* lib/tftpDriver.c: Restore write capability.
* configure.ac: Remove RTEMS_ENABLE_NETWORKING.
This was tracked as PR88.
* libc/scandir.c: Fixed to perform cleanup on error conditions.
* configure.ac: Replace RTEMS_BSPOPTS_BSP with RTEMS_BSPOPTS_SET (typo).
* include/Makefile.am: Use _HEADER instead of H_FILES.
* irq/Makefile.am: Ditto.
* openpic/Makefile.am: Ditto.
* include/bsp.h: Include <bspopts.h>.
* Makefile.am: Add DIST_SUBDIRS.
This was tracked as PR91.
* include/rtems/score/isr.h, inline/rtems/score/isr.inl,
macros/rtems/score/isr.inl: Modified to allow any port to provide
its own implementation of the macro _ISR_Is_in_progress. If the
port overrides this macro, it must provide a non-inlined function
implementation.
This was tracked as PR87.
* README, configure.ac, include/Makefile.am, include/bsp.h,
start/start.S, startup/FPGA.c, startup/Makefile.am, tod/Makefile.am:
Eliminated conditional code for generation 1 boards as these are
no longer available.
* include/gen1.h, startup/82378zb.c, tod/tod_g1.c: Deleted.
* rtems/score/c_isr.inl: Deleted and contents merged into cpu.c.
* cpu.c: Received contents of c_isr.inl.
* Makefile.am: Deleted reference to c_isr.inl.
* wrapup/Makefile.am: Remove HAS_IMFS.
* ppc403/vectors/vectors.S: Include <bsp.h>.
* shared/include/cpu.h: Remove stray empty lines.
This was tracked as PR39.
* include/bsp.h, start/cpuboot.c, start/reset.S, startup/debugger,
startup/linkcmds, startup/rom: Eliminated required definition of
macros in the custom file for the BSP to compile. The ROM and ROM
address and size settings are now linker script items.
* new_exception_processing/Makefile.in,
new_exception_processing/.cvsignore,
new_exception_processing/Makefile.am,
new_exception_processing/c_isr.inl,
new_exception_processing/cpu.c, new_exception_processing/cpu.h,
new_exception_processing/cpu_asm.S,
old_exception_processing/Makefile.in,
old_exception_processing/.cvsignore,
old_exception_processing/Makefile.am, old_exception_processing/README,
old_exception_processing/TODO, old_exception_processing/c_isr.inl,
old_exception_processing/cpu.c, old_exception_processing/cpu.h,
old_exception_processing/cpu_asm.S, old_exception_processing/irq_stub.S,
old_exception_processing/ppc_offs.h,
old_exception_processing/ppccache.c, old_exception_processing/rtems.S:
Deleted since now under libbsp.
* configure.ac: Remove old_exception_processing,
new_exception_processing.
* Makefile.am: Ditto.
* configure.ac: Add RTEMS_BSPOPTS_*(DATA_CACHE_ENABLE),
RTEMS_BSPOPTS_*(INSTRUCTION_CACHE_ENABLE).
* Makefile.am: Remove . from SUBDIRS, remove duplicate bsp_specs
rules, add @exceptions@ to SUBDIRS.
* configure.ac: Add RTEMS_BSPOPTS_*(PPC_USE_SPRG),
RTEMS_BSPOPTS_*(PPC_VECTOR_FILE_BASE),
RTEMS_PPC_EXCEPTIONS([old]), autoupdate to autoconf 2.52.
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
* Makefile.am: Remove . from SUBDIRS, add @exceptions@ to
SUBDIRS.
RTEMS_PPC_EXCEPTIONS([old]).
* .cvsignore: Add aclocal.m4, autom4te.*, config.*, configure.
* vectors/vectors.S: Include <bsp.h> to get PPC_VECTOR_FILE_BASE.
* acinclude.m4: papyrus reference removed.
* papyrus/.cvsignore, papyrus/ChangeLog, papyrus/Makefile.am,
papyrus/README, papyrus/bsp_specs, papyrus/configure.ac, papyrus/times,
papyrus/dlentry/.cvsignore, papyrus/dlentry/Makefile.am,
papyrus/dlentry/dlentry.S, papyrus/flashentry/.cvsignore,
papyrus/flashentry/Makefile.am, papyrus/flashentry/flashentry.S,
papyrus/include/.cvsignore, papyrus/include/Makefile.am,
papyrus/include/bsp.h, papyrus/include/coverhd.h,
papyrus/startup/.cvsignore, papyrus/startup/Makefile.am,
papyrus/startup/bspclean.c, papyrus/startup/bspstart.c,
papyrus/startup/linkcmds, papyrus/startup/setvec.c,
papyrus/wrapup/.cvsignore, papyrus/wrapup/Makefile.am: Deleted.
