* | Added CVS Ids | Joel Sherrill | 1998-08-20 | 194 | -0/+611 |
* | Fixed many warnings. | Joel Sherrill | 1998-08-20 | 104 | -254/+484 |
* | changed version to 980820-BSD | Joel Sherrill | 1998-08-20 | 2 | -2/+2 |
* | Changed to avoid use of gets(). | Joel Sherrill | 1998-08-20 | 2 | -16/+68 |
* | Updated to reflect TCP/IP stack transition. | Joel Sherrill | 1998-08-20 | 1 | -1/+3 |
* | Temporarily leave strsep out of the build. | Joel Sherrill | 1998-08-20 | 2 | -4/+8 |
* | Added missing file. | Joel Sherrill | 1998-08-20 | 2 | -2/+2 |
* | Removed stub implementation | Joel Sherrill | 1998-08-20 | 3 | -13/+4 |
* | FreeBSD stack compiles for the first time (except libc/strsep.c) | Joel Sherrill | 1998-08-20 | 10 | -437/+525 |
* | FreeBSD stack compiles for the first time (except libc/strsep.c). | Joel Sherrill | 1998-08-20 | 45 | -24/+1058 |
* | Base files | Joel Sherrill | 1998-08-20 | 4 | -0/+190 |
* | Base files | Joel Sherrill | 1998-08-20 | 12 | -0/+584 |
* | Base version. | Joel Sherrill | 1998-08-20 | 2 | -0/+28 |
* | Base files | Joel Sherrill | 1998-08-19 | 647 | -0/+179701 |
* | changed version to 980819 | Joel Sherrill | 1998-08-19 | 2 | -2/+2 |
* | Patch from Eric Valette <valette@crf.canon.fr>: | Joel Sherrill | 1998-08-19 | 4 | -58/+86 |
| | | | | | | | - Use the "hlt" instruction for the Idle thread, - Optimise interrupt PATH leadding to thread wakeup, - Preparation for Intel exception management that should come before the end of the week... | ||||
* | Fixed obsolete reference to BSDINSTALL. | Joel Sherrill | 1998-08-19 | 1 | -1/+1 |
* | Patch from Aleksey <qqi@world.std.com>: | Joel Sherrill | 1998-08-19 | 2 | -10/+45 |
| | | | | | | | | | | | | This patch has same changes as one I sent to you earlier plus it fixes _heap_size problem for pc386 we had discussed earlier. Now, _heap_size is defined and set to 0 in pc386/startup/bspstart.c It can be patched to desireable value in binary image. If it is left unpatched, then startup code will determine size of memory (on the assumption that at least 2MB are present) and use max possible heap. | ||||
* | Patch from Aleksey <qqi@world.std.com>: | Joel Sherrill | 1998-08-19 | 8 | -21/+34 |
| | | | | | | It fixes netboot build problem, KA9Q configuration for pc386, some compiler wardning, it also removed some stuff ifdef'ed with '#if 0'. | ||||
* | Patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de> and myself to | Joel Sherrill | 1998-08-19 | 8 | -13/+12 |
| | | | | | | | | | | | | | | | | | | | | | | | | make solaris target buildable. > 1. The ipc check fails since solaris does not define union semun. > The unix port code actually defines this type itself on solaris. Doing > the same thing lets it get configured. Then... > 2. It looks like BSDINSTALL is not defined properly. BSDINSTALL is defined in make/host.cfg.in as BSDINSTALL=@INSTALL@ @INSTALL@ is generated by autoconf's standard macro AC_PROG_INSTALL, which is widely used in almost any autoconf/automake configured package. In case there is really something wrong with it, then it must be considered a bug in autoconf. I can see a doubious fragment in AC_PROG_INSTALL, which is used when no appropriate bsd-install is found. Finally Ralf saw a problem with the find on solaris which I also saw and fixed. | ||||
* | Added 68060 definition from Chris Johns. | Joel Sherrill | 1998-08-19 | 1 | -0/+17 |
* | If 0 out the code which touches the chip in questionable ways for processing | Joel Sherrill | 1998-08-14 | 1 | -0/+6 |
| | | | | a giant packet. | ||||
* | Changed tm27 clear interrupt macro on all PPC BSPs except the papyrus. | Joel Sherrill | 1998-08-14 | 1 | -0/+5 |
* | Added information on caching. | Joel Sherrill | 1998-08-14 | 1 | -0/+13 |
* | Updated. | Joel Sherrill | 1998-08-14 | 1 | -1/+1 |
* | Fixed version reference | Joel Sherrill | 1998-08-13 | 1 | -1/+1 |
