* sh7032/clock/ckinit.c, sh7032/delay/delay.c, sh7032/timer/timer.c,
sh7045/clock/ckinit.c, sh7045/timer/timer.c, sh7750/clock/ckinit.c,
sh7750/timer/timer.c: Eliminate the clicks_per_microsecond field in
the SuperH CPU Table and define another mechanism for drivers to
obtain this information.
* clock/ckinit.c: Eliminate the clicks_per_microsecond field in the
MIPS CPU Table and define another mechanism for drivers to obtain
this information.
* clock/ckinit.c, startup/bspstart.c: Eliminate the
clicks_per_microsecond field in the MIPS CPU Table and define another
mechanism for drivers to obtain this information.
* libchip/network/if_fxp.c: Spacing.
* bootcard.c: Add comment.
* console/config.c: Fix typo.
* startup/bspstart.c: Eliminate the interrupt_table_segment and
interrupt_table_offset fields in the i386 CPU Table since they are
never read.
* shmsupp/getcfg.c: Fix spacing.
* clock/ckinit.c, include/bsp.h: Fix spacing.
* startup/bspstart.c: Fix spacing.
* startup/bspstart.c: Eliminate the interrupt_vector_table field in the
m68k CPU Table since it is never read.
* runtest.in: Filter out Memory exception error messages.
* shared/console/uart.c: Fix typo and spacing.
* network/network.c: Fix LED configuration to match uCDIMM.
* shared/console/uart.c: when draining UART during
initialization (wait for possible printk() activity
to finish) look at TEMT (fifo, holding-reg and shift-reg)
rather than THRE (fifo, holding-reg only). This resolved
some scrambled output issues for me.
Enhanced semantics: if BSP initializes BSPBaseBaud to a negative
value then the driver interprets the modulus as a speed value
and uses the current setting of the divisor to compute the
clock speed (BSPBaseBaud). This is useful if you have a board
that you know is initialized e.g., to 9600 but you
don't know the clock speed.
* m68k/mcf5235/include/mcf5235.h: Remove '/' from define label.
* Makefile.am, motorola_powerpc/Makefile.am,
* shared/pci/detect_raven_bridge.c, Makefile.am,
* shared/pci/generic_clear_hberrs.c: separated the generic
version of _BSP_clear_hostbridge_errors() into its own
file.
* libchip/rtc/ds1375.c, libchip/rtc/ds1375-rtc.h:
Avoid using 'stdio' before the system is up and fully
initialized.
* libchip/rtc/ds1375.c, libchip/rtc/ds1375-rtc.h,
* libchip/Makefile.am, libchip/preinstall.am:
added new driver for Maxim DS1375 i2c RTC.
* shared/src/cache.c: moved generic operations
(flush/invalidate 1 data line, invalidate 1 inst. line)
from #ifdef <cpu_flavor> to general section (all CPUs).
* shared/src/cache_.h: include <libcpu/cache.h> only
#ifdef _OLD_EXCEPTIONS - no need for <libcpu/cache.h>
otherwise.
* shared/include/byteorder.h: fixed wrong pointer-type
of ld_le32() (uint16_t* -> uint32_t*).
* ada.am: Now builds cleanly with GCC trunk.
* aclocal.m4: Removed. Is automatically generated by bootstrap.
*lpc22xx/irq/bsp_irq_asm.S: Add veneer for ARM<->Thumb
lpc22xx/irq/bsp_irq_init.c: add VIC address init
* shared/abort/simple_abort.c: Add veneer for ARM<->Thumb
shared/irq/irq_asm.S: Add veneer for ARM<->Thumb
* start/start.S, startup/bspclean.c: Add veneer between ARM and
Thumb instructions. also moved bss init after CPSR/stack init in
start.S
* ep1a/irq/irq.c, gen5200/irq/irq.c, mbx8xx/irq/irq.c,
mpc8260ads/irq/irq.c, mvme5500/irq/irq.c, psim/irq/irq.c,
score603e/irq/irq.c, shared/irq/irq.c:
test for non-NULL-ness before calling 'on'/'off'
methods so that users don't have to provide
no-ops if they don't want this feature.
* shared/console/uart.c: removed #define UARTDEBUG
* mpc5xx/irq/irq.c, mpc5xx/exceptions/raw_exception.c,
new-exceptions/raw_exception.c: test for non-NULL-ness before calling
'on'/'off' methods so that users don't have to provide
* shared/irq/irq.c: test for non-NULL-ness before calling
* gba/irq/irq.c: test for non-NULL-ness before calling
* clock/ckinit.c: Formatting.
* startup/linkcmds: Formatting.
