* | bsp/stm32f4: fix typo in USART2 device name | Karel Gardas | 2013-07-22 | 1 | -1/+1 |
* | bsp/gen83xx: Fix BSP options for MPC8348EAMDS | Ralf Kirchner | 2013-07-18 | 1 | -2/+1 |
* | smp: Add and use _CPU_SMP_Send_interrupt() | Sebastian Huber | 2013-07-17 | 5 | -16/+11 |
| | | | | Delete bsp_smp_interrupt_cpu(). | ||||
* | smp: Add and use _CPU_SMP_Get_current_processor() | Sebastian Huber | 2013-07-17 | 7 | -21/+16 |
| | | | | | | | | | | Add and use _SMP_Get_current_processor() and rtems_smp_get_current_processor(). Delete bsp_smp_interrupt_cpu(). Change type of current processor index from int to uint32_t to match _SMP_Processor_count type. | ||||
* | bsps/arm: Fix for top of the address space | Ric Claus | 2013-07-17 | 2 | -4/+6 |
* | bsp/xilinx-zynq: Provide BSP variants | Ric Claus | 2013-07-17 | 13 | -4/+96 |
* | bsp/xilinx-zynq: Use bsp_console_select() | Sebastian Huber | 2013-07-17 | 1 | -2/+7 |
* | bsps/serial: Move bsp_console_select() declaration | Sebastian Huber | 2013-07-17 | 3 | -9/+8 |
* | bsps: Use rtems_task_self() | Sebastian Huber | 2013-07-16 | 3 | -3/+3 |
* | libchip/ata: Remove dead code | Sebastian Huber | 2013-07-16 | 1 | -58/+5 |
* | Updated legacy code in arm edb7312 | Vipul Nayyar | 2013-07-16 | 2 | -20/+6 |
* | bsps/arm: Disable alignment exceptions | Sebastian Huber | 2013-07-16 | 2 | -2/+2 |
* | bsp/mpc55xx: Add MPC5668G support | Sebastian Huber | 2013-07-15 | 17 | -20/+6836 |
* | bsp/rtl22xx: Use IRQ extensions API | Vipul Nayyar | 2013-07-15 | 1 | -13/+20 |
* | bsp/gumstix: Fix warnings | Vipul Nayyar | 2013-07-12 | 1 | -54/+14 |
* | Updated Legacy code in arm gba | Vipul Nayyar | 2013-07-12 | 1 | -48/+20 |
* | bsps: Simplify bsp_generic_fatal() declaration | Sebastian Huber | 2013-07-11 | 1 | -8/+2 |
* | libbsp/shared/generic-fatal.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to bsp_f | Joel Sherrill | 2013-07-10 | 1 | -0/+7 |
* | Updated Legacy code in arm gumstix | Vipul Nayyar | 2013-07-10 | 1 | -17/+16 |
* | Updated Legacy code in arm edb7312 | Vipul Nayyar | 2013-07-10 | 2 | -37/+39 |
* | bsp/virtex: Use #if instead of #ifdef | Sebastian Huber | 2013-07-10 | 1 | -9/+9 |
| | | | | | This allows VIRTEX_CONSOLE_USE_INTERRUPTS=0 on the configure command line to disable the interrupt mode. | ||||
* | bsp/csb336: Use IRQ extensions API | Vipul Nayyar | 2013-07-10 | 2 | -92/+96 |
| | | | | Fix warnings. | ||||
* | libchip ns16550.c: Improve comment | Joel Sherrill | 2013-07-09 | 1 | -1/+4 |
* | bsp/virtex: Add VIRTEX_CONSOLE_USE_INTERRUPTS | Sebastian Huber | 2013-07-09 | 2 | -37/+107 |
| | | | | Add interrupt support for console driver. | ||||
* | bsp/virtex: Use ppc_count_leading_zeros() | Sebastian Huber | 2013-07-09 | 1 | -11/+10 |
| | | | | Use ppc_count_leading_zeros() to optimize interrupt processing. | ||||
* | bsp/virtex: Fix interrupt handling | Sebastian Huber | 2013-07-09 | 1 | -9/+5 |