* network/sonic.h: Fix typo.
* src/imfs/Makefile.am: Cleanup.
* arpa/Makefile.am: Remove stray lines.
* cdtest/main.cc: Remove RTEMS_TEST_IO_STREAM.
* configure.ac: Remove mpc750 from new_exception_processing,
Remove mpc604 from new_exception_processing.
* Makefile.am: Add @exceptions@ to SUBDIRS;
Remove need_motorola_powerpc.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/mcp750.cfg, make/custom/mvme2307.cfg;
Remove need_motorola_powerpc;
Add RTEMS_PPC_EXCEPTIONS([new]).
* include/Makefile.am: Replace PREINSTALL_FILES with
* Makefile.am: Preinstall c_isr.inl (HACK).
* ChangeLog: New file.
* configure.ac: Remove ppc603e from old_exception_processing.
* Makefile.am: Add @exceptions@ to SUBDIRS.
make/custom/score603e.cfg;
Add automake conditional for SCORE_GENERATION_1;
Add RTEMS_PPC_EXCEPTIONS([old]).
* include/Makefile.am: include force-preinstall.am.
* start/start.S: include <bspopts.h> instead of targopts.h.
* tod/Makefile.am: Apply SCORE_GENERATION_1 conditional.
* vectors/vector.S: include <bsp.h>.
make/custom/ppcn_60x.cfg;
make/custom/psim.cfg;
Remove RTEMS_OUTPUT_BUILD_SUBDIRS;
* include/bspopts.h.in: Automatically generated file that should not
be in CVS.
* configure.ac: Remove mpc8xx from new_exception_processing.
* support/new_exception_processing/configure.ac,
support/new_exception_processing/rtems/score/c_isr.inl,
support/new_exception_processing/rtems/score/cpu.h,
support/old_exception_processing/configure.ac,
support/old_exception_processing/rtems/score/c_isr.inl,
support/old_exception_processing/rtems/score/cpu.h,
support/old_exception_processing/rtems/score/ppc_offs.h: New files
missed in previous commit.
make/custom/dmv177.cfg;
Rename PPC_USE_INSTRUCTION_CACHE to DMV177_USE_INSTRUCTION_CACHE,
* startup/bspstart.c: Rename PPC_USE_INSTRUCTION_CACHE to
DMV177_USE_INSTRUCTION_CACHE.
* configure.ac: Add RTEMS_BSPOPTS_*(), merge-in settings
from make/custom/mbx*.cfg, add RTEMS_PPC_EXCEPTIONS([new]).
* vectors/Makefile.am: remove bogus VPATH.
* configure.ac: Remove mpc8620 from new_exception_processing.
make/custom/mpc8260ads.cfg, add RTEMS_PPC_EXCEPTIONS([new]).
* configure.ac: Add RTEMS_BSPOPTS_*(UARTS_IO_MODE),
* irq/Makefile.am: remove irq.h from EXTRA_DIST.
* support/new_exception_processing/Makefile.am,
support/old_exception_processing/Makefile.am,
support/old_exception_processing/cpu_asm.S,
support/old_exception_processing/irq_stub.S: Modified to reflect
old versus new exception processing being a per BSP option.
* support/new_exception_processing/c_isr.inl,
support/new_exception_processing/cpu.h,
support/old_exception_processing/c_isr.inl,
support/old_exception_processing/cpu.h,
support/old_exception_processing/ppc_offs.h: Removed.
* ChangeLog: Corrected spacing.
* console/console-io.c: Fix incorrect comment.
* src/threadhandler.c: When __USE__MAIN__ is defined by the toolset,
invoke the global constructors via __main. Reported as tested by
Alexandra Kossovsky <sasha@oktet.ru> and Victor V. Vengerov
<vvv@oktet.ru> in conjunction with a new set of tool RPMs
(gcc2.95.3newlib1.9.0-3). This was tracked as GNATS PR tools/84.
* configure.ac: Add RTEMS_BSPOPTS_*(CPU_CLOCK_RATE_HZ),
RTEMS_BSPOPTS_*(START_HW_INIT),
RTEMS_BSPOPTS_*(STANDALONE_EVB).
* wrapup/Makefile.am: Apply RTEMS_CPU_MODEL to pickup CPU_PIECES.
* configure.ac: Apply RTEMS_BSPOPTS_*(CPU_CLOCK_RATE_HZ).
* configure.ac: Add RTEMS_BSPOPTS_*(USE_CONSOLE_A),
add RTEMS_BSPOPTS_*(USE_CONSOLE_B).
