am, asp.c, balloc.c, default.c, ej.h, ejlex.c, ejparse.c,
form.c, h.c, handler.c, mime.c, misc.c, ringq.c, rom.c, security.c,
socket.c, sym.c, uemf.c, uemf.h, url.c, value.c, webcomp.c, webmain.c,
webpage.c, webrom.c, webs.c, webs.h, websuemf.c, wsIntrn.h: Modified.
* netinet/tcp_input.c: Spelling corrections.
psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am,
psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am:
Use AM_CPPFLAGS += instead of AM_CPPFLAGS =
all APIs.
* mw-fb/.cvsignore: New file.
* console/keyboard.h: Changed numerous routines from extern inline
to static inline.
* rtems_webserver/license.txt: New file.
* configure.in: Add lib/libcpu and lib/libbsp to cfg_subdirs
* Added generic Micro FrameBuffer interface for MicroWindows.
This interface allows MicroWindows to under RTEMS. A sample
driver has been developed for the pc386 BSP. See
pc386/fb_vga.c as a sample.
* Added Uniform Input Device interface for MicroWindows.
See PC386 bsp for sample drivers for mouse and keyboard (console).
* mw-bf: New directory.
* Makefile.am, configure.in, wrapup/Makefile.am: Account for mw-fb.
* mw-fb/Makefile.am: New file.
* mw-fb/mw_fb.c: New file.
* mw-fb/mw_fb.h: New file.
* mw-fb/mw_uid.c: New file.
* mw-fb/mw_uid.h: New file.
