1997-04-22 | File changed to reflect change in license and copyright. | Joel Sherrill | 1 | -5/+5 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1344 | -6686/+6686 | |
of switching to the modified GNU GPL. | |||||
1997-04-22 | LICENSE file is now only in top directory. | Joel Sherrill | 1 | -9/+1 | |
README updated. | |||||
1997-04-22 | corrected some email addresses | Joel Sherrill | 1 | -4/+4 | |
1997-04-22 | corrected Tony Bennett's email address | Joel Sherrill | 1 | -1/+1 | |
1997-04-22 | Added support for HW API package | Joel Sherrill | 2 | -11/+7 | |
1997-04-18 | Modified to reflect change from 255 posix priority levels to 254. | Joel Sherrill | 3 | -6/+6 | |
1997-04-18 | Changed format of comment blocks to C comments. | Joel Sherrill | 3 | -51/+51 | |
1997-04-18 | Duplicated timerisr symbol as _timerisr to avoid tool naming problems. | Joel Sherrill | 1 | -0/+6 | |
1997-04-18 | Corrected incorrect settings for locations of psx and sp test screens. | Joel Sherrill | 1 | -2/+2 | |
1997-04-16 | Fixed path which points to shared directory for all BSPs. | Joel Sherrill | 20 | -20/+20 | |
1997-04-16 | fixed spacing | Joel Sherrill | 1 | -1/+3 | |
1997-04-16 | added fpsp support. | Joel Sherrill | 1 | -0/+2 | |
1997-04-16 | Update from Eric Norum. | Joel Sherrill | 8 | -174/+414 | |
1997-04-16 | Updated to reflect Tony Bennett's new email address and the incorporation | Joel Sherrill | 1 | -3/+5 | |
of the ka9q stack, m68040 fpsp, gen68360_040 bsp submitted by Eric Norum. | |||||
1997-04-16 | Added FPSP support for MC68040 | Joel Sherrill | 3 | -5/+71 | |
1997-04-16 | Added CVS Id's | Joel Sherrill | 2 | -0/+7 | |
1997-04-16 | Added the MC68040 Floating Point Support Package. This was ported | Joel Sherrill | 47 | -0/+16820 | |
to RTEMS by Eric Norum. It is freely distributable and was acquired from the Motorola WWW site. More info is in the FPSP README. | |||||
1997-04-15 | Reduced number of POSIX thread priorities from 255 to 254 to avoid conflicts | Joel Sherrill | 4 | -8/+20 | |
of lowest priority with the RTEMS IDLE thread. This was causing the lowest priority GNAT Ada task to never run. | |||||
1997-04-15 | Added directories to place test output screens into as part of fixing | Joel Sherrill | 1 | -3/+4 | |
difftest. | |||||
1997-04-15 | Added line to install test screens so difftest does not have to have | Joel Sherrill | 65 | -7/+137 | |
a path back into the source tree. This would be better for binary distributions as well since you now have the correct output at the install point. | |||||
1997-04-15 | Switched all bsps which had an implementation of sbrk.c which only | Joel Sherrill | 20 | -19/+51 | |
returned an error to using a single shared copy of this file. | |||||
1997-04-15 | Removed many BSPs' copy of setvec.c and let them share the same | Joel Sherrill | 10 | -9/+48 | |
implementation as all m68k BSPs. | |||||
1997-04-11 | replaced linking of source from mvme147 drivers with use of vpath to | Joel Sherrill | 4 | -29/+8 | |
simply search into that directory and get the necessary files. | |||||
1997-04-11 | removed commented out line performing a link | Joel Sherrill | 2 | -2/+0 | |
1997-04-09 | enabled floating point and fixed confdef reference to initialization | Joel Sherrill | 4 | -5/+9 | |
tasks table. | |||||
1997-04-09 | new test | Joel Sherrill | 14 | -0/+862 | |
1997-04-09 | added cpuuse and rtmonuse | Joel Sherrill | 1 | -1/+1 | |
1997-04-09 | printing task names now instead of id numbers | Joel Sherrill | 2 | -6/+32 | |
1997-04-09 | new files. | Joel Sherrill | 16 | -0/+1234 | |
1997-04-09 | added rtmonuse and cpuuse directories | Joel Sherrill | 2 | -0/+4 | |
1997-04-09 | added cpuuse and rtmonuse directories | Joel Sherrill | 1 | -1/+1 | |
1997-04-09 | added code to prevent attempts to clean up the library when rtems is | Joel Sherrill | 2 | -0/+16 | |
down. | |||||
1997-04-09 | correct incorrect register addresses for port a. | Joel Sherrill | 1 | -2/+2 | |
1997-04-09 | removed unused is_character_ready routine. | Joel Sherrill | 1 | -27/+0 | |
1997-04-09 | added support for tracking thread cpu usage. | Joel Sherrill | 1 | -0/+2 | |
1997-04-09 | enhanced printf statements | Joel Sherrill | 1 | -4/+4 | |
1997-04-09 | corrected spacing. | Joel Sherrill | 2 | -16/+16 | |
1997-04-09 | added SYSTEM_STATE_SHUTDOWN | Joel Sherrill | 2 | -0/+2 | |
1997-04-09 | enhanced rtems_shutdown_executive to insure that no attempt will | Joel Sherrill | 1 | -1/+4 | |
be made to shut the system down when it is down. | |||||
1997-04-09 | added support for statistics on rate monotonic periods. | Joel Sherrill | 3 | -15/+142 | |
1997-04-09 | Added ka9q tcpip stack and network driver for the gen68360. This effort | Joel Sherrill | 37 | -133/+1030 | |
was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point. | |||||
1997-04-08 | added cast to eliminate warning. | Joel Sherrill | 1 | -1/+1 | |
1997-04-07 | corrected printf specifications and added casts as necessary to eliminate | Joel Sherrill | 7 | -72/+79 | |
warnings. | |||||
1997-04-07 | added ifdef to avoid warning for unused variable. | Joel Sherrill | 1 | -2/+6 | |
1997-04-07 | corrected integer only definitions of "FP CHECK" routines to eliminate | Joel Sherrill | 1 | -3/+10 | |
warnings. | |||||
1997-04-07 | changed signed int to unsigned int to eliminate a warning. | Joel Sherrill | 2 | -2/+2 | |
1997-04-07 | removed noreturn attribute to eliminate warnings. | Joel Sherrill | 5 | -10/+35 | |
1997-04-07 | commented out sccs_id's to eliminate warnings. | Joel Sherrill | 4 | -12/+28 | |
1997-04-07 | added prototype and return statement to eliminate warnings. | Joel Sherrill | 1 | -0/+4 | |