| | | | | | | Some modules like the XPS UART Lite use event triggered interrupts. If we acknowledge the interrupts after the interrupt service we may loose these events. | ||||
* | bsps/powerpc: Add ppc_count_leading_zeros() | Sebastian Huber | 2013-07-09 | 1 | -0/+13 |
* | bsp/csb337: Use IRQ extensions API | Vipul Nayyar | 2013-07-07 | 1 | -36/+17 |
* | mouse: Add shared bsp_get_serial_mouse_device() | Sebastian Huber | 2013-07-07 | 3 | -14/+28 |
* | bsp/mpc55xx: Update due to API changes | Sebastian Huber | 2013-07-05 | 2 | -16/+12 |
| | | | | | Termios notifies now the driver about an inactive transmit with the length argument set to zero. | ||||
* | bsp/mpc55xx: Avoid integer overflow | Sebastian Huber | 2013-07-05 | 1 | -2/+2 |
* | bsp/mpc55xx: Round PLL divider up | Sebastian Huber | 2013-07-05 | 1 | -1/+2 |
* | bsp/psim: Use EABI and System V small-data area | Ralf Kirchner | 2013-07-05 | 1 | -1/+1 |
* | bsps/powerpc: Avoid placement in small-data area | Ralf Kirchner | 2013-07-05 | 1 | -2/+2 |
* | bsp/psim: Fix declaration | Ralf Kirchner | 2013-07-05 | 1 | -2/+2 |
| | | | | It declares a symbol defined in the linker command file. | ||||
* | bsps/arm: Add PL050 support | Sebastian Huber | 2013-06-29 | 6 | -0/+257 |
* | bsps/arm: Add PL111 support | Sebastian Huber | 2013-06-29 | 7 | -1/+561 |
* | libchip/serial: Add const qualifier | Sebastian Huber | 2013-06-29 | 1 | -1/+1 |
* | framebuffer: Add and use FRAMEBUFFER_DEVICE_0_NAME | Sebastian Huber | 2013-06-29 | 5 | -10/+11 |
* | make: Use C flags for C++ as default | Sebastian Huber | 2013-06-29 | 1 | -2/+2 |
| | | | | | In case a BSP selects special CFLAGS_OPTIMIZE_V flags then they will be also used for CXXFLAGS_OPTIMIZE_V automatically for example. | ||||
* | bsp/psim: Use plain symbol for PSIM | Sebastian Huber | 2013-06-28 | 3 | -27/+2 |
| | | | | This avoids a linker assertion failure in the GCC test suite. | ||||
* | bsps/powerpc: Update debug sections | Sebastian Huber | 2013-06-28 | 1 | -18/+18 |
* | bsps/arm: Set vector base on all processors | Sebastian Huber | 2013-06-28 | 1 | -16/+23 |
* | bsps/arm: Move input sections | Sebastian Huber | 2013-06-28 | 1 | -6/+6 |
| | | | | Move input sections to preserve order of the default Binutils script. | ||||
* | powerpc: Fix Altivec support | Sebastian Huber | 2013-06-26 | 1 | -1/+1 |
| | | | | Use the right context. | ||||
* | bsps/arm: Fix set exception handler for ARMv7 | Sebastian Huber | 2013-06-26 | 1 | -0/+8 |
* | termios: Update due to API changes | Sebastian Huber | 2013-06-25 | 28 | -272/+256 |
* | bsps/arm: Rename function | Sebastian Huber | 2013-06-24 | 4 | -5/+5 |
| | | | | | | Rename arm_cp15_start_setup_translation_table_and_enable_mmu() in arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache() to emphasize that the cache is also enabled after this operation. | ||||
* | bsp/virtex: Use shared clock driver | Sebastian Huber | 2013-06-24 | 3 | -12/+5 |
* | bsp/virtex: Add console devices only if present | Sebastian Huber | 2013-06-24 | 1 | -10/+11 |
