* | Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirements | Joel Sherrill | 1998-04-27 | 24 | -3/+49 |
| | | | | more accurate. | ||||
* | Fixed screen to match actual output. | Joel Sherrill | 1998-04-27 | 1 | -3/+2 |
* | Added numerous entries to make the memory calculation more accurate: | Joel Sherrill | 1998-04-27 | 2 | -2/+134 |
| | | | | | | | | | | | | | + POSIX threads + Ada tasks + POSIX threads API support + POSIX condition variables + POSIX keys (still do not account for data fields) + POSIX mutexes + POSIX queued signals + added macro for extra memory for task stacks + default value for CONFIGURE_MAXIMUM_FAKE_ADA_TASKS + extra memory for Ada task stacks | ||||
* | Moved POSIX_signals_Siginfo_node structure definition to headers/psignal.h | Joel Sherrill | 1998-04-27 | 1 | -5/+1 |
| | | | | so confdefs.h could see it. | ||||
* | Changed __POSIX_SIGNALS_h to __RTEMS_POSIX_SIGNALS_h to avoid conflict with | Joel Sherrill | 1998-04-27 | 2 | -4/+14 |
| | | | | | | | the system signals.h file. Moved POSIX_signals_Siginfo_node type definition to this file to allow confdefs.h to know the size per queued signal. | ||||
* | Reset the pthread attributes structure so the proper error would be | Joel Sherrill | 1998-04-27 | 1 | -1/+5 |
| | | | | generated. | ||||
* | psim now runs in both debug and non-debug mode. | Joel Sherrill | 1998-04-18 | 4 | -9/+17 |
* | rtems_libio_number_iops is now defined in confdefs.h so the maximum | Joel Sherrill | 1998-04-18 | 2 | -2/+2 |
| | | | | file descriptors is user configurable. | ||||
* | Changed to account for libio's maximum_semaphores as well as its | Joel Sherrill | 1998-04-18 | 2 | -2/+10 |
| | | | | | | memory requirements. Also added variable to tell libio how many file descriptors to allocate. | ||||
* | Changed version number so script will work. | Joel Sherrill | 1998-04-18 | 2 | -2/+2 |
* | Fixed so this would compile without warning. | Joel Sherrill | 1998-04-15 | 2 | -0/+4 |
* | Added bh, ch, dh, bl, cl, and dl register macros. | Joel Sherrill | 1998-04-15 | 1 | -0/+7 |
* | Updated. | Joel Sherrill | 1998-04-15 | 1 | -0/+2 |
* | update from Eric Norum | Joel Sherrill | 1998-04-15 | 2 | -16/+15 |
* | New file created by extracting common initialization from every BSP's | Joel Sherrill | 1998-04-15 | 1 | -0/+38 |
| | | | | bspstart.c file. | ||||
* | Numerous changes which in total greatly reduced the amount of source | Joel Sherrill | 1998-04-15 | 56 | -873/+90 |
| | | | | | | | | | | | | code in each BSP's bspstart.c. These changes were: + confdefs.h now knows libio's semaphore requirements + shared/main.c now copies Configuration to BSP_Configuration + shared/main.c fills in the Cpu_table with default values This removed the need for rtems_libio_config() and the constant BSP_LIBIO_MAX_FDS in every BSP. Plus now the maximum number of open files can now be set on the gcc command line. | ||||
* | Transitioned to shared bsp_libc_init() and cleaned up comments. | Joel Sherrill | 1998-04-15 | 63 | -1435/+604 |
* | Initial sets of user extensions now have memory allocated on the fly | Joel Sherrill | 1998-04-15 | 1 | -2/+1 |
| | | | | for them. | ||||
* | Stack check now initialized as part of initial extension set. | Joel Sherrill | 1998-04-15 | 6 | -0/+130 |
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 27 | -351/+13 |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | ||||
