* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 7 | -6/+84 |
| | | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | ||||
* | Added support for rtems_message_queue_get_number_pending. | Joel Sherrill | 1997-07-31 | 4 | -0/+21 |
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 6 | -30/+139 |
* | Added comment to indicate what the commented out C_PIECES indicated. | Joel Sherrill | 1997-07-31 | 1 | -2/+3 |
* | fixed typo | Joel Sherrill | 1997-07-18 | 2 | -8/+8 |
* | Reordered specs. | Joel Sherrill | 1997-07-10 | 1 | -4/+4 |
* | fixed milliseconds and microseconds to tick conversion routines. | Joel Sherrill | 1997-07-10 | 1 | -11/+10 |
* | Added information on different MVME162 models. | Joel Sherrill | 1997-07-10 | 1 | -0/+11 |
* | Strip the trace bit from the SR register when dispatching a thread when | Joel Sherrill | 1997-07-10 | 1 | -3/+5 |
| | | | | | exiting from an ISR. This allows the trace bit to be set on a per task basis and tracing to be limited to that task. | ||||
* | Repository damaged -- file re-added | Joel Sherrill | 1997-07-09 | 3 | -0/+555 |
* | Repository damaged -- files readded. | Joel Sherrill | 1997-07-09 | 2 | -0/+411 |
* | Changed name from entry to thread_entry to be more compatible with | Joel Sherrill | 1997-07-09 | 3 | -3/+3 |
| | | | | Ada interface where entry is a keyword. | ||||
* | Used macro instead of hard coded number. | Joel Sherrill | 1997-07-09 | 1 | -1/+1 |
* | Added postswitch extension. | Joel Sherrill | 1997-07-09 | 2 | -0/+4 |
* | Added post switch extension. | Joel Sherrill | 1997-07-09 | 2 | -0/+10 |
* | Corrected typos and spacing. | Joel Sherrill | 1997-07-09 | 2 | -6/+6 |
* | This code was in the tree but not actually being compiled. There | Joel Sherrill | 1997-07-09 | 34 | -140/+140 |
| | | | | | | | were a number of minor problems which had to be fixed to get it to compile including modifying the compile rule to handle C++ comments, changing the syntax of the include statement, and getting rid of "%" as part of register names. | ||||
* | Added sp, sfc, and fpcsr register defines. | Joel Sherrill | 1997-07-09 | 1 | -0/+4 |
* | new file | Joel Sherrill | 1997-06-04 | 2 | -0/+90 |
* | corrected name of test suite | Joel Sherrill | 1997-06-03 | 30 | -30/+30 |
* | fixed comment | Joel Sherrill | 1997-06-03 | 1 | -1/+1 |
* | Removed configuration information. | Joel Sherrill | 1997-06-03 | 1 | -54/+0 |
* | new file | Joel Sherrill | 1997-06-03 | 4 | -0/+181 |
* | Removed Configuration Information. | Joel Sherrill | 1997-06-03 | 1 | -54/+0 |
* | new files. | Joel Sherrill | 1997-06-03 | 2 | -0/+89 |
* | Removed configuration information. | Joel Sherrill | 1997-06-03 | 1 | -42/+0 |
* | new files | Joel Sherrill | 1997-06-03 | 5 | -0/+362 |
* | new file. | Joel Sherrill | 1997-06-03 | 1 | -0/+9 |
* | corrected to compile with the new binding. | Joel Sherrill | 1997-06-03 | 5 | -35/+119 |
* | Corrected for this test. | Joel Sherrill | 1997-06-03 | 1 | -0/+1 |
* | Added correct contents | Joel Sherrill | 1997-06-03 | 1 | -0/+57 |
* | new file | Joel Sherrill | 1997-06-03 | 4 | -0/+700 |
* | Corrected maximum number of messages to be non-zero | Joel Sherrill | 1997-06-03 | 1 | -1/+1 |
* | removed reference to Stub Device Driver | Joel Sherrill | 1997-06-03 | 1 | -1/+0 |
* | Replaced prototype for Last_Task which was accidentally removed when | Joel Sherrill | 1997-06-03 | 1 | -0/+14 |
| | | | | the Configuration Tables were deleted from the Ada specification. | ||||
* | Changed RTEMS.Boolean to Standard.Boolean to avoid typing problems. | Joel Sherrill | 1997-06-03 | 1 | -1/+1 |
* | Fixed incorrect invocation of Message_Queue_Create | Joel Sherrill | 1997-06-03 | 1 | -1/+0 |
* | fixed typo which resulted in Message_Queue_Create being invoked incorrectly. | Joel Sherrill | 1997-06-03 | 1 | -1/+0 |
* | Fixed calls to Message_Queue_Create to include maximum message size | Joel Sherrill | 1997-06-03 | 9 | -5/+14 |
| | | | | parameter. | ||||
* | Changed to variable length messages. | Joel Sherrill | 1997-06-03 | 17 | -66/+219 |
* | Changed Task_Entry_Point to Task_Entry to be correct per 4.0.0. | Joel Sherrill | 1997-06-03 | 11 | -11/+11 |
* | Changed type Task_Entry_Point to Task_Entry to be correct per 4.0.0. | Joel Sherrill | 1997-06-03 | 1 | -1/+1 |
* | Fixed all references to Semaphore_Create to have the correct | Joel Sherrill | 1997-06-03 | 7 | -5/+12 |
| | | | | argument sequence. | ||||
* | New file. | Joel Sherrill | 1997-06-03 | 28 | -0/+1045 |
* | new file | Joel Sherrill | 1997-06-03 | 28 | -0/+1596 |
* | Removed Configuration Table information. | Joel Sherrill | 1997-06-03 | 30 | -1170/+0 |
* | Corrected call to Semaphore_Create to have the proper calling sequence | Joel Sherrill | 1997-06-03 | 1 | -0/+2 |
* | Removed Configuration Table information | Joel Sherrill | 1997-06-03 | 1 | -38/+0 |
* | new file | Joel Sherrill | 1997-06-03 | 2 | -0/+94 |
* | Removed unnecessary dependency on RTEMS_Test_Support which existed | Joel Sherrill | 1997-06-03 | 1 | -1/+0 |
| | | | | in the RTEMS Ada implementation but does not exist in this binding. |
