* Makefile.am: Move include_adadir into RTEMS_ADA condional block.
Add CLEANFILES. Add PREINSTALL_FILES to CLEANFILES.
* start/.cvsignore: Remove.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* mpc6xx/Makefile.am: Remove libcpuspec.a (Unused).
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of
$(RTEMS_BSP_FAMILY).
* mpc505/Makefile.am: Fix typo vectors/vectors.S.
* shared/Makefile.am: Fix typo
EXTRA_DIST = $(libcpuspec_C_FILES)
* gnatsupp/Makefile.am: Eliminate VPATH.
* ACKNOWLEDGEMENTS: Remove efi68k and efi332 references as they are no
longer in the tree.
* times, console/sci.c: Remove efi68k and efi332 references as they are
no longer in the tree.
* acinclude.m4: Remove efi68k and efi332 references as they are no
longer in the tree.
* timer/timer.c: Remove efi68k and efi332 references as they are no
longer in the tree.
Per John S. Gwynne <jgwynne@mrcday.com>, there are no longer any
users of these boards so we are removing them.
* efi332/.cvsignore, efi332/ChangeLog, efi332/Makefile.am,
efi332/README, efi332/bsp_specs, efi332/configure.ac, efi332/times,
efi332/clock/.cvsignore, efi332/clock/Makefile.am,
efi332/clock/ckinit.c, efi332/console/.cvsignore,
efi332/console/Makefile.am, efi332/console/console.c,
efi332/include/.cvsignore, efi332/include/bsp.h,
efi332/include/efi332.h, efi332/misc/dotests, efi332/misc/gdbinit68,
efi332/misc/interr.c, efi332/spurious/.cvsignore,
efi332/spurious/Makefile.am, efi332/spurious/spinit.c,
efi332/start/.cvsignore, efi332/start/Makefile.am,
efi332/start/except_vect_332_ROM.S, efi332/start/ram_init.ld,
efi332/start/ram_init.sed, efi332/start/start.c,
efi332/startup/.cvsignore, efi332/startup/Makefile.am,
efi332/startup/bspclean.c, efi332/startup/bspstart.c,
efi332/startup/linkcmds, efi332/startup/linkcmds_ROM,
efi332/timer/.cvsignore, efi332/timer/Makefile.am,
efi332/timer/timer.c, efi332/wrapup/.cvsignore,
efi332/wrapup/Makefile.am, efi68k/.cvsignore, efi68k/ChangeLog,
efi68k/Makefile.am, efi68k/README, efi68k/bsp_specs,
efi68k/configure.ac, efi68k/times, efi68k/clock/.cvsignore,
efi68k/clock/Makefile.am, efi68k/clock/ckinit.c,
efi68k/console/.cvsignore, efi68k/console/Makefile.am,
efi68k/console/console.c, efi68k/include/.cvsignore,
efi68k/include/16550.h, efi68k/include/DP8570A.h,
efi68k/include/bsp.h, efi68k/include/efi68k.h,
efi68k/spurious/.cvsignore, efi68k/spurious/Makefile.am,
efi68k/spurious/spinit.c, efi68k/start/.cvsignore,
efi68k/start/start.c, efi68k/startup/.cvsignore,
efi68k/startup/Makefile.am, efi68k/startup/bspclean.c,
efi68k/startup/bspstart.c, efi68k/startup/efi68k_tcp.c,
efi68k/startup/efi68k_wd.c, efi68k/startup/linkcmds,
efi68k/startup/m68k-stub.c, efi68k/startup/setvec.c,
efi68k/timer/.cvsignore, efi68k/timer/Makefile.am,
efi68k/timer/timer.c, efi68k/wrapup/.cvsignore,
efi68k/wrapup/Makefile.am: Removed.
* aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port
more completely covers the MIPS family.