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 9 | -28/+83 |
* | changed version to ralf-980414 | Joel Sherrill | 1998-04-14 | 2 | -2/+2 |
* | Account for interrupt stack space | Joel Sherrill | 1998-04-14 | 2 | -2/+24 |
* | Ralf Corsepius suggested a way to get rid of UNIX compiler files and use ↵ | Joel Sherrill | 1998-04-14 | 3 | -3/+2 |
| | | | | gcc-target-default.cfg | ||||
* | Stack checker extension now accounted for in confdefs.h | Joel Sherrill | 1998-04-14 | 27 | -201/+3 |
* | Added stack checker extension | Joel Sherrill | 1998-04-14 | 2 | -4/+28 |
* | Now accounts for region used by RTEMS malloc and extension used | Joel Sherrill | 1998-04-14 | 28 | -408/+32 |
| | | | | by newlib. | ||||
* | Removed recursive call to exit | Joel Sherrill | 1998-04-14 | 1 | -2/+0 |
* | Moved bspclean from assembly to C and made exit act properly. | Joel Sherrill | 1998-04-14 | 2 | -2/+19 |
* | new file | Joel Sherrill | 1998-04-14 | 3 | -6/+54 |
* | Removed delay macro | Joel Sherrill | 1998-04-14 | 1 | -16/+0 |
* | Refreshing effort from Avenger. | Joel Sherrill | 1998-04-14 | 8 | -322/+1046 |
* | removed shmsupp | Joel Sherrill | 1998-04-14 | 1 | -1/+1 |
* | Corrected comment | Joel Sherrill | 1998-04-14 | 1 | -3/+2 |
* | new files | Joel Sherrill | 1998-04-14 | 35 | -0/+3397 |
* | Increased stack space of the monitor task. | Joel Sherrill | 1998-04-06 | 2 | -2/+2 |
* | Increased stack size so test would run in debug mode. | Joel Sherrill | 1998-04-06 | 5 | -5/+6 |
* | More stuff removed as a result of using newlib's isatty() implementation. | Joel Sherrill | 1998-04-06 | 3 | -26/+0 |
| | | | | These were noticed by Eric Norum. | ||||
* | Added stanzas for debug_tests and profile_tests. | Joel Sherrill | 1998-04-06 | 1 | -0/+6 |
* | Added test so the build procedure would stop if a directory did not exist. | Joel Sherrill | 1998-04-03 | 1 | -0/+2 |
| | | | | | This typically indicates a bug in a directory level Makefile or a configure scrip bug. | ||||
* | Removed isatty() since we are now using newlib's implementation as | Joel Sherrill | 1998-04-03 | 5 | -22/+0 |
| | | | | a result of enabling the newlib POSIX directory. | ||||
* | Made these have real constants. | Joel Sherrill | 1998-04-03 | 4 | -44/+52 |
* | changed version to 4.0.0-beta2 | Joel Sherrill | 1998-03-31 | 2 | -2/+2 |
* | Added "sigemptyset()" call to insure that the memcmp() would work. | Joel Sherrill | 1998-03-31 | 1 | -0/+4 |
| | | | | | It appears that the new glibc does not clear all the bits of the signal set with a sigprocmask. | ||||
* | Were looking at the wrong C++ variable. | Joel Sherrill | 1998-03-30 | 1 | -1/+1 |
* | Moved bsp_postdriver_hook() to a shared file and made it a common | Joel Sherrill | 1998-03-30 | 47 | -666/+118 |
| | | | | component. | ||||
* | Renamed crt0.o to crt0_go32.o to avoid build problems. | Joel Sherrill | 1998-03-30 | 1 | -1/+1 |
* | Update from "erik.ivanenko" <erik.ivanenko@utoronto.ca>. | Joel Sherrill | 1998-03-30 | 12 | -130/+1432 |
| | | | | | Also removed bsp_postdriver_hook() from every bsp possible and moved to shared version. | ||||
* | GO32 does not have sockets. | Joel Sherrill | 1998-03-27 | 1 | -0/+2 |
* | Changed int to unsigned32 to match cpu.h. | Joel Sherrill | 1998-03-27 | 1 | -1/+1 |
