* Makefile.am: Fix typo in previous patch.
* automake/compile.am: Add RTEMS_RELLDFLAGS.
Remove XLDFLAGS.
* Makefile.am: Use automake compilation rules.
* wrapup/Makefile.am: Reflect changes to libchip/*.
* support/Makefile.am: Use automake compilation rules.
* wrapup/Makefile.am: Reflect changes to support/*.
* configure.ac: Remove libnetworking/wrapup/Makefile.
* wrapup/Makefile.am: Reflect change to libnetworking/*.
Use libnetworking/*/lib*.a instead of libnetapps.a
* Makefile.am: Remove wrapup.
* pppd/Makefile.am: Build libpppd.
Use automake-compilation rules.
* rtems_servers/Makefile.am: Build libftpd.
* rtems_telnetd/Makefile.am: Build libtelnetd.
* rtems_webserver/Makefile.am: Build libhttpd.
* wrapup/Makefile.am: Remove (Unused).
* configure.ac: Add subdir-objects to AUTOMAKE_OPTIONS.
Require automake-1.8.2.
Add RTEMS_PROG_CCAS.
Add AM_PROG_CC_C_O.
* Makefile.am: Use automake-compilation rules.
* Makefile.am: Remove gdbstub/rtems-stub-glue.c (Non-existent)
* start/.cvsignore: Remove.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* wrapup/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* automake/lib.am: Remove TMPINSTALL_FILES.
* pppd/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Ditto.
* rtems_telnetd/Makefile.am: Ditto.
* rtems_webserver/Makefile.am: Ditto.
* startup/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* startup/Makefile.am: Ditto.
* console/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Ditto.
* motorola/Makefile.am: Ditto.
* openpic/Makefile.am: Ditto.
* pci/Makefile.am: Ditto.
* residual/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* start/Makefile.am: Ditto.
* bootloader/Makefile.am: Ditto.
* vme/Makefile.am: Ditto.
* start/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* consolex/Makefile.am: Ditto.
* configure.ac: Ditto.
* console/Makefile.am: Ditto.
* cache/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* mpc505/Makefile.am: Ditto.
* mpc6xx/Makefile.am: Ditto.
* mpc8260/Makefile.am: Ditto.
* mpc8xx/Makefile.am: Ditto.
* ppc403/Makefile.am: Ditto.
* shared/Makefile.am: Ditto.
* mongoosev/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* tx39/Makefile.am: Ditto.
* shared/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* include/rdbg/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* include/rdbg/i386/Makefile.am: Ditto.
* include/rdbg/m68k/Makefile.am: Ditto.
* include/rdbg/powerpc/Makefile.am: Ditto.
* src/i386/Makefile.am: Ditto.
* src/m68k/Makefile.am: Ditto.
* src/powerpc/Makefile.am: Ditto.
* Makefile.am: Move include_adadir into RTEMS_ADA condional block.
Add CLEANFILES. Add PREINSTALL_FILES to CLEANFILES.
* mpc6xx/Makefile.am: Remove libcpuspec.a (Unused).
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of
$(RTEMS_BSP_FAMILY).
* mpc505/Makefile.am: Fix typo vectors/vectors.S.
* shared/Makefile.am: Fix typo
EXTRA_DIST = $(libcpuspec_C_FILES)
* gnatsupp/Makefile.am: Eliminate VPATH.
* ACKNOWLEDGEMENTS: Remove efi68k and efi332 references as they are no
longer in the tree.
* times, console/sci.c: Remove efi68k and efi332 references as they are
no longer in the tree.
* acinclude.m4: Remove efi68k and efi332 references as they are no
longer in the tree.
* timer/timer.c: Remove efi68k and efi332 references as they are no
longer in the tree.