* shared/pci/pci.c: converted access to pci_config_addr to
conditionally defined macros so that bsp.h can override details.
* include/mpc5200.h: Fix typo.
* include/mpc5200.h: Fix constants off by one nibble.
* include/mpc5200.h: Added some simple interrupt GPIO constants.
* irq/irq.h: Fixed typos.
* mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am,
mptests/mp02/node1/Makefile.am, mptests/mp02/node2/Makefile.am,
mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am,
mptests/mp04/node1/Makefile.am, mptests/mp04/node2/Makefile.am,
mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am,
mptests/mp06/node1/Makefile.am, mptests/mp06/node2/Makefile.am,
mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am,
mptests/mp08/node1/Makefile.am, mptests/mp08/node2/Makefile.am,
mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am,
mptests/mp10/node1/Makefile.am, mptests/mp10/node2/Makefile.am,
mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am,
mptests/mp12/node1/Makefile.am, mptests/mp12/node2/Makefile.am,
mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am,
mptests/mp14/node1/Makefile.am, mptests/mp14/node2/Makefile.am,
samples/base_mp/Makefile.am, samples/base_mp/node1/Makefile.am,
samples/base_mp/node2/Makefile.am, samples/base_sp/Makefile.am,
samples/hello/Makefile.am, samples/nsecs/Makefile.am,
samples/ticker/Makefile.am, sptests/sp01/Makefile.am,
sptests/sp02/Makefile.am, sptests/sp03/Makefile.am,
sptests/sp04/Makefile.am, sptests/sp05/Makefile.am,
sptests/sp06/Makefile.am, sptests/sp07/Makefile.am,
sptests/sp08/Makefile.am, sptests/sp09/Makefile.am,
sptests/sp11/Makefile.am, sptests/sp12/Makefile.am,
sptests/sp13/Makefile.am, sptests/sp14/Makefile.am,
sptests/sp15/Makefile.am, sptests/sp16/Makefile.am,
sptests/sp17/Makefile.am, sptests/sp19/Makefile.am,
sptests/sp20/Makefile.am, sptests/sp22/Makefile.am,
sptests/sp23/Makefile.am, sptests/sp24/Makefile.am,
sptests/sp25/Makefile.am, tmtests/tm01/Makefile.am,
tmtests/tm02/Makefile.am, tmtests/tm03/Makefile.am,
tmtests/tm04/Makefile.am, tmtests/tm05/Makefile.am,
tmtests/tm06/Makefile.am, tmtests/tm07/Makefile.am,
tmtests/tm08/Makefile.am, tmtests/tm09/Makefile.am,
tmtests/tm10/Makefile.am, tmtests/tm11/Makefile.am,
tmtests/tm12/Makefile.am, tmtests/tm13/Makefile.am,
tmtests/tm14/Makefile.am, tmtests/tm15/Makefile.am,
tmtests/tm16/Makefile.am, tmtests/tm17/Makefile.am,
tmtests/tm18/Makefile.am, tmtests/tm19/Makefile.am,
tmtests/tm20/Makefile.am, tmtests/tm21/Makefile.am,
tmtests/tm22/Makefile.am, tmtests/tm23/Makefile.am,
tmtests/tm24/Makefile.am, tmtests/tm25/Makefile.am,
tmtests/tm28/Makefile.am, tmtests/tm29/Makefile.am,
tmtests/tmck/Makefile.am, tmtests/tmoverhd/Makefile.am: Executables
should end in .exe just like their C counterparts.
* rtems.adb, rtems.ads: Added some more missing bindings.
* configure.ac, samples/Makefile.am: Added a test for Clock_Get_Uptime
* samples/nsecs/.cvsignore, samples/nsecs/Makefile.am,
samples/nsecs/config.h, samples/nsecs/nsecs.adb,
samples/nsecs/nsecs.scn, samples/nsecs/sptest.adb,
samples/nsecs/sptest.ads: New files.
added IRQ support to MPC83xx i2c driver
added mpc83xx spi driver
* rtems.adb, rtems.ads: Added a missing binding.
* sptests/sp16/sptest.ads, sptests/sp20/sptest.adb,
sptests/sp20/sptest.ads: Forgot to update the copyright.
* sptests/sp09/sp09.scn, sptests/sp09/sptest.adb,
sptests/sp13/sp13.scn, sptests/sp13/sptest.adb,
sptests/sp16/sp16.scn, sptests/sp16/sptest.adb,
sptests/sp16/sptest.ads, sptests/sp20/sp20.scn,
sptests/sp20/sptest.adb, sptests/sp20/sptest.ads: Updated tests to
match the current C tests and regenerated the .scn files.