* | Updated. | Joel Sherrill | 1998-08-13 | 1 | -181/+179 |
* | Fixed preinstall stanza so the prebuild works. | Joel Sherrill | 1998-08-13 | 1 | -3/+3 |
* | base line -- copied from erc32 | Joel Sherrill | 1998-08-13 | 1 | -0/+193 |
* | Enable TX interrupts only when we need TDAs. | Joel Sherrill | 1998-08-13 | 1 | -1/+0 |
* | Cleaned up some debugging stuff. | Joel Sherrill | 1998-08-13 | 1 | -23/+15 |
| | | | | Redid interrupt handler to read imr/isr once and to write the imr once. | ||||
* | Don't disable the RX/TX on close in polled mode. | Joel Sherrill | 1998-08-13 | 2 | -4/+6 |
| | | | | Fixed a comment. | ||||
* | Per request from Chris Johns <ccj@acm.org>, I added code to detect | Joel Sherrill | 1998-08-13 | 1 | -3/+3 |
| | | | | | when the bare bsp was enabled without setting both --enable-cpu-model and --enable-cpu-cflags. | ||||
* | Patch from Chris Johns <ccj@acm.org> to change the way in which the initial | Joel Sherrill | 1998-08-13 | 1 | -2/+5 |
| | | | | stack pointers are saved. | ||||
* | Patch from Chris Johns <ccj@acm.org>. Comments follow: | Joel Sherrill | 1998-08-13 | 1 | -0/+19 |
| | | | | | | | | | | | Here is a small patch which allows the m68060 to be used. I have not tested the FP switching stuff which we know is broken. This is taken against the libchip snapshot but should merge without problems. If you have any problems please let me know. There are other smaller issues such as superscalar enable and cache control which I have not addressed yet. They are different to all other m68k processors. These can wait IMO. | ||||
* | fixed spacing | Joel Sherrill | 1998-08-13 | 1 | -16/+14 |
* | Removed spurious prints and cleaned up XXX. | Joel Sherrill | 1998-08-12 | 1 | -11/+10 |
* | Added more debug information. There are probably debug prints left in. | Joel Sherrill | 1998-08-12 | 1 | -24/+53 |
| | | | | | Fixed one important bug. After wrapping the RX Descriptors all had the EOL bit set which resulted in everything slowing down massively. | ||||
* | Fixed bug where the last link of the RDA was not initialized properly. | Joel Sherrill | 1998-08-12 | 1 | -15/+30 |
* | Added SONIC_DEBUG_DESCRIPTORS and changed debug level. | Joel Sherrill | 1998-08-11 | 1 | -3/+11 |
* | Survives 16-20 packets. Appears to be ok on TX buffer management. | Joel Sherrill | 1998-08-10 | 1 | -11/+16 |
| | | | | Problem appears to be on the RX buffer initialization side. | ||||
* | Added prints | Joel Sherrill | 1998-08-10 | 1 | -1/+2 |
* | Can now reply to multiple successive pings successfully without being in | Joel Sherrill | 1998-08-10 | 2 | -29/+22 |
| | | | | | | promiscuous mode. It still dies somewhere between 16 and 20 pings. | ||||
* | replies to ping -- forced into prosmiscuous mode | Joel Sherrill | 1998-08-10 | 1 | -13/+21 |
* | Reordered some stuff. | Joel Sherrill | 1998-08-08 | 1 | -7/+10 |
* | changed version to 980808 | Joel Sherrill | 1998-08-08 | 2 | -2/+2 |
* | Corrected spacing. | Joel Sherrill | 1998-08-08 | 1 | -1/+1 |
* | Changed debug level. | Joel Sherrill | 1998-08-08 | 2 | -36/+96 |
| | | | | | | | | | | | | | | | | Moved CAM Descriptor types to sonic.h. CAM memory is now malloced to insure it shares the same upper address bits. Removed increment of RX interrupt count on TX interrupt path. Added SONIC_DEBUG_FRAGMENTS and SONIC_DEBUG_CAM conditionals. Fixed bugs in fragment manipulation. First bug was that the pad overwrote the last fragment. The second bug was that the link information overwrote the size of the last fragment. Rewrote initialization of TDA to simplify it. | ||||
* | changed version to 9800808 | Joel Sherrill | 1998-08-08 | 2 | -2/+2 |
* | Removed SonicRegisters structure since we now use register indices | Joel Sherrill | 1998-08-06 | 1 | -83/+15 |
| | | | | | | | | and access routines. Added revision constants. Added in_use and EOL field values. |
