* | Removed nanosleep() since it is now in its own file. | Joel Sherrill | 1999-11-15 | 1 | -21/+0 |
* | Returned third parameter for a NULL name to the objects open call. | Jennifer Averett | 1999-11-15 | 1 | -1/+1 |
* | + Fixed files to consistantly use a case of the location after calls | Jennifer Averett | 1999-11-15 | 11 | -81/+97 |
| | | | | | | to ITRON_Task_Get. + Modified to consistantly call _ITRON_return_errorno with E_OK. + Optimized the code to not disable dispatch prior to checking input values. | ||||
* | + Modified to use new Thread_Reset routine instead of the restart method. | Jennifer Averett | 1999-11-15 | 1 | -1/+1 |
* | Fixed verificaiton checks to call correct macro if dispatch is disabled. | Jennifer Averett | 1999-11-15 | 1 | -7/+12 |
* | + Added check that a task could be sent to a dormant state | Jennifer Averett | 1999-11-15 | 4 | -12/+94 |
| | | | | | | | | then sta_tsk used to restart the task to its initial state. + Added calls to ref_tsk to yellow paths for suspended and ready but not running tasks. + Fixed output file to correctly state test name + Added priority of preempt to the header file. Allows ref_tsk verification. | ||||
* | + Changed preempt routine into two dummy tasks one that is in dormant | Jennifer Averett | 1999-11-15 | 4 | -20/+70 |
| | | | | | | | | state and one that is in non-dormant state. + Increased the priority of the Init task to force the dummy tasks to run first. + Added calls to ref_tsk to verify the state of the dummy tasks and test ref_tsk. | ||||
* | Split ITRON Message Buffer Manager into multiple files. | Joel Sherrill | 1999-11-15 | 12 | -355/+524 |
* | Split ITRON semaphore manager into multiple files. | Joel Sherrill | 1999-11-15 | 9 | -285/+378 |
* | + Modified calls to use TSK_SLF for calls to self. | Joel Sherrill | 1999-11-12 | 1 | -25/+24 |
| | | | | + Modified calls to use the task id macro for calls to the PREEMPT task. | ||||
* | + Added comments on paths tested. | Joel Sherrill | 1999-11-12 | 2 | -1/+14 |
* | + Added check for priority over 256. | Joel Sherrill | 1999-11-12 | 1 | -1/+4 |
| | | | | + Modified output to correctly state the error. | ||||
* | Added comments for path's tested. | Joel Sherrill | 1999-11-12 | 1 | -0/+3 |
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 4 | -37/+27 |
| | | | | | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead of enabling dispatching and returning E_OK. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 1 | -11/+11 |
| | | | | + Removed error path that should never happen. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 2 | -17/+8 |
* | + Moved error checks to before the disable dispatch where possible. | Joel Sherrill | 1999-11-12 | 1 | -5/+5 |
* | Added comment about the E_CTX error condition (Implementation dependent). | Joel Sherrill | 1999-11-12 | 1 | -0/+7 |
* | + Moved error checks to before the dispatch disable where possible. | Joel Sherrill | 1999-11-12 | 1 | -13/+12 |
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 1 | -15/+10 |
| | | | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. + Set correct error code when dormant state. + Fixed comment. | ||||
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 1 | -5/+2 |
| | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. | ||||
* | Corrected so now actually indexes into the allocation block. | Joel Sherrill | 1999-11-12 | 1 | -10/+6 |
* | Corrected remaining references to struct rtems_task_variable_t since | Joel Sherrill | 1999-11-12 | 2 | -7/+11 |
| | | | | it is now typedef'ed. | ||||
* | Removed unnecessary 3rd parameter. | Joel Sherrill | 1999-11-12 | 1 | -1/+1 |
* | New file. | Joel Sherrill | 1999-11-12 | 1 | -0/+13 |
* | Used typedef so all "struct rtems_task_variable_t" uses are now | Joel Sherrill | 1999-11-12 | 4 | -19/+19 |
| | | | | just "rtems_task_variable_t". | ||||
* | Added per-task variable data stucture (rtems_task_variable_t), | Joel Sherrill | 1999-11-12 | 1 | -4/+36 |
| | | | | | task_variables field to API extension, and two directives (rtems_task_variable_add and rtems_task_variable_delete). | ||||
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 6 | -8/+9 |
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 2 | -6/+11 |
| | | | | Changed output to reflect what was actually being tested. | ||||
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 4 | -5/+9 |
| | | | | Increased stack space. | ||||
* | Added per task variables based on patch from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-12 | 4 | -4/+224 |
| | | | | | After being submitted, this support was rewritten to be inside the executive rather than layered on top of it using an extension. | ||||
* | Cleaned up style. | Joel Sherrill | 1999-11-12 | 1 | -243/+239 |
* | Removed redundant line. | Joel Sherrill | 1999-11-12 | 1 | -1/+0 |
* | Enabled after merging message buffer code. | Joel Sherrill | 1999-11-12 | 1 | -6/+2 |
* | Added comment block and removed include of deleted file. | Joel Sherrill | 1999-11-12 | 1 | -1/+4 |
* | Updated. | Joel Sherrill | 1999-11-11 | 1 | -4/+15 |
* | Screen updated. | Joel Sherrill | 1999-11-11 | 1 | -0/+2 |
* | Added new test sp28 to test the task variable directives. | Joel Sherrill | 1999-11-11 | 6 | -1/+180 |
* | General cleanup. Test documentation improved. The message buffer test | Joel Sherrill | 1999-11-10 | 15 | -22/+81 |
| | | | | | prints a message instead of actually testing since the message buffer implementation is not in yet. | ||||
* | Corrected to account for the way memory is divided up in | Joel Sherrill | 1999-11-10 | 1 | -7/+9 |
| | | | | | _Object_Extend_information. This change is a side-effect of the change made to that file to fix an alignment problem. | ||||
* | Added line to make sure HAS_ITRON_API is defined in Makefile. | Joel Sherrill | 1999-11-10 | 1 | -2/+1 |
* | Added call to _Thread_Enable_dispatch() and did some cleanup. | Joel Sherrill | 1999-11-10 | 1 | -2/+9 |
* | rtems_semaphore_flush test from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-10 | 7 | -28/+186 |
* | Patch from Eric Norum <eric@cls.usask.ca> which includes: | Joel Sherrill | 1999-11-10 | 7 | -17/+327 |
| | | | | | Patches against 1105 snapshot to add NTP server support to network configuration/BOOTP. | ||||
* | Combination of committing some new files which had been overlooked | Joel Sherrill | 1999-11-10 | 13 | -1/+463 |
| | | | | and adding code which installed screens for itron tests. | ||||
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-10 | 35 | -289/+696 |
| | | | | Working Group. Included are tests. | ||||
* | Added support for ITRON tests. | Joel Sherrill | 1999-11-10 | 1 | -0/+2 |
* | Added more tasking tests. | Joel Sherrill | 1999-11-09 | 2 | -1/+5 |
* | Merged tests from Task group. | Joel Sherrill | 1999-11-09 | 36 | -38/+2031 |
* | Added nesting count for suspend/resume. | Joel Sherrill | 1999-11-09 | 1 | -1/+1 |
