* | 2008-09-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-08 | 1 | -0/+4 |
| | | | | * ChangeLog: New file. | ||||
* | 2008-09-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-08 | 2 | -31/+137 |
| | | | | | * mcf548x/include/Freescale_license.txt: Convert to UNIX CR/LF style, eliminate characters with 8th bit set. | ||||
* | Derive time base clicks from bus frequency | Thomas Doerfler | 2008-09-08 | 1 | -1/+1 |
* | added new bsp for tqm8xx | Thomas Doerfler | 2008-09-08 | 1 | -0/+4 |
* | some mpc8xx maintenance | Thomas Doerfler | 2008-09-08 | 1 | -0/+7 |
* | maintenance | Thomas Doerfler | 2008-09-08 | 2 | -2/+1 |
* | added new BSP for TQM8xx boards | Thomas Doerfler | 2008-09-08 | 26 | -0/+7160 |
* | added support for flexible PLL in MPC866 and friends | Thomas Doerfler | 2008-09-08 | 1 | -4/+38 |
* | corrected parameters for done signalling | Thomas Doerfler | 2008-09-08 | 2 | -7/+7 |
* | corrected parameters inside i2c driver for done signalling | Thomas Doerfler | 2008-09-08 | 4 | -17/+28 |
* | corrected parameters in i2c driver for done signalling | Thomas Doerfler | 2008-09-08 | 7 | -30/+59 |
| | | | | updated mscan CAN driver | ||||
* | 2008-09-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-08 | 1 | -0/+4 |
| | | | | * mcf548x/include/mcf548x.h: Convert to Unix file format. | ||||
* | Convert to Unix file format. | Ralf Corsepius | 2008-09-08 | 2 | -4109/+4109 |
| | | | | * libchip/ide/ata.h: Convert to Unix file format. | ||||
* | 2008-09-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-07 | 1 | -0/+4 |
| | | | | * shared/comm/i386-stub.c: Include stdbool.h. | ||||
* | Include stdbool.h. | Ralf Corsepius | 2008-09-07 | 1 | -0/+1 |
* | 2008-09-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-07 | 1 | -0/+5 |
| | | | | | | | | * libchip/serial/mc68681.c, libchip/serial/mc68681_p.h, libchip/serial/ns16550.c, libchip/serial/ns16550_p.h, libchip/serial/serial.h, libchip/serial/serprobe.c, libchip/serial/sersupp.h, libchip/serial/z85c30.c: Convert to "bool". | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-07 | 24 | -80/+80 |
* | 2008-09-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-07 | 1 | -0/+2 |
| | | | | | * libchip/i2c/spi-flash-m25p40.c, libchip/i2c/spi-fram-fm25l256.c, libchip/i2c/spi-memdrv.h: Convert to "bool". | ||||
* | 2008-09-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-07 | 1 | -0/+3 |
| | | | | | | * libchip/rtc/ds1375-rtc.h, libchip/rtc/ds1375.c, libchip/rtc/mc146818a.c, libchip/rtc/mc146818a.h, libchip/rtc/rtc.h, libchip/rtc/rtcprobe.c: Convert to "bool". | ||||
| | | | | | * libchip/ide/ata.c, libchip/ide/ata_internal.h, libchip/ide/ide_ctrl_cfg.h: Convert to "bool". | ||||
| | | | | | * libchip/display/disp_hcms29xx.c, libchip/display/disp_hcms29xx.h: Convert to "bool". | ||||
| | | | | | * libchip/network/if_fxp.c, libchip/network/if_fxpvar.h: Convert to "bool". | ||||
| | | | | | * libchip/shmdr/fatal.c, libchip/shmdr/shm_driver.h: Convert to "bool". | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-07 | 2 | -3/+3 |
* | 2008-09-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-06 | 1 | -0/+10 |
| | | | | | | | | | | * mpc5xx/irq/irq.c, mpc83xx/spi/mpc83xx_spidrv.c, new-exceptions/cpu.c, new-exceptions/raw_exception.h, new-exceptions/bspsupport/ppc_exc_hdl.c, ppc403/clock/clock.c, ppc403/clock/clock_4xx.c, ppc403/console/console.c, ppc403/console/console.c.polled, ppc403/console/console405.c, ppc403/tty_drv/tty_drv.c: Convert to "bool". | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-06 | 35 | -123/+121 |
* | 2008-09-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-06 | 1 | -0/+5 |
| | | | | | * interrupt/interrupt.h, serial/spi.h, serial/twi.h, serial/uart.h: Convert to "bool". | ||||
* | Minor "bool" fixes. | Ralf Corsepius | 2008-09-06 | 1 | -1/+1 |
* | 2008-09-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-06 | 1 | -0/+4 |
| | | | | * irq/irq.c: Minor "bool" fixes. | ||||
* | 2008-09-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-06 | 1 | -0/+4 |
| | | | | * startup/m68k-stub.c: Convert to "bool". | ||||
| | | | | * shared/gdbstub/m68k-stub.c: Convert to "bool". | ||||
* | changes | Ralf Corsepius | 2008-09-06 | 1 | -0/+4 |
| | | | | * irq/irq.c: Convert to "bool". | ||||
| | | | | * startup/bspstart.c: Convert to "bool". | ||||
| | | | | * console/console.h: Convert to "bool". | ||||
* | 2008-09-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-06 | 1 | -2/+2 |
| | | | | * console/config.c, console/console.h: Convert to "bool". | ||||
| | | | | * irq/irq.c, startup/bspstart.c: Convert to bool. | ||||
* | Convert to bool. | Ralf Corsepius | 2008-09-06 | 2 | -5/+5 |
| | | | | | * bestcomm/bestcomm_glue.c, ide/pcmcia_ide.c, tod/todcfg.c: Convert to "bool". | ||||
| | | | | | * ide/pcmcia_ide.c, irq/irq.c, startup/bspstart.c, startup/bspstart.c.nocache: Convert to "bool". | ||||
| | | | | * misc/interr.c: Convert to "bool". | ||||
| | | | | * tod/todcfg.c: Convert to "bool". | ||||
| | | | | * ide/ide.c: Convert to "bool". | ||||
| | | | | * spi/mc68360_spidrv.c: Convert to "bool". | ||||
| | | | | * shared/comm/i386-stub.c, shared/irq/irq.c: Misc. "bool" changes. | ||||
* | Misc. "bool" changes. | Ralf Corsepius | 2008-09-06 | 2 | -3/+3 |
* | Convert to Unix file format. | Ralf Corsepius | 2008-09-06 | 1 | -316/+316 |
* | 2008-09-05 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-05 | 4 | -106/+8 |
| | | | | | | | | * sh7032/clock/ckinit.c, sh7045/clock/ckinit.c, sh7750/clock/ckinit.c: The Shared Memory Driver no longer requires the special IOCTL in Clock_control. This was a hack which has existed since before the Classic API Timer Manager was implemented. All implementations of and references to Clock_control were removed. |