* mips64orion/.cvsignore, mips64orion/ChangeLog,
mips64orion/Makefile.am, mips64orion/configure.ac,
mips64orion/clock/.cvsignore, mips64orion/clock/Makefile.am,
mips64orion/clock/ckinit.c, mips64orion/clock/clock.S,
mips64orion/clock/clock.h, mips64orion/timer/.cvsignore,
mips64orion/timer/Makefile.am, mips64orion/timer/gettime.S,
mips64orion/timer/timer.c: Removed.
mips64orion/Makefile.am, mips64orion/README,
mips64orion/acinclude.m4, mips64orion/configure.ac,
mips64orion/p4000/.cvsignore, mips64orion/p4000/ChangeLog,
mips64orion/p4000/Makefile.am, mips64orion/p4000/README,
mips64orion/p4000/bsp_specs, mips64orion/p4000/configure.ac,
mips64orion/p4000/times, mips64orion/p4000/console/.cvsignore,
mips64orion/p4000/console/Makefile.am,
mips64orion/p4000/console/console.c, mips64orion/p4000/console/led.S,
mips64orion/p4000/include/.cvsignore,
mips64orion/p4000/include/bsp.h, mips64orion/p4000/include/coverhd.h,
mips64orion/p4000/liblnk/.cvsignore,
mips64orion/p4000/liblnk/Makefile.am,
mips64orion/p4000/liblnk/lnklib.S,
mips64orion/p4000/start/.cvsignore,
mips64orion/p4000/start/Makefile.am, mips64orion/p4000/start/start.S,
mips64orion/p4000/startup/.cvsignore,
mips64orion/p4000/startup/Makefile.am,
mips64orion/p4000/startup/bspclean.c,
mips64orion/p4000/startup/bspstart.c,
mips64orion/p4000/startup/ghlinkcmds,
mips64orion/p4000/startup/idtmem.S,
mips64orion/p4000/startup/idttlb.S,
mips64orion/p4000/startup/inittlb.c,
mips64orion/p4000/startup/linkcmds,
mips64orion/p4000/startup/setvec.c,
mips64orion/p4000/wrapup/.cvsignore,
mips64orion/p4000/wrapup/Makefile.am: Removed.
* Makefile.am: Regenerate.
* start/regs.S: Remove.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* tod/Makefile.am: Cosmetics.
* console/Makefile.am: Eliminate *.rel.
Use $(top_srcdir)/../../shared instead of ../../../shared.
* start/Makefile.am: Add BUILD-VARIANTS.
* vectors/Makefile.am: Fix typos.
* vme/Makefile.am: Fix typos.
* PCI_bus/Makefile.am: Eliminate VPATH.
* clock/Makefile.am: Eliminate VPATH.
* console/Makefile.am: Eliminate VPATH.
* start/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
* timer/Makefile.am: Eliminate VPATH.
* tod/Makefile.am: Eliminate VPATH.
* vectors/Makefile.am: Eliminate VPATH.
* shmsupp/Makefile.am: Eliminate VPATH.
* network/Makefile.am: Eliminate VPATH.
* nvram/Makefile.am: Eliminate VPATH.
* pci/Makefile.am: Eliminate VPATH.
* universe/Makefile.am: Eliminate VPATH.
* irq/Makefile.am: Eliminate VPATH.
* bootloader/Makefile.am: Eliminate VPATH.
* motorola/Makefile.am: Eliminate VPATH.
* openpic/Makefile.am: Eliminate VPATH.
* residual/Makefile.am: Eliminate VPATH.
* vme/Makefile.am: Eliminate VPATH.
* ide/Makefile.am: Eliminate VPATH.
* dlentry/Makefile.am: Eliminate VPATH.
* flashentry/Makefile.am: Eliminate VPATH.
* canbus/Makefile.am: Eliminate VPATH.
* scv64/Makefile.am: Eliminate VPATH.
* sonic/Makefile.am: Eliminate VPATH.
PR 545/bsps
* startup/setvec.c: Removed.
PR 545/bsps
* ppc403/Makefile.am: Fix typo in vectors' compilation rule.
* shared/Makefile.am: Use $(top_srcdir)/../shared instead of
relative subdirs.
PR 545/bsps
* wrapup/Makefile.am: Reflect changes to shmdr.
