* configure.ac: Add RTEMS_PROG_CCAS.
* Makefile.am: Use automake compilation rules.
* Makefile.am: Cosmetics.
wrapup/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
* configure.ac: Add RTEMS_ENV_RTEMSBSP.
* Makefile.am: Merge-in debug_ada/Makefile.am, debug_c/Makefile.am,
dos_sup/Makefile.am, network_ada/adasockets/Makefile.am,
network_ada/Makefile.am, network_ada/listener/Makefile.am,
network_ada/tcprelay/Makefile.am, ts_1325_ada/Makefile.am. Use automake
compilation rules.
* debug_ada/Makefile.am, debug_c/Makefile.am, dos_sup/Makefile.am,
network_ada/adasockets/Makefile.am, network_ada/Makefile.am,
network_ada/listener/Makefile.am, network_ada/tcprelay/Makefile.am,
ts_1325_ada/Makefile.am: Remove.
network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, startup/Makefile.am,
* Makefile.am: Merge-in clock/Makefile.am, gdbsci/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am, console/Makefile.am,
scitab/Makefile.am, trap34/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, gdbsci/Makefile.am, startup/Makefile.am,
wrapup/Makefile.am, console/Makefile.am, scitab/Makefile.am,
trap34/Makefile.am: Remove.
* Makefile.am: Merge-in console/Makefile.am, hw_init/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am. Use automake compilation rules.
* console/Makefile.am, hw_init/Makefile.am, startup/Makefile.am,
* Makefile.am: Merge-in console/Makefile.am, scitab/Makefile.am,
* console/Makefile.am, scitab/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Remove.
wrapup/Makefile.am.
Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
* Makefile.am: Merge-in clock/Makefile.am, erc32sonic/Makefile.am,
startup/Makefile.am, console/Makefile.am, gnatsupp/Makefile.am,
* clock/Makefile.am, erc32sonic/Makefile.am, startup/Makefile.am,
console/Makefile.am, gnatsupp/Makefile.am, timer/Makefile.am,
start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am.
* include/bsp.h: Remove config.
* irq/irq.c: Remove stray blanks.
* start/start.S: Add missing */ in comments.
* start/start.S, startup/libcfunc.c, startup/syscalls.c:
Include bspopts.h for ARM_RDI_MONITOR.
network/Makefile.am, irq/Makefile.am, start/Makefile.am,
compilation rules.
irq/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, irq/Makefile.am,
* Makefile.am: Distribute start/startfor340only.S.
* Makefile.am: Don't include subdirs.am.
* start/reset.S: Remove cat(). Add EXPAND(). Make EXCEPTION_HANDLER
ANSI-C compliant.
wrapup/Makefile.am.
Remove.
* Makefile.am: Reflect having changed libcpu/m68k/mcf5206/console.rel
to libcpu/m68k/mcf5206/mcfuart.rel
* mcf5206/Makefile.am: Rename console.rel to mcfuart.rel.
* Makefile.am: Merge-in console/Makefile.am, i2c/Makefile.am,
nvram/Makefile.am, startup/Makefile.am, tod/Makefile.am,
wrapup/Makefile.am.
* console/Makefile.am, i2c/Makefile.am, nvram/Makefile.am,
startup/Makefile.am, tod/Makefile.am, wrapup/Makefile.am:
Remove.
* Makefile.am: Fix typo.
spurious/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am.
* clock/Makefile.am, console/Makefile.am, spurious/Makefile.am,
Remove.
wrapup/Makefile.am.
Remove.
fatal/Makefile.am, network/Makefile.am, startup/Makefile.am,
* clock/Makefile.am, console/Makefile.am, fatal/Makefile.am,
wrapup/Makefile.am.
Remove.
* console/console-recording.c: Remove (rename to console-recording.h).
* console/console-recording.h: New.
PR 562/bsps
* Makefile.am: Remove references to m68k-gdbstub.c,
rtems-gdbstub-glue.c.
network/Makefile.am, startup/Makefile.am, timer/Makefile.am.
Use automake-compilation rules.
Remove.
* README: Remove references to consolex.
tod/Makefile.am.
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am: Remove.
